[petsc-users] Error type "Petsc has generated inconsistent data"
Barry Smith
bsmith at petsc.dev
Mon Jun 24 14:56:46 CDT 2024
The error is coming from the parallel SNES used by TS TSTheta_SNESSolve() not your small SNES solver but TSTheta_SNESSolve()
Process 7 uses [7]PETSC ERROR: #4 SNESLineSearchApply_CP() while the rest uses _BT(). I think this causes the problem since they are different algorithms using different MPI.
Are you perhaps setting somewhere the line search to use? Options database or someway that different processes will get a different value?
> On Jun 24, 2024, at 2:50 PM, MIGUEL MOLINOS PEREZ <mmolinos at us.es> wrote:
> This Message Is From an External Sender
> This message came from outside your organization.
> Dear all,
> I am trying to assemble a matrix A with coefficients which I need to assemble the RHS (F) and its Jacobian (J) in a TS type of problem.
> Determining each coefficient of A involves the resolution of a small non-linear problem (1 dof) using the serial version of SNES. By the way, the matrix A is of the type “MATMPIAIJ”.
> The weird part is, if I pass the matrix A to the TS routine inside of a user-context structure, without even accessing to the values inside of A, I got the following error message:
> > [1]PETSC ERROR: Petsc has generated inconsistent data
> > [1]PETSC ERROR: MPI_Allreduce() called in different locations (code lines)
> > on different processors
> But if I comment out the line which calls the SNES routine used to evaluate the coefficients inside of A, I don’t get the error message.
> Some additional context:
> - The SNES routine is called once at a time inside of each rank.
> - I use PetscCall(SNESCreate(PETSC_COMM_SELF,
> &snes));
> - The vectors inside of the SNES function are defined as follows:
> VecCreateSeq(PETSC_COMM_SELF,
> 1,
> &Y)
> - All the input fields for SNES are also sequential.
> Any feedback is greatly appreciated!
> Thanks,
> Miguel
> [test-Mass-Transport-Master-Equation-PETSc-Backward-Euler][MgHx-hcp-x5x5x5-cell]
> t=0.0000e+00 dt=1.0000e-07 it=( 0, 0)
> 0 KSP Residual norm 4.776631889125e-07
> 1 KSP Residual norm 6.807505564283e-17
> [0]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
> [0]PETSC ERROR: Petsc has generated inconsistent data
> [5]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
> [5]PETSC ERROR: Petsc has generated inconsistent data
> [7]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
> [7]PETSC ERROR: Petsc has generated inconsistent data
> [0]PETSC ERROR: MPI_Allreduce() called in different locations (code lines) on different processors
> [1]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
> [1]PETSC ERROR: MPI_Allreduce() called in different locations (code lines) on different processors
> [2]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
> [2]PETSC ERROR: Petsc has generated inconsistent data
> [2]PETSC ERROR: MPI_Allreduce() called in different locations (code lines) on different processors
> [3]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
> [3]PETSC ERROR: Petsc has generated inconsistent data
> [3]PETSC ERROR: MPI_Allreduce() called in different locations (code lines) on different processors
> [4]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
> [4]PETSC ERROR: Petsc has generated inconsistent data
> [4]PETSC ERROR: MPI_Allreduce() called in different locations (code lines) on different processors
> [5]PETSC ERROR: MPI_Allreduce() called in different locations (code lines) on different processors
> [6]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
> [6]PETSC ERROR: Petsc has generated inconsistent data
> [6]PETSC ERROR: MPI_Allreduce() called in different locations (code lines) on different processors
> [7]PETSC ERROR: MPI_Allreduce() called in different locations (code lines) on different processors
> [0]PETSC ERROR: WARNING! There are unused option(s) set! Could be the program crashed before usage or a spelling mistake, etc!
> [1]PETSC ERROR: WARNING! There are unused option(s) set! Could be the program crashed before usage or a spelling mistake, etc!
> [2]PETSC ERROR: WARNING! There are unused option(s) set! Could be the program crashed before usage or a spelling mistake, etc!
> [2]PETSC ERROR: Option left: name:-sns_monitor (no value) source: code
> [2]PETSC ERROR: [3]PETSC ERROR: WARNING! There are unused option(s) set! Could be the program crashed before usage or a spelling mistake, etc!
> [3]PETSC ERROR: Option left: name:-sns_monitor (no value) source: code
> [3]PETSC ERROR: See https://urldefense.us/v3/__https://petsc.org/release/faq/__;!!G_uCfscf7eWS!fEaSpu9Ts97xYvsqM9wnNqYODpUsu00JOWgIqC17b8_Oj0brMFwA1GECPWPgxJVaJ3av-AgGncHm9IRLugqkV1Y$ <https://urldefense.us/v3/__https://petsc.org/release/faq/__;!!G_uCfscf7eWS!YCo3JjgVyVqwScfRf05FevGAOdJG2APEIkhxmpYQmmJFmnrOBYrCKeun20x6gytf7m2IpXZPhyib8zJmPUCYCw$> for trouble shooting.
> [4]PETSC ERROR: WARNING! There are unused option(s) set! Could be the program crashed before usage or a spelling mistake, etc!
> [4]PETSC ERROR: Option left: name:-sns_monitor (no value) source: code
> [4]PETSC ERROR: See https://urldefense.us/v3/__https://petsc.org/release/faq/__;!!G_uCfscf7eWS!fEaSpu9Ts97xYvsqM9wnNqYODpUsu00JOWgIqC17b8_Oj0brMFwA1GECPWPgxJVaJ3av-AgGncHm9IRLugqkV1Y$ <https://urldefense.us/v3/__https://petsc.org/release/faq/__;!!G_uCfscf7eWS!YCo3JjgVyVqwScfRf05FevGAOdJG2APEIkhxmpYQmmJFmnrOBYrCKeun20x6gytf7m2IpXZPhyib8zJmPUCYCw$> for trouble shooting.
> [5]PETSC ERROR: WARNING! There are unused option(s) set! Could be the program crashed before usage or a spelling mistake, etc!
> [5]PETSC ERROR: Option left: name:-sns_monitor (no value) source: code
> [5]PETSC ERROR: See https://urldefense.us/v3/__https://petsc.org/release/faq/__;!!G_uCfscf7eWS!fEaSpu9Ts97xYvsqM9wnNqYODpUsu00JOWgIqC17b8_Oj0brMFwA1GECPWPgxJVaJ3av-AgGncHm9IRLugqkV1Y$ <https://urldefense.us/v3/__https://petsc.org/release/faq/__;!!G_uCfscf7eWS!YCo3JjgVyVqwScfRf05FevGAOdJG2APEIkhxmpYQmmJFmnrOBYrCKeun20x6gytf7m2IpXZPhyib8zJmPUCYCw$> for trouble shooting.
> [5]PETSC ERROR: Petsc Release Version 3.21.0, unknown
> [6]PETSC ERROR: WARNING! There are unused option(s) set! Could be the program crashed before usage or a spelling mistake, etc!
> [6]PETSC ERROR: Option left: name:-sns_monitor (no value) source: code
> [6]PETSC ERROR: See https://urldefense.us/v3/__https://petsc.org/release/faq/__;!!G_uCfscf7eWS!fEaSpu9Ts97xYvsqM9wnNqYODpUsu00JOWgIqC17b8_Oj0brMFwA1GECPWPgxJVaJ3av-AgGncHm9IRLugqkV1Y$ <https://urldefense.us/v3/__https://petsc.org/release/faq/__;!!G_uCfscf7eWS!YCo3JjgVyVqwScfRf05FevGAOdJG2APEIkhxmpYQmmJFmnrOBYrCKeun20x6gytf7m2IpXZPhyib8zJmPUCYCw$> for trouble shooting.
> [6]PETSC ERROR: Petsc Release Version 3.21.0, unknown
> [6]PETSC ERROR: [7]PETSC ERROR: WARNING! There are unused option(s) set! Could be the program crashed before usage or a spelling mistake, etc!
> [7]PETSC ERROR: Option left: name:-sns_monitor (no value) source: code
> [0]PETSC ERROR: Option left: name:-sns_monitor (no value) source: code
> [0]PETSC ERROR: See https://urldefense.us/v3/__https://petsc.org/release/faq/__;!!G_uCfscf7eWS!fEaSpu9Ts97xYvsqM9wnNqYODpUsu00JOWgIqC17b8_Oj0brMFwA1GECPWPgxJVaJ3av-AgGncHm9IRLugqkV1Y$ <https://urldefense.us/v3/__https://petsc.org/release/faq/__;!!G_uCfscf7eWS!YCo3JjgVyVqwScfRf05FevGAOdJG2APEIkhxmpYQmmJFmnrOBYrCKeun20x6gytf7m2IpXZPhyib8zJmPUCYCw$> for trouble shooting.
> [0]PETSC ERROR: Petsc Release Version 3.21.0, unknown
> [0]PETSC ERROR: ./exe-tasting-SOLERA on a arch-darwin-c-debug named mmp-laptop.local by migmolper Mon Jun 24 11:37:38 2024
> [1]PETSC ERROR: Option left: name:-sns_monitor (no value) source: code
> [1]PETSC ERROR: See https://urldefense.us/v3/__https://petsc.org/release/faq/__;!!G_uCfscf7eWS!fEaSpu9Ts97xYvsqM9wnNqYODpUsu00JOWgIqC17b8_Oj0brMFwA1GECPWPgxJVaJ3av-AgGncHm9IRLugqkV1Y$ <https://urldefense.us/v3/__https://petsc.org/release/faq/__;!!G_uCfscf7eWS!YCo3JjgVyVqwScfRf05FevGAOdJG2APEIkhxmpYQmmJFmnrOBYrCKeun20x6gytf7m2IpXZPhyib8zJmPUCYCw$> for trouble shooting.
> [2]PETSC ERROR: Petsc Release Version 3.21.0, unknown
> [2]PETSC ERROR: ./exe-tasting-SOLERA on a arch-darwin-c-debug named mmp-laptop.local by migmolper Mon Jun 24 11:37:38 2024
> [2]PETSC ERROR: Configure options --download-hdf5=1 --download-mpich=1 --with-debugging=1 CC=gcc CXX=c++ PETSC_ARCH=arch-darwin-c-debug --with-x
> [3]PETSC ERROR: Petsc Release Version 3.21.0, unknown
> [3]PETSC ERROR: ./exe-tasting-SOLERA on a arch-darwin-c-debug named mmp-laptop.local by migmolper Mon Jun 24 11:37:38 2024
> [3]PETSC ERROR: Configure options --download-hdf5=1 --download-mpich=1 --with-debugging=1 CC=gcc CXX=c++ PETSC_ARCH=arch-darwin-c-debug --with-x
> [4]PETSC ERROR: Petsc Release Version 3.21.0, unknown
> [4]PETSC ERROR: ./exe-tasting-SOLERA on a arch-darwin-c-debug named mmp-laptop.local by migmolper Mon Jun 24 11:37:38 2024
> [4]PETSC ERROR: Configure options --download-hdf5=1 --download-mpich=1 --with-debugging=1 CC=gcc CXX=c++ PETSC_ARCH=arch-darwin-c-debug --with-x
> [5]PETSC ERROR: ./exe-tasting-SOLERA on a arch-darwin-c-debug named mmp-laptop.local by migmolper Mon Jun 24 11:37:38 2024
> [5]PETSC ERROR: Configure options --download-hdf5=1 --download-mpich=1 --with-debugging=1 CC=gcc CXX=c++ PETSC_ARCH=arch-darwin-c-debug --with-x
> [6]PETSC ERROR: Configure options --download-hdf5=1 --download-mpich=1 --with-debugging=1 CC=gcc CXX=c++ PETSC_ARCH=arch-darwin-c-debug --with-x
> [7]PETSC ERROR: Petsc Release Version 3.21.0, unknown
> [7]PETSC ERROR: ./exe-tasting-SOLERA on a arch-darwin-c-debug named mmp-laptop.local by migmolper Mon Jun 24 11:37:38 2024
> [7]PETSC ERROR: Configure options --download-hdf5=1 --download-mpich=1 --with-debugging=1 CC=gcc CXX=c++ PETSC_ARCH=arch-darwin-c-debug --with-x
> [1]PETSC ERROR: Petsc Release Version 3.21.0, unknown
> [1]PETSC ERROR: ./exe-tasting-SOLERA on a arch-darwin-c-debug named mmp-laptop.local by migmolper Mon Jun 24 11:37:38 2024
> [1]PETSC ERROR: Configure options --download-hdf5=1 --download-mpich=1 --with-debugging=1 CC=gcc CXX=c++ PETSC_ARCH=arch-darwin-c-debug --with-x
> [0]PETSC ERROR: #1 PetscSplitReductionApply() at /Users/migmolper/petsc/src/vec/vec/utils/comb.c:230
> [2]PETSC ERROR: #1 PetscSplitReductionApply() at /Users/migmolper/petsc/src/vec/vec/utils/comb.c:230
> [2]PETSC ERROR: [3]PETSC ERROR: #1 PetscSplitReductionApply() at /Users/migmolper/petsc/src/vec/vec/utils/comb.c:230
> [3]PETSC ERROR: #2 PetscSplitReductionEnd() at /Users/migmolper/petsc/src/vec/vec/utils/comb.c:172
> [4]PETSC ERROR: #1 PetscSplitReductionApply() at /Users/migmolper/petsc/src/vec/vec/utils/comb.c:230
> [4]PETSC ERROR: #2 PetscSplitReductionEnd() at /Users/migmolper/petsc/src/vec/vec/utils/comb.c:172
> [5]PETSC ERROR: #1 PetscSplitReductionApply() at /Users/migmolper/petsc/src/vec/vec/utils/comb.c:230
> [5]PETSC ERROR: #2 PetscSplitReductionEnd() at /Users/migmolper/petsc/src/vec/vec/utils/comb.c:172
> [0]PETSC ERROR: #2 PetscSplitReductionEnd() at /Users/migmolper/petsc/src/vec/vec/utils/comb.c:172
> [0]PETSC ERROR: #3 VecNormEnd() at /Users/migmolper/petsc/src/vec/vec/utils/comb.c:553
> [0]PETSC ERROR: #4 SNESLineSearchApply_BT() at /Users/migmolper/petsc/src/snes/linesearch/impls/bt/linesearchbt.c:88
> [1]PETSC ERROR: #1 PetscSplitReductionApply() at /Users/migmolper/petsc/src/vec/vec/utils/comb.c:230
> [1]PETSC ERROR: #2 PetscSplitReductionEnd() at /Users/migmolper/petsc/src/vec/vec/utils/comb.c:172
> [1]PETSC ERROR: #3 VecNormEnd() at /Users/migmolper/petsc/src/vec/vec/utils/comb.c:553
> [2]PETSC ERROR: #3 VecNormEnd() at /Users/migmolper/petsc/src/vec/vec/utils/comb.c:553
> [2]PETSC ERROR: #4 SNESLineSearchApply_BT() at /Users/migmolper/petsc/src/snes/linesearch/impls/bt/linesearchbt.c:88
> [2]PETSC ERROR: [3]PETSC ERROR: #3 VecNormEnd() at /Users/migmolper/petsc/src/vec/vec/utils/comb.c:553
> [3]PETSC ERROR: #4 SNESLineSearchApply_BT() at /Users/migmolper/petsc/src/snes/linesearch/impls/bt/linesearchbt.c:88
> [3]PETSC ERROR: #5 SNESLineSearchApply() at /Users/migmolper/petsc/src/snes/linesearch/interface/linesearch.c:645
> [4]PETSC ERROR: #3 VecNormEnd() at /Users/migmolper/petsc/src/vec/vec/utils/comb.c:553
> [4]PETSC ERROR: #4 SNESLineSearchApply_BT() at /Users/migmolper/petsc/src/snes/linesearch/impls/bt/linesearchbt.c:88
> [4]PETSC ERROR: #5 SNESLineSearchApply() at /Users/migmolper/petsc/src/snes/linesearch/interface/linesearch.c:645
> [5]PETSC ERROR: #3 VecNormEnd() at /Users/migmolper/petsc/src/vec/vec/utils/comb.c:553
> [5]PETSC ERROR: #4 SNESLineSearchApply_BT() at /Users/migmolper/petsc/src/snes/linesearch/impls/bt/linesearchbt.c:88
> [5]PETSC ERROR: #5 SNESLineSearchApply() at /Users/migmolper/petsc/src/snes/linesearch/interface/linesearch.c:645
> [5]PETSC ERROR: [6]PETSC ERROR: #1 PetscSplitReductionApply() at /Users/migmolper/petsc/src/vec/vec/utils/comb.c:230
> [6]PETSC ERROR: #2 PetscSplitReductionEnd() at /Users/migmolper/petsc/src/vec/vec/utils/comb.c:172
> [6]PETSC ERROR: #3 VecNormEnd() at /Users/migmolper/petsc/src/vec/vec/utils/comb.c:553
> [6]PETSC ERROR: #4 SNESLineSearchApply_BT() at /Users/migmolper/petsc/src/snes/linesearch/impls/bt/linesearchbt.c:88
> [6]PETSC ERROR: #5 SNESLineSearchApply() at /Users/migmolper/petsc/src/snes/linesearch/interface/linesearch.c:645
> [7]PETSC ERROR: #1 VecXDot_MPI_Default() at /Users/migmolper/petsc/include/../src/vec/vec/impls/mpi/pvecimpl.h:107
> [7]PETSC ERROR: #2 VecDot_MPI() at /Users/migmolper/petsc/src/vec/vec/impls/mpi/pvec2.c:10
> [7]PETSC ERROR: #3 VecDot() at /Users/migmolper/petsc/src/vec/vec/interface/rvector.c:120
> [7]PETSC ERROR: #4 SNESLineSearchApply_CP() at /Users/migmolper/petsc/src/snes/linesearch/impls/cp/linesearchcp.c:28
> [0]PETSC ERROR: #5 SNESLineSearchApply() at /Users/migmolper/petsc/src/snes/linesearch/interface/linesearch.c:645
> [0]PETSC ERROR: #6 SNESSolve_NEWTONLS() at /Users/migmolper/petsc/src/snes/impls/ls/ls.c:234
> [0]PETSC ERROR: #7 SNESSolve() at /Users/migmolper/petsc/src/snes/interface/snes.c:4738
> [0]PETSC ERROR: #8 TSTheta_SNESSolve() at /Users/migmolper/petsc/src/ts/impls/implicit/theta/theta.c:174
> [1]PETSC ERROR: #4 SNESLineSearchApply_BT() at /Users/migmolper/petsc/src/snes/linesearch/impls/bt/linesearchbt.c:88
> [1]PETSC ERROR: #5 SNESLineSearchApply() at /Users/migmolper/petsc/src/snes/linesearch/interface/linesearch.c:645
> [1]PETSC ERROR: #6 SNESSolve_NEWTONLS() at /Users/migmolper/petsc/src/snes/impls/ls/ls.c:234
> [1]PETSC ERROR: #7 SNESSolve() at /Users/migmolper/petsc/src/snes/interface/snes.c:4738
> [1]PETSC ERROR: #8 TSTheta_SNESSolve() at /Users/migmolper/petsc/src/ts/impls/implicit/theta/theta.c:174
> [1]PETSC ERROR: #9 TSStep_Theta() at /Users/migmolper/petsc/src/ts/impls/implicit/theta/theta.c:225
> [1]PETSC ERROR: #10 TSStep() at /Users/migmolper/petsc/src/ts/interface/ts.c:3391
> [1]PETSC ERROR: #11 TSSolve() at /Users/migmolper/petsc/src/ts/interface/ts.c:4037
> [2]PETSC ERROR: #6 SNESSolve_NEWTONLS() at /Users/migmolper/petsc/src/snes/impls/ls/ls.c:234
> [2]PETSC ERROR: #7 SNESSolve() at /Users/migmolper/petsc/src/snes/interface/snes.c:4738
> [2]PETSC ERROR: #8 TSTheta_SNESSolve() at /Users/migmolper/petsc/src/ts/impls/implicit/theta/theta.c:174
> [2]PETSC ERROR: #9 TSStep_Theta() at /Users/migmolper/petsc/src/ts/impls/implicit/theta/theta.c:225
> [2]PETSC ERROR: #10 TSStep() at /Users/migmolper/petsc/src/ts/interface/ts.c:3391
> [2]PETSC ERROR: #11 TSSolve() at /Users/migmolper/petsc/src/ts/interface/ts.c:4037
> [3]PETSC ERROR: #6 SNESSolve_NEWTONLS() at /Users/migmolper/petsc/src/snes/impls/ls/ls.c:234
> [3]PETSC ERROR: #7 SNESSolve() at /Users/migmolper/petsc/src/snes/interface/snes.c:4738
> [3]PETSC ERROR: #8 TSTheta_SNESSolve() at /Users/migmolper/petsc/src/ts/impls/implicit/theta/theta.c:174
> [3]PETSC ERROR: #9 TSStep_Theta() at /Users/migmolper/petsc/src/ts/impls/implicit/theta/theta.c:225
> [3]PETSC ERROR: #10 TSStep() at /Users/migmolper/petsc/src/ts/interface/ts.c:3391
> [3]PETSC ERROR: #11 TSSolve() at /Users/migmolper/petsc/src/ts/interface/ts.c:4037
> [4]PETSC ERROR: #6 SNESSolve_NEWTONLS() at /Users/migmolper/petsc/src/snes/impls/ls/ls.c:234
> [4]PETSC ERROR: #7 SNESSolve() at /Users/migmolper/petsc/src/snes/interface/snes.c:4738
> [4]PETSC ERROR: #8 TSTheta_SNESSolve() at /Users/migmolper/petsc/src/ts/impls/implicit/theta/theta.c:174
> [4]PETSC ERROR: #9 TSStep_Theta() at /Users/migmolper/petsc/src/ts/impls/implicit/theta/theta.c:225
> [4]PETSC ERROR: #10 TSStep() at /Users/migmolper/petsc/src/ts/interface/ts.c:3391
> [4]PETSC ERROR: #11 TSSolve() at /Users/migmolper/petsc/src/ts/interface/ts.c:4037
> [5]PETSC ERROR: #7 SNESSolve() at /Users/migmolper/petsc/src/snes/interface/snes.c:4738
> [5]PETSC ERROR: #8 TSTheta_SNESSolve() at /Users/migmolper/petsc/src/ts/impls/implicit/theta/theta.c:174
> [5]PETSC ERROR: #9 TSStep_Theta() at /Users/migmolper/petsc/src/ts/impls/implicit/theta/theta.c:225
> [5]PETSC ERROR: #10 TSStep() at /Users/migmolper/petsc/src/ts/interface/ts.c:3391
> [5]PETSC ERROR: #11 TSSolve() at /Users/migmolper/petsc/src/ts/interface/ts.c:4037
> [6]PETSC ERROR: #6 SNESSolve_NEWTONLS() at /Users/migmolper/petsc/src/snes/impls/ls/ls.c:234
> [6]PETSC ERROR: #7 SNESSolve() at /Users/migmolper/petsc/src/snes/interface/snes.c:4738
> [6]PETSC ERROR: #8 TSTheta_SNESSolve() at /Users/migmolper/petsc/src/ts/impls/implicit/theta/theta.c:174
> [6]PETSC ERROR: #9 TSStep_Theta() at /Users/migmolper/petsc/src/ts/impls/implicit/theta/theta.c:225
> [6]PETSC ERROR: #10 TSStep() at /Users/migmolper/petsc/src/ts/interface/ts.c:3391
> [6]PETSC ERROR: #11 TSSolve() at /Users/migmolper/petsc/src/ts/interface/ts.c:4037
> [7]PETSC ERROR: #5 SNESLineSearchApply() at /Users/migmolper/petsc/src/snes/linesearch/interface/linesearch.c:645
> [7]PETSC ERROR: #6 SNESSolve_NEWTONLS() at /Users/migmolper/petsc/src/snes/impls/ls/ls.c:234
> [7]PETSC ERROR: #7 SNESSolve() at /Users/migmolper/petsc/src/snes/interface/snes.c:4738
> [7]PETSC ERROR: #8 TSTheta_SNESSolve() at /Users/migmolper/petsc/src/ts/impls/implicit/theta/theta.c:174
> [7]PETSC ERROR: #9 TSStep_Theta() at /Users/migmolper/petsc/src/ts/impls/implicit/theta/theta.c:225
> [7]PETSC ERROR: #10 TSStep() at /Users/migmolper/petsc/src/ts/interface/ts.c:3391
> [7]PETSC ERROR: #11 TSSolve() at /Users/migmolper/petsc/src/ts/interface/ts.c:4037
> [0]PETSC ERROR: #9 TSStep_Theta() at /Users/migmolper/petsc/src/ts/impls/implicit/theta/theta.c:225
> [0]PETSC ERROR: #10 TSStep() at /Users/migmolper/petsc/src/ts/interface/ts.c:3391
> [0]PETSC ERROR: #11 TSSolve() at /Users/migmolper/petsc/src/ts/interface/ts.c:4037
> [0]PETSC ERROR: #12 Mass_Transport_Master_Equation_PETSc() at /Users/migmolper/DMD/SOLERA/Chemical-eqs/Mass-Transport-PETSc.cpp:251
> [2]PETSC ERROR: #12 Mass_Transport_Master_Equation_PETSc() at /Users/migmolper/DMD/SOLERA/Chemical-eqs/Mass-Transport-PETSc.cpp:251
> [3]PETSC ERROR: #12 Mass_Transport_Master_Equation_PETSc() at /Users/migmolper/DMD/SOLERA/Chemical-eqs/Mass-Transport-PETSc.cpp:251
> [1]PETSC ERROR: #12 Mass_Transport_Master_Equation_PETSc() at /Users/migmolper/DMD/SOLERA/Chemical-eqs/Mass-Transport-PETSc.cpp:251
> [4]PETSC ERROR: #12 Mass_Transport_Master_Equation_PETSc() at /Users/migmolper/DMD/SOLERA/Chemical-eqs/Mass-Transport-PETSc.cpp:251
> [5]PETSC ERROR: #12 Mass_Transport_Master_Equation_PETSc() at /Users/migmolper/DMD/SOLERA/Chemical-eqs/Mass-Transport-PETSc.cpp:251
> [6]PETSC ERROR: #12 Mass_Transport_Master_Equation_PETSc() at /Users/migmolper/DMD/SOLERA/Chemical-eqs/Mass-Transport-PETSc.cpp:251
> [7]PETSC ERROR: #12 Mass_Transport_Master_Equation_PETSc() at /Users/migmolper/DMD/SOLERA/Chemical-eqs/Mass-Transport-PETSc.cpp:251
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240624/884ed4d0/attachment-0001.html>
