[petsc-users] Doubt about TSMonitorSolutionVTK
MIGUEL MOLINOS PEREZ mmolinos at us.es
Wed Jun 26 16:30:00 CDT 2024
Sorry, I did not put in cc petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov> my replay.
Miguel
On Jun 24, 2024, at 6:39 PM, MIGUEL MOLINOS PEREZ <mmolinos at us.es> wrote:
Thank you Barry,
This is exactly how I did it the first time.
Miguel
On Jun 24, 2024, at 6:37 PM, Barry Smith <bsmith at petsc.dev> wrote:
   See, for example, the bottom of src/ts/tutorials/ex26.c  that uses -ts_monitor_solution_vtk 'foo-%03d.vts'
On Jun 24, 2024, at 8:47 PM, MIGUEL MOLINOS PEREZ <mmolinos at us.es> wrote:
This Message Is From an External Sender
This message came from outside your organization.
Dear all,
I want to monitor the results at each iteration of TS using vtk format. To do so, I add the following lines to my Monitor function:
char vts_File_Name[MAXC];
PetscCall(PetscSNPrintf(vts_File_Name, sizeof(vts_File_Name),
"./xi-MgHx-hcp-cube-x5-x5-x5-TS-BE-%i.vtu", step));
PetscCall(TSMonitorSolutionVTK(ts, step, time, X, (void*)vts_File_Name));
My script compiles and executes without any sort of warning/error messages. However, no output files are produced at the end of the simulation. I’ve also tried the option “-ts_monitor_solution_vtk <filename-%03D.vts>”, but I got no results as well.
I can’t find any similar example on the petsc website and I don’t see what I am doing wrong. Could somebody point me to the right direction?
Miguel
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240626/da416a6d/attachment-0001.html>
