[petsc-users] [petsc-maint] Assistance Needed with PETSc KSPSolve Performance Issue
Junchao Zhang junchao.zhang at gmail.com
Tue Jun 25 17:34:12 CDT 2024
Hi, Yongzhong,
  Since the two kernels of KSPGMRESOrthog are VecMDot and VecMAXPY,  if we
can speed up the two with OpenMP threads, then we can speed up
KSPGMRESOrthog.  We recently added an optimization to do VecMDot/MAXPY() in
dense matrix-vector multiplication (i.e., BLAS2 GEMV, with tall-and-skinny
matrices ).  So with MKL_VERBOSE=1,  you should see something like
"MKL_VERBOSE ZGEMV ..."  in output.  If not, could you try again with
petsc/main?
  petsc has a microbenchmark (vec/vec/tests/ex2k.c) to test them.  I ran
VecMDot with multithreaded oneMKL (via setting MKL_NUM_THREADS), it was
strange to see no speedup.   I then configured petsc with openblas, I did
see better performance with more threads
$ OMP_PROC_BIND=spread OMP_NUM_THREADS=1 ./ex2k -n 15 -m 4
Vector(N)      VecMDot-3    VecMDot-8    VecMDot-30  (us)
         128         2.0          2.5          6.1
         256         1.8          2.7          7.0
         512         2.1          3.1          8.6
        1024         2.7          4.0         12.3
        2048         3.8          6.3         28.0
        4096         6.1         10.6         42.4
        8192        10.9         21.8         79.5
       16384        21.2         39.4        149.6
       32768        45.9         75.7        224.6
       65536       142.2        215.8        732.1
      131072       169.1        233.2       1729.4
      262144       367.5        830.0       4159.2
      524288       999.2       1718.1       8538.5
     1048576      2113.5       4082.1      18274.8
     2097152      5392.6      10273.4      43273.4
$ OMP_PROC_BIND=spread OMP_NUM_THREADS=8 ./ex2k -n 15 -m 4
         128         2.0          2.5          6.0
         256         1.8          2.7         15.0
         512         2.1          9.0         16.6
        1024         2.6          8.7         16.1
        2048         7.7         10.3         20.5
        4096         9.9         11.4         25.9
        8192        14.5         22.1         39.6
       16384        25.1         27.8         67.8
       32768        44.7         95.7         91.5
       65536        82.1        156.8        165.1
      131072       194.0        335.1        341.5
      262144       388.5        380.8        612.9
      524288      1046.7        967.1       1653.3
     1048576      1997.4       2169.0       4034.4
     2097152      5502.9       5787.3      12608.1
The tall-and-skinny matrices in KSPGMRESOrthog vary in width.  The average
speedup depends on components.  So I suggest you run ex2k to see in your
environment whether oneMKL can speedup the kernels.
--Junchao Zhang
On Mon, Jun 24, 2024 at 11:35 AM Junchao Zhang <junchao.zhang at gmail.com>
wrote:
> Let me run some examples on our end to see whether the code calls expected
> functions.
> --Junchao Zhang
> On Mon, Jun 24, 2024 at 10:46 AM Matthew Knepley <knepley at gmail.com>
> wrote:
>> On Mon, Jun 24, 2024 at 11: 21 AM Yongzhong Li <yongzhong. li@ mail.
>> utoronto. ca> wrote: Thank you Pierre for your information. Do we have a
>> conclusion for my original question about the parallelization efficiency
>> for different stages of
>> ZjQcmQRYFpfptBannerStart
>> This Message Is From an External Sender
>> This message came from outside your organization.
>> ZjQcmQRYFpfptBannerEnd
>> On Mon, Jun 24, 2024 at 11:21 AM Yongzhong Li <
>> yongzhong.li at mail.utoronto.ca> wrote:
>>> Thank you Pierre for your information. Do we have a conclusion for my
>>> original question about the parallelization efficiency for different stages
>>> of KSP Solve? Do we need to do more testing to figure out the issues? Thank
>>> you, Yongzhong From:
>> We have an extended discussion of this here:
>> https://urldefense.us/v3/__https://petsc.org/release/faq/*what-kind-of-parallel-computers-or-clusters-are-needed-to-use-petsc-or-why-do-i-get-little-speedup__;Iw!!G_uCfscf7eWS!YH0MZEitgVyMCSrjwIzvt_s5lUzx3y_DLknXI9TNdBzdEWWAvy0nWkeaPe2b54Q6ioRraV7S3gzxr_k9JDqYX1rvYgHD$
>> <https://urldefense.us/v3/__https://petsc.org/release/faq/*what-kind-of-parallel-computers-or-clusters-are-needed-to-use-petsc-or-why-do-i-get-little-speedup__;Iw!!G_uCfscf7eWS!aQJpmm5W6l6FUiumnIPmkouzwzNUfx-Dyq04i1O2KS_InQGk6qjI7wUir0Hx6QEUQE2AMiJDsez3x4zRO7V_$>
>> The kinds of operations you are talking about (SpMV, VecDot, VecAXPY,
>> etc) are memory bandwidth limited. If there is no more bandwidth to be
>> marshalled on your board, then adding more processes does nothing at all.
>> This is why people were asking about how many "nodes" you are running on,
>> because that is the unit of memory bandwidth, not "cores" which make little
>> difference.
>>   Thanks,
>>      Matt
>>> Thank you,
>>> Yongzhong
>>> *From: *Pierre Jolivet <pierre at joliv.et>
>>> *Date: *Sunday, June 23, 2024 at 12:41 AM
>>> *To: *Yongzhong Li <yongzhong.li at mail.utoronto.ca>
>>> *Cc: *petsc-users at mcs.anl.gov <petsc-users at mcs.anl.gov>
>>> *Subject: *Re: [petsc-users] [petsc-maint] Assistance Needed with PETSc
>>> On 23 Jun 2024, at 4:07 AM, Yongzhong Li <yongzhong.li at mail.utoronto.ca>
>>> Yeah, I ran my program again using -mat_view::ascii_info and set
>>> MKL_VERBOSE to be 1, then I noticed the outputs suggested that the matrix
>>> to be seqaijmkl type (I’ve attached a few as below)
>>> --> Setting up matrix-vector products...
>>> Mat Object: 1 MPI process
>>>   type: seqaijmkl
>>>   rows=16490, cols=35937
>>>   total: nonzeros=128496, allocated nonzeros=128496
>>>   total number of mallocs used during MatSetValues calls=0
>>>     not using I-node routines
>>>   type: seqaijmkl
>>> --> Solving the system...
>>> Excitation 1 of 1...
>>> Iterative solve completed in 7435 ms.
>>> CONVERGED: rtol.
>>> Iterations: 72
>>> Final relative residual norm: 9.22287e-07
>>> [CPU TIME] System solution: 2.27160000e+02 s.
>>> [WALL TIME] System solution: 7.44387218e+00 s.
>>> However, it seems to me that there were still no MKL outputs even I set
>>> MKL_VERBOSE to be 1. Although, I think it should be many spmv operations
>>> when doing KSPSolve(). Do you see the possible reasons?
>>> SPMV are not reported with MKL_VERBOSE (last I checked), only dense BLAS
>>> is.
>>> Thanks,
>>> Pierre
>>> Thanks,
>>> Yongzhong
>>> *From: *Matthew Knepley <knepley at gmail.com>
>>> *Date: *Saturday, June 22, 2024 at 5:56 PM
>>> *Cc: *Junchao Zhang <junchao.zhang at gmail.com>, Pierre Jolivet <
>>> pierre at joliv.et>, petsc-users at mcs.anl.gov <petsc-users at mcs.anl.gov>
>>> 你通常不会收到来自 knepley at gmail.com 的电子邮件。了解这一点为什么很重要
>>> <https://urldefense.us/v3/__https://aka.ms/LearnAboutSenderIdentification__;!!G_uCfscf7eWS!fVvbGldqcUV5ju4jpu5oGmt-VjITi5JpCJzhHxpbgsERLVYZzglpxKOOyrBRGxjRxp7vWHwt3SnINFOQErR1Z8kcDcf3qwbYRxM$>
>>> On Sat, Jun 22, 2024 at 5:03 PM Yongzhong Li <
>>> MKL_VERBOSE=1 ./ex1 matrix nonzeros = 100, allocated nonzeros = 100
>>> MKL_VERBOSE Intel(R) MKL 2019. 0 Update 4 Product build 20190411 for
>>> Intel(R) 64 architecture Intel(R) Advanced Vector Extensions 512 (Intel(R)
>>> AVX-512) with support of Vector
>>> *This Message Is From an External Sender*
>>> MKL_VERBOSE=1 ./ex1
>>> MKL_VERBOSE Intel(R) MKL 2019.0 Update 4 Product build 20190411 for
>>> AVX-512) with support of Vector Neural Network Instructions enabled
>>> processors, Lnx 2.50GHz lp64 gnu_thread
>>> MKL_VERBOSE
>>> ZGEMV(N,10,10,0x7ffd9d7078f0,0x187eb20,10,0x187f7c0,1,0x7ffd9d707900,0x187ff70,1)
>>> 167.34ms CNR:OFF Dyn:1 FastMM:1 TID:0  NThr:1
>>> MKL_VERBOSE ZSYTRF(L,10,0x1894b50,10,0x1893df0,0x7ffd9d7078c0,-1,0)
>>> 77.19ms CNR:OFF Dyn:1 FastMM:1 TID:0  NThr:1
>>> MKL_VERBOSE ZSYTRF(L,10,0x1894b50,10,0x1893df0,0x1894490,10,0) 83.97ms
>>> MKL_VERBOSE ZSYTRS(L,10,1,0x1894b50,10,0x1893df0,0x1880720,10,0) 44.94ms
>>> MKL_VERBOSE ZAXPY(10,0x7ffd9d7078f0,0x187f7c0,1,0x1880720,1) 20.72us
>>> MKL_VERBOSE ZSYTRS(L,10,2,0x1894b50,10,0x1893df0,0x187d2a0,10,0) 4.22us
>>> MKL_VERBOSE
>>> ZGEMM(N,N,10,2,10,0x7ffd9d707790,0x187eb20,10,0x187d2a0,10,0x7ffd9d7077a0,0x1896a70,10)
>>> 1.41ms CNR:OFF Dyn:1 FastMM:1 TID:0  NThr:1
>>> MKL_VERBOSE ZAXPY(20,0x7ffd9d7078a0,0x1896a70,1,0x187b650,1) 381ns
>>> MKL_VERBOSE ZSYTRF(L,10,0x1894b50,10,0x1893df0,0x7ffd9d707840,-1,0)
>>> 742ns CNR:OFF Dyn:1 FastMM:1 TID:0  NThr:1
>>> MKL_VERBOSE ZSYTRF(L,10,0x1894b50,10,0x1893df0,0x18951a0,10,0) 4.20us
>>> MKL_VERBOSE ZSYTRS(L,10,1,0x1894b50,10,0x1893df0,0x1880720,10,0) 2.94us
>>> MKL_VERBOSE ZAXPY(10,0x7ffd9d7078f0,0x187f7c0,1,0x1880720,1) 292ns
>>> MKL_VERBOSE
>>> 1.17us CNR:OFF Dyn:1 FastMM:1 TID:0  NThr:1
>>> MKL_VERBOSE ZGETRF(10,10,0x1894b50,10,0x1893df0,0) 202.48ms CNR:OFF
>>> MKL_VERBOSE ZGETRS(N,10,1,0x1894b50,10,0x1893df0,0x1880720,10,0) 20.78ms
>>> MKL_VERBOSE ZAXPY(10,0x7ffd9d7078f0,0x187f7c0,1,0x1880720,1) 954ns
>>> MKL_VERBOSE ZGETRS(N,10,2,0x1894b50,10,0x1893df0,0x187d2a0,10,0) 30.74ms
>>> MKL_VERBOSE
>>> ZGEMM(N,N,10,2,10,0x7ffd9d707790,0x187eb20,10,0x187d2a0,10,0x7ffd9d7077a0,0x18969c0,10)
>>> 3.95us CNR:OFF Dyn:1 FastMM:1 TID:0  NThr:1
>>> MKL_VERBOSE ZAXPY(20,0x7ffd9d7078a0,0x18969c0,1,0x187b650,1) 995ns
>>> MKL_VERBOSE ZGETRF(10,10,0x1894b50,10,0x1893df0,0) 4.09us CNR:OFF Dyn:1
>>> MKL_VERBOSE ZGETRS(N,10,1,0x1894b50,10,0x1893df0,0x1880720,10,0) 3.92us
>>> MKL_VERBOSE ZAXPY(10,0x7ffd9d7078f0,0x187f7c0,1,0x1880720,1) 274ns
>>> MKL_VERBOSE
>>> ZGEMV(N,15,10,0x7ffd9d7078f0,0x187ec70,15,0x187fc30,1,0x7ffd9d707900,0x1880400,1)
>>> 1.59us CNR:OFF Dyn:1 FastMM:1 TID:0  NThr:1
>>> MKL_VERBOSE ZGEQRF(15,10,0x1894b40,15,0x1894550,0x7ffd9d707900,-1,0)
>>> 47.07us CNR:OFF Dyn:1 FastMM:1 TID:0  NThr:1
>>> MKL_VERBOSE ZGEQRF(15,10,0x1894b40,15,0x1894550,0x1895cb0,10,0) 26.62us
>>> MKL_VERBOSE
>>> ZUNMQR(L,C,15,1,10,0x1894b40,15,0x1894550,0x1895b00,15,0x7ffd9d7078b0,-1,0)
>>> 35.32us CNR:OFF Dyn:1 FastMM:1 TID:0  NThr:1
>>> MKL_VERBOSE
>>> ZUNMQR(L,C,15,1,10,0x1894b40,15,0x1894550,0x1895b00,15,0x1895cb0,10,0)
>>> 42.33ms CNR:OFF Dyn:1 FastMM:1 TID:0  NThr:1
>>> MKL_VERBOSE ZTRTRS(U,N,N,10,1,0x1894b40,15,0x1895b00,15,0) 16.11us
>>> MKL_VERBOSE ZAXPY(10,0x7ffd9d7078f0,0x187fc30,1,0x1880c70,1) 395ns
>>> MKL_VERBOSE
>>> ZGEMM(N,N,15,2,10,0x7ffd9d707790,0x187ec70,15,0x187d310,10,0x7ffd9d7077a0,0x187b5b0,15)
>>> 3.22us CNR:OFF Dyn:1 FastMM:1 TID:0  NThr:1
>>> MKL_VERBOSE
>>> ZUNMQR(L,C,15,2,10,0x1894b40,15,0x1894550,0x1897760,15,0x7ffd9d7078c0,-1,0)
>>> 730ns CNR:OFF Dyn:1 FastMM:1 TID:0  NThr:1
>>> MKL_VERBOSE
>>> ZUNMQR(L,C,15,2,10,0x1894b40,15,0x1894550,0x1897760,15,0x1895cb0,10,0)
>>> 4.42us CNR:OFF Dyn:1 FastMM:1 TID:0  NThr:1
>>> MKL_VERBOSE ZTRTRS(U,N,N,10,2,0x1894b40,15,0x1897760,15,0) 5.96us
>>> MKL_VERBOSE ZAXPY(20,0x7ffd9d7078a0,0x187d310,1,0x1897610,1) 222ns
>>> MKL_VERBOSE ZGEQRF(15,10,0x1894b40,15,0x18954b0,0x7ffd9d707820,-1,0)
>>> 685ns CNR:OFF Dyn:1 FastMM:1 TID:0  NThr:1
>>> MKL_VERBOSE ZGEQRF(15,10,0x1894b40,15,0x18954b0,0x1895d60,10,0) 6.11us
>>> MKL_VERBOSE
>>> ZUNMQR(L,C,15,1,10,0x1894b40,15,0x18954b0,0x1895bb0,15,0x7ffd9d7078b0,-1,0)
>>> 390ns CNR:OFF Dyn:1 FastMM:1 TID:0  NThr:1
>>> MKL_VERBOSE
>>> ZUNMQR(L,C,15,1,10,0x1894b40,15,0x18954b0,0x1895bb0,15,0x1895d60,10,0)
>>> 3.09us CNR:OFF Dyn:1 FastMM:1 TID:0  NThr:1
>>> MKL_VERBOSE ZTRTRS(U,N,N,10,1,0x1894b40,15,0x1895bb0,15,0) 1.05us
>>> MKL_VERBOSE ZAXPY(10,0x7ffd9d7078f0,0x187fc30,1,0x1880c70,1) 257ns
>>> Yes, for petsc example, there are MKL outputs, but for my own program.
>>> All I did is to change the matrix type from MATAIJ to MATAIJMKL to get
>>> optimized performance for spmv from MKL. Should I expect to see any MKL
>>> outputs in this case?
>>> Are you sure that the type changed? You can MatView() the matrix with
>>> format ascii_info to see.
>>>   Thanks,
>>>      Matt
>>> Thanks,
>>> Yongzhong
>>> *From: *Junchao Zhang <junchao.zhang at gmail.com>
>>> *Date: *Saturday, June 22, 2024 at 9:40 AM
>>> *Cc: *Pierre Jolivet <pierre at joliv.et>, petsc-users at mcs.anl.gov <
>>> No,  you don't.  It is strange.  Perhaps you can you run a petsc example
>>> first and see if MKL is really used
>>> $ cd src/mat/tests
>>> $ make ex1
>>> $ MKL_VERBOSE=1 ./ex1
>>> --Junchao Zhang
>>> On Fri, Jun 21, 2024 at 4:03 PM Yongzhong Li <
>>> I am using
>>> export MKL_VERBOSE=1
>>> ./xx
>>> in the bash file, do I have to use - ksp_converged_reason?
>>> Thanks,
>>> Yongzhong
>>> *Date: *Friday, June 21, 2024 at 1:47 PM
>>> *Cc: *Junchao Zhang <junchao.zhang at gmail.com>, petsc-users at mcs.anl.gov <
>>> 你通常不会收到来自 pierre at joliv.et 的电子邮件。了解这一点为什么很重要
>>> <https://urldefense.us/v3/__https://aka.ms/LearnAboutSenderIdentification__;!!G_uCfscf7eWS!flsZMI97ne0yyxHhLda3hROB9qsgstuZS-jPinxGIzFCCSdn1ujdoMR8dyz-5_kVqqMM-12Lt0dTdjKrx3wXhHZmBhNydvFQeSY$>
>>> How do you set the variable?
>>> $ MKL_VERBOSE=1 ./ex1 -ksp_converged_reason
>>> MKL_VERBOSE oneMKL 2024.0 Update 1 Product build 20240215 for Intel(R)
>>> 64 architecture Intel(R) Advanced Vector Extensions 2 (Intel(R) AVX2)
>>> enabled processors, Lnx 2.80GHz lp64 intel_thread
>>> MKL_VERBOSE DDOT(10,0x22127c0,1,0x22127c0,1) 2.02ms CNR:OFF Dyn:1
>>> MKL_VERBOSE DSCAL(10,0x7ffc9fb4ff08,0x22127c0,1) 12.67us CNR:OFF Dyn:1
>>> MKL_VERBOSE DDOT(10,0x22127c0,1,0x2212840,1) 1.52us CNR:OFF Dyn:1
>>> MKL_VERBOSE DDOT(10,0x2212840,1,0x2212840,1) 167ns CNR:OFF Dyn:1
>>> On 21 Jun 2024, at 7:37 PM, Yongzhong Li <yongzhong.li at mail.utoronto.ca>
>>> Hello all,
>>> I set MKL_VERBOSE = 1, but observed no print output specific to the use
>>> of MKL. Does PETSc enable this verbose output?
>>> Best,
>>> Yongzhong
>>> *Date: *Friday, June 21, 2024 at 1:36 AM
>>> *To: *Junchao Zhang <junchao.zhang at gmail.com>
>>> *Cc: *Yongzhong Li <yongzhong.li at mail.utoronto.ca>,
>>> <https://urldefense.us/v3/__https://aka.ms/LearnAboutSenderIdentification__;!!G_uCfscf7eWS!eXBeeIXo9Yqgp2nypqwKYimLnGBZXnF4dXxgLM1UoOIO6n8nt3XlfgjVWLPWJh4UOa5NNpx-nrJb_H828XRQKUREfR2m69oCbxI$>
>>> On 21 Jun 2024, at 6:42 AM, Junchao Zhang <junchao.zhang at gmail.com>
>>> I remember there are some MKL env vars to print MKL routines called.
>>> The environment variable is MKL_VERBOSE
>>> Thanks,
>>> Pierre
>>> Maybe we can try it to see what MKL routines are really used and then we
>>> can understand why some petsc functions did not speed up
>>> --Junchao Zhang
>>> On Thu, Jun 20, 2024 at 10:39 PM Yongzhong Li <
>>> Hi Barry, sorry for my last results. I didn’t fully understand the stage
>>> profiling and logging in PETSc, now I only record KSPSolve() stage of my
>>> program. Some sample codes are as follow,
>>>                 // Static variable to keep track of the stage counter
>>>                 static int stageCounter = 1;
>>>                 // Generate a unique stage name
>>>                 std::ostringstream oss;
>>>                 oss << "Stage " << stageCounter << " of Code";
>>>                 std::string stageName = oss.str();
>>>                 // Register the stage
>>>                 PetscLogStage stagenum;
>>>                 PetscLogStageRegister(stageName.c_str(), &stagenum);
>>>                 PetscLogStagePush(stagenum);
>>>                 *KSPSolve(*ksp_ptr, b, x);*
>>>                 PetscLogStagePop();
>>>                 stageCounter++;
>>> I have attached my new logging results, there are 1 main stage and 4
>>> other stages where each one is KSPSolve() call.
>>> To provide some additional backgrounds, if you recall, I have been
>>> trying to get efficient iterative solution using multithreading. I found
>>> out by compiling PETSc with Intel MKL library instead of OpenBLAS, I am
>>> able to perform sparse matrix-vector multiplication faster, I am using
>>> MATSEQAIJMKL. This makes the shell matrix vector product in each iteration
>>> scale well with the #of threads. However, I found out the total GMERS solve
>>> time (~KSPSolve() time) is not scaling well the #of threads.
>>> From the logging results I learned that when performing KSPSolve(),
>>> there are some CPU overheads in PCApply() and KSPGMERSOrthog(). I ran my
>>> programs using different number of threads and plotted the time consumption
>>> for PCApply() and KSPGMERSOrthog() against #of thread. I found out these
>>> two operations are not scaling with the threads at all! My results are
>>> attached as the pdf to give you a clear view.
>>> My questions is,
>>> From my understanding, in PCApply, MatSolve() is involved,
>>> KSPGMERSOrthog() will have many vector operations, so why these two parts
>>> can’t scale well with the # of threads when the intel MKL library is linked?
>>> Thank you,
>>> Yongzhong
>>> *From: *Barry Smith <bsmith at petsc.dev>
>>> *Date: *Friday, June 14, 2024 at 11:36 AM
>>> *Cc: *petsc-users at mcs.anl.gov <petsc-users at mcs.anl.gov>,
>>> petsc-maint at mcs.anl.gov <petsc-maint at mcs.anl.gov>, Piero Triverio <
>>> piero.triverio at utoronto.ca>
>>> *Subject: *Re: [petsc-maint] Assistance Needed with PETSc KSPSolve
>>> Performance Issue
>>>    I am a bit confused. Without the initial guess computation, there are
>>> still a bunch of events I don't understand
>>> MatTranspose          79 1.0 4.0598e+01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
>>> 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
>>> MatMatMultSym        110 1.0 1.7419e+02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
>>> 0.0e+00  1  0  0  0  0   1  0  0  0  0     0
>>> MatMatMultNum         90 1.0 1.2640e+02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
>>> MatMatMatMultSym      20 1.0 1.3049e+02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
>>> MatRARtSym            25 1.0 1.2492e+02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
>>> MatMatTrnMultSym      25 1.0 8.8265e+01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
>>> MatMatTrnMultNum      25 1.0 2.4820e+02 1.0 6.83e+10 1.0 0.0e+00 0.0e+00
>>> 0.0e+00  1  0  0  0  0   1  0  0  0  0   275
>>> MatTrnMatMultSym      10 1.0 7.2984e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
>>> MatTrnMatMultNum      10 1.0 9.3128e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
>>> in addition there are many more VecMAXPY then VecMDot (in GMRES they are
>>> each done the same number of times)
>>> VecMDot             5588 1.0 1.7183e+03 1.0 2.06e+13 1.0 0.0e+00 0.0e+00
>>> 0.0e+00  8 10  0  0  0   8 10  0  0  0 12016
>>> VecMAXPY           22412 1.0 8.4898e+03 1.0 4.17e+13 1.0 0.0e+00 0.0e+00
>>> 0.0e+00 39 20  0  0  0  39 20  0  0  0  4913
>>> Finally there are a huge number of
>>> MatMultAdd        258048 1.0 1.4178e+03 1.0 6.10e+13 1.0 0.0e+00 0.0e+00
>>> 0.0e+00  7 29  0  0  0   7 29  0  0  0 43025
>>> Are you making calls to all these routines? Are you doing this inside
>>> your MatMult() or before you call KSPSolve?
>>> The reason I wanted you to make a simpler run without the initial guess
>>> code is that your events are far more complicated than would be produced by
>>> GMRES alone so it is not possible to understand the behavior you are seeing
>>> without fully understanding all the events happening in the code.
>>>   Barry
>>> On Jun 14, 2024, at 1:19 AM, Yongzhong Li <yongzhong.li at mail.utoronto.ca>
>>> wrote:
>>> Thanks, I have attached the results without using any KSPGuess. At low
>>> frequency, the iteration steps are quite close to the one with KSPGuess,
>>> specifically
>>>   KSPGuess Object: 1 MPI process
>>>     type: fischer
>>>     Model 1, size 200
>>> However, I found at higher frequency, the # of iteration steps are
>>>  significant higher than the one with KSPGuess, I have attahced both of the
>>> results for your reference.
>>> Moreover, could I ask why the one without the KSPGuess options can be
>>> used for a baseline comparsion? What are we comparing here? How does it
>>> relate to the performance issue/bottleneck I found? “*I have noticed
>>> that the time taken by **KSPSolve** is **almost two times **greater
>>> than the CPU time for matrix-vector product multiplied by the number of
>>> iteration*”
>>> Thank you!
>>> Yongzhong
>>> *Date: *Thursday, June 13, 2024 at 2:14 PM
>>> Performance Issue
>>>   Can you please run the same thing without the  KSPGuess option(s) for
>>> a baseline comparison?
>>>    Thanks
>>>    Barry
>>> On Jun 13, 2024, at 1:27 PM, Yongzhong Li <yongzhong.li at mail.utoronto.ca>
>>> Hi Matt,
>>> I have rerun the program with the keys you provided. The system output
>>> when performing ksp solve and the final petsc log output were stored in a
>>> .txt file attached for your reference.
>>> Thanks!
>>> Yongzhong
>>> *Date: *Wednesday, June 12, 2024 at 6:46 PM
>>> Performance Issue
>>> <https://urldefense.us/v3/__https://aka.ms/LearnAboutSenderIdentification__;!!G_uCfscf7eWS!djGfJnEhNJROfsMsBJy5u_KoRKbug55xZ64oHKUFnH2cWku_Th1hwt4TDdoMd8pWYVDzJeqJslMNZwpO3y0Et94d31qk-oCEwo4$>
>>> On Wed, Jun 12, 2024 at 6:36 PM Yongzhong Li <
>>> Dear PETSc’s developers, I hope this email finds you well. I am
>>> currently working on a project using PETSc and have encountered a
>>> performance issue with the KSPSolve function. Specifically, I have noticed
>>> that the time taken by KSPSolve is
>>> I am currently working on a project using PETSc and have encountered a
>>> performance issue with the KSPSolve function. Specifically, *I have
>>> noticed that the time taken by **KSPSolve** is **almost two times **greater
>>> iteration steps*. I use C++ chrono to record CPU time.
>>> For context, I am using a shell system matrix A. Despite my efforts to
>>> parallelize the matrix-vector product (Ax), the overall solve time
>>> remains higher than the matrix vector product per iteration indicates
>>> when multiple threads were used. Here are a few details of my setup:
>>>    - *Matrix Type*: Shell system matrix
>>>    - *Preconditioner*: Shell PC
>>>    - *Parallel Environment*: Using Intel MKL as PETSc’s BLAS/LAPACK
>>>    library, multithreading is enabled
>>> I have considered several potential reasons, such as preconditioner
>>> setup, additional solver operations, and the inherent overhead of using a
>>> shell system matrix. *However, since KSPSolve is a high-level API, I
>>> have been unable to pinpoint the exact cause of the increased solve time.*
>>> Have you observed the same issue? Could you please provide some
>>> experience on how to diagnose and address this performance discrepancy?
>>> Any insights or recommendations you could offer would be greatly
>>> appreciated.
>>> For any performance question like this, we need to see the output of
>>> your code run with
>>>   -ksp_view -ksp_monitor_true_residual -ksp_converged_reason -log_view
>>>   Thanks,
>>>      Matt
>>> Thank you for your time and assistance.
>>> Best regards,
>>> Yongzhong
>>> *Yongzhong Li*
>>> PhD student | Electromagnetics Group
>>> Department of Electrical & Computer Engineering
>>> University of Toronto
>>> https://urldefense.us/v3/__http://www.modelics.org__;!!G_uCfscf7eWS!YH0MZEitgVyMCSrjwIzvt_s5lUzx3y_DLknXI9TNdBzdEWWAvy0nWkeaPe2b54Q6ioRraV7S3gzxr_k9JDqYXymw_hMJ$
>>> <https://urldefense.us/v3/__http://www.modelics.org__;!!G_uCfscf7eWS!cuLttMJEcegaqu461Bt4QLsO4fASfLM5vjRbtyNhWJQiInbjgNwkGNdkFE1ebSbFjOUatYB0-jd2yQWMWzqkDFFjwMvNl3ZKAr8$>
>>> What most experimenters take for granted before they begin their
>>> experiments is infinitely more interesting than any results to which their
>>> experiments lead.
>>> -- Norbert Wiener
>>> https://urldefense.us/v3/__https://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!YH0MZEitgVyMCSrjwIzvt_s5lUzx3y_DLknXI9TNdBzdEWWAvy0nWkeaPe2b54Q6ioRraV7S3gzxr_k9JDqYX78QsGNH$
>>> <https://urldefense.us/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!djGfJnEhNJROfsMsBJy5u_KoRKbug55xZ64oHKUFnH2cWku_Th1hwt4TDdoMd8pWYVDzJeqJslMNZwpO3y0Et94d31qkNOuenGA$>
>>> <ksp_petsc_log.txt>
>>> <ksp_petsc_log.txt><ksp_petsc_log_noguess.txt>
>>> experiments lead.
>>> -- Norbert Wiener
>>> <https://urldefense.us/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!fVvbGldqcUV5ju4jpu5oGmt-VjITi5JpCJzhHxpbgsERLVYZzglpxKOOyrBRGxjRxp7vWHwt3SnINFOQErR1Z8kcDcf3cNeD9Gw$>
>> experiments lead.
>> -- Norbert Wiener
>> <https://urldefense.us/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!aQJpmm5W6l6FUiumnIPmkouzwzNUfx-Dyq04i1O2KS_InQGk6qjI7wUir0Hx6QEUQE2AMiJDsez3x2Os2C2d$>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240625/4e6a3f63/attachment-0001.html>
