[petsc-users] Issues Compiling petsc4py with Cython
Stefano Zampini
stefano.zampini at gmail.com
Tue Jun 25 14:00:00 CDT 2024
Which version of petsc4py is it?
Il giorno mar 25 giu 2024 alle ore 20:35 maitri ksh <maitri.ksh at gmail.com>
ha scritto:
> I am currently working on integrating petsc4py, but I am encountering
> persistent compilation issues related to Cython. Below are the details of
> my setup and the errors I am facing. I would greatly appreciate any
> assistance or guidance on how
> ZjQcmQRYFpfptBannerStart
> This Message Is From an External Sender
> This message came from outside your organization.
> ZjQcmQRYFpfptBannerEnd
> assistance or guidance on how to resolve these issues.
> System Configuration:
> - *PETSc Architecture*: linux-gnu-c-debug
> - *Python Environment*: Python 3.6 (virtual environment)
> - *Cython Version*: 3.0.10
> - *Compiler*: /gcc11.2/bin/gcc
> During the build process, I received multiple warnings and errors related
> to the use of noexcept, nogil, and except in function declarations. Here
> are some of the specific errors:
> cythonizing 'petsc4py.PETSc.pyx' -> 'petsc4py.PETSc.c'
> warning: petsc4py.PETSc.pyx:1:0: Dotted filenames ('petsc4py.PETSc.pyx')
> are deprecated. Please use the normal Python package directory layout.
> /home/maitri.ksh/Maitri/petsc/petsc4py/myenv/lib64/python3.6/site-packages/Cython/Compiler/Main.py:381:
> FutureWarning: Cython directive 'language_level' not set, using '3str' for
> now (Py3). This has changed from earlier releases! File:
> include/petsc4py/PETSc.pxd
> tree = Parsing.p_module(s, pxd, full_module_name)
> warning: PETSc/PETSc.pyx:53:48: The keyword 'nogil' should appear at the
> end of the function signature line. Placing it before 'except' or
> 'noexcept' will be disallowed in a future version of Cython.
> warning: PETSc/petscvec.pxi:406:79: The keyword 'nogil' should appear at
> the end of the function signature line. Placing it before 'except' or
> warning: PETSc/petscvec.pxi:411:79: The keyword 'nogil' should appear at
> Error compiling Cython file:
> PETSc/petscobj.pxi:91:29: Cannot assign type 'int (void *) except? -1
> nogil' to 'int (*)(void *) noexcept'. Exception values are incompatible.
> Suggest adding 'noexcept' to the type of 'PetscDelPyDict'.
> PETSc/cyclicgc.pxi:34:20: Cannot assign type 'int (PyObject *, visitproc,
> void *) except? -1' to 'traverseproc *'. Exception values are incompatible.
> Suggest adding 'noexcept' to the type of 'tp_traverse'.
> PETSc/cyclicgc.pxi:35:20: Cannot assign type 'int (PyObject *) except? -1'
> to 'inquiry *'. Exception values are incompatible. Suggest adding
> 'noexcept' to the type of 'tp_clear'.
> PETSc/PETSc.pyx:351:17: Cannot assign type 'void (void) except * nogil' to
> 'void (*)(void) noexcept'. Exception values are incompatible. Suggest
> adding 'noexcept' to the type of 'finalize'.
> error: Cython failure: 'petsc4py.PETSc.pyx' -> 'petsc4py.PETSc.c'
> Any advice on building petsc4py in environments similar to mine would be
> greatly appreciated.
> Thanks,
> Maitri
Stefano
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240625/43fdbdc3/attachment-0001.html>
