[petsc-users] [petsc-maint] Assistance Needed with PETSc KSPSolve Performance Issue
Junchao Zhang junchao.zhang at gmail.com
Sat Jun 22 08:40:04 CDT 2024
No,  you don't.  It is strange.  Perhaps you can you run a petsc example
first and see if MKL is really used
$ cd src/mat/tests
$ make ex1
$ MKL_VERBOSE=1 ./ex1
--Junchao Zhang
On Fri, Jun 21, 2024 at 4:03 PM Yongzhong Li <yongzhong.li at mail.utoronto.ca>
wrote:
> I am using
> export MKL_VERBOSE=1
> ./xx
> in the bash file, do I have to use - ksp_converged_reason?
> Thanks,
> Yongzhong
> *From: *Pierre Jolivet <pierre at joliv.et>
> *Date: *Friday, June 21, 2024 at 1:47 PM
> *To: *Yongzhong Li <yongzhong.li at mail.utoronto.ca>
> *Cc: *Junchao Zhang <junchao.zhang at gmail.com>, petsc-users at mcs.anl.gov <
> petsc-users at mcs.anl.gov>
> *Subject: *Re: [petsc-users] [petsc-maint] Assistance Needed with PETSc
> 你通常不会收到来自 pierre at joliv.et 的电子邮件。了解这一点为什么很重要
> <https://urldefense.us/v3/__https://aka.ms/LearnAboutSenderIdentification__;!!G_uCfscf7eWS!YIK0ThSYBvsQIwQn1nK19oKLIjhdsMJjFBn4TKBPWX9MdHPawEkV_Ol4-JrQi4VGPFKXs18XY44nNUBQDDP5XKUuInIR$ >
> How do you set the variable?
> $ MKL_VERBOSE=1 ./ex1 -ksp_converged_reason
> MKL_VERBOSE oneMKL 2024.0 Update 1 Product build 20240215 for Intel(R) 64
> architecture Intel(R) Advanced Vector Extensions 2 (Intel(R) AVX2) enabled
> processors, Lnx 2.80GHz lp64 intel_thread
> MKL_VERBOSE DDOT(10,0x22127c0,1,0x22127c0,1) 2.02ms CNR:OFF Dyn:1 FastMM:1
> TID:0  NThr:1
> MKL_VERBOSE DSCAL(10,0x7ffc9fb4ff08,0x22127c0,1) 12.67us CNR:OFF Dyn:1
> FastMM:1 TID:0  NThr:1
> MKL_VERBOSE DDOT(10,0x22127c0,1,0x2212840,1) 1.52us CNR:OFF Dyn:1 FastMM:1
> TID:0  NThr:1
> MKL_VERBOSE DDOT(10,0x2212840,1,0x2212840,1) 167ns CNR:OFF Dyn:1 FastMM:1
> TID:0  NThr:1
> On 21 Jun 2024, at 7:37 PM, Yongzhong Li <yongzhong.li at mail.utoronto.ca>
> wrote:
> This Message Is From an External Sender
> This message came from outside your organization.
> Hello all,
> I set MKL_VERBOSE = 1, but observed no print output specific to the use of
> MKL. Does PETSc enable this verbose output?
> Best,
> Yongzhong
> *Date: *Friday, June 21, 2024 at 1:36 AM
> *To: *Junchao Zhang <junchao.zhang at gmail.com>
> *Cc: *Yongzhong Li <yongzhong.li at mail.utoronto.ca>,
> petsc-users at mcs.anl.gov <petsc-users at mcs.anl.gov>
> <https://urldefense.us/v3/__https://aka.ms/LearnAboutSenderIdentification__;!!G_uCfscf7eWS!eXBeeIXo9Yqgp2nypqwKYimLnGBZXnF4dXxgLM1UoOIO6n8nt3XlfgjVWLPWJh4UOa5NNpx-nrJb_H828XRQKUREfR2m69oCbxI$>
> On 21 Jun 2024, at 6:42 AM, Junchao Zhang <junchao.zhang at gmail.com> wrote:
> I remember there are some MKL env vars to print MKL routines called.
> The environment variable is MKL_VERBOSE
> Thanks,
> Pierre
> Maybe we can try it to see what MKL routines are really used and then we
> can understand why some petsc functions did not speed up
> --Junchao Zhang
> On Thu, Jun 20, 2024 at 10:39 PM Yongzhong Li <
> yongzhong.li at mail.utoronto.ca> wrote:
> *This Message Is From an External Sender*
> Hi Barry, sorry for my last results. I didn’t fully understand the stage
> profiling and logging in PETSc, now I only record KSPSolve() stage of my
> program. Some sample codes are as follow,
>                 // Static variable to keep track of the stage counter
>                 static int stageCounter = 1;
>                 // Generate a unique stage name
>                 std::ostringstream oss;
>                 oss << "Stage " << stageCounter << " of Code";
>                 std::string stageName = oss.str();
>                 // Register the stage
>                 PetscLogStage stagenum;
>                 PetscLogStageRegister(stageName.c_str(), &stagenum);
>                 PetscLogStagePush(stagenum);
>                 *KSPSolve(*ksp_ptr, b, x);*
>                 PetscLogStagePop();
>                 stageCounter++;
> I have attached my new logging results, there are 1 main stage and 4 other
> stages where each one is KSPSolve() call.
> To provide some additional backgrounds, if you recall, I have been trying
> to get efficient iterative solution using multithreading. I found out by
> compiling PETSc with Intel MKL library instead of OpenBLAS, I am able to
> perform sparse matrix-vector multiplication faster, I am using
> MATSEQAIJMKL. This makes the shell matrix vector product in each iteration
> scale well with the #of threads. However, I found out the total GMERS solve
> time (~KSPSolve() time) is not scaling well the #of threads.
> From the logging results I learned that when performing KSPSolve(), there
> are some CPU overheads in PCApply() and KSPGMERSOrthog(). I ran my programs
> using different number of threads and plotted the time consumption for
> PCApply() and KSPGMERSOrthog() against #of thread. I found out these two
> operations are not scaling with the threads at all! My results are attached
> as the pdf to give you a clear view.
> My questions is,
> From my understanding, in PCApply, MatSolve() is involved,
> KSPGMERSOrthog() will have many vector operations, so why these two parts
> can’t scale well with the # of threads when the intel MKL library is linked?
> Thank you,
> Yongzhong
> *From: *Barry Smith <bsmith at petsc.dev>
> *Date: *Friday, June 14, 2024 at 11:36 AM
> *Cc: *petsc-users at mcs.anl.gov <petsc-users at mcs.anl.gov>,
> petsc-maint at mcs.anl.gov <petsc-maint at mcs.anl.gov>, Piero Triverio <
> piero.triverio at utoronto.ca>
> *Subject: *Re: [petsc-maint] Assistance Needed with PETSc KSPSolve
> Performance Issue
>    I am a bit confused. Without the initial guess computation, there are
> still a bunch of events I don't understand
> MatTranspose          79 1.0 4.0598e+01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
> MatMatMultSym        110 1.0 1.7419e+02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> 0.0e+00  1  0  0  0  0   1  0  0  0  0     0
> MatMatMultNum         90 1.0 1.2640e+02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> MatMatMatMultSym      20 1.0 1.3049e+02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> MatRARtSym            25 1.0 1.2492e+02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> MatMatTrnMultSym      25 1.0 8.8265e+01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> MatMatTrnMultNum      25 1.0 2.4820e+02 1.0 6.83e+10 1.0 0.0e+00 0.0e+00
> 0.0e+00  1  0  0  0  0   1  0  0  0  0   275
> MatTrnMatMultSym      10 1.0 7.2984e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> MatTrnMatMultNum      10 1.0 9.3128e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> in addition there are many more VecMAXPY then VecMDot (in GMRES they are
> each done the same number of times)
> VecMDot             5588 1.0 1.7183e+03 1.0 2.06e+13 1.0 0.0e+00 0.0e+00
> 0.0e+00  8 10  0  0  0   8 10  0  0  0 12016
> VecMAXPY           22412 1.0 8.4898e+03 1.0 4.17e+13 1.0 0.0e+00 0.0e+00
> 0.0e+00 39 20  0  0  0  39 20  0  0  0  4913
> Finally there are a huge number of
> MatMultAdd        258048 1.0 1.4178e+03 1.0 6.10e+13 1.0 0.0e+00 0.0e+00
> 0.0e+00  7 29  0  0  0   7 29  0  0  0 43025
> Are you making calls to all these routines? Are you doing this inside your
> MatMult() or before you call KSPSolve?
> The reason I wanted you to make a simpler run without the initial guess
> code is that your events are far more complicated than would be produced by
> GMRES alone so it is not possible to understand the behavior you are seeing
> without fully understanding all the events happening in the code.
>   Barry
> On Jun 14, 2024, at 1:19 AM, Yongzhong Li <yongzhong.li at mail.utoronto.ca>
> wrote:
> Thanks, I have attached the results without using any KSPGuess. At low
> frequency, the iteration steps are quite close to the one with KSPGuess,
> specifically
>   KSPGuess Object: 1 MPI process
>     type: fischer
>     Model 1, size 200
> However, I found at higher frequency, the # of iteration steps are
>  significant higher than the one with KSPGuess, I have attahced both of the
> results for your reference.
> Moreover, could I ask why the one without the KSPGuess options can be used
> for a baseline comparsion? What are we comparing here? How does it relate
> to the performance issue/bottleneck I found? “*I have noticed that the
> time taken by **KSPSolve** is **almost two times **greater than the CPU
> time for matrix-vector product multiplied by the number of iteration*”
> Thank you!
> Yongzhong
> *Date: *Thursday, June 13, 2024 at 2:14 PM
> Performance Issue
>   Can you please run the same thing without the  KSPGuess option(s) for a
> baseline comparison?
>    Thanks
>    Barry
> On Jun 13, 2024, at 1:27 PM, Yongzhong Li <yongzhong.li at mail.utoronto.ca>
> Hi Matt,
> I have rerun the program with the keys you provided. The system output
> when performing ksp solve and the final petsc log output were stored in a
> .txt file attached for your reference.
> Thanks!
> Yongzhong
> *From: *Matthew Knepley <knepley at gmail.com>
> *Date: *Wednesday, June 12, 2024 at 6:46 PM
> Performance Issue
> 你通常不会收到来自 knepley at gmail.com 的电子邮件。了解这一点为什么很重要
> <https://urldefense.us/v3/__https://aka.ms/LearnAboutSenderIdentification__;!!G_uCfscf7eWS!djGfJnEhNJROfsMsBJy5u_KoRKbug55xZ64oHKUFnH2cWku_Th1hwt4TDdoMd8pWYVDzJeqJslMNZwpO3y0Et94d31qk-oCEwo4$>
> On Wed, Jun 12, 2024 at 6:36 PM Yongzhong Li <
> Dear PETSc’s developers, I hope this email finds you well. I am currently
> working on a project using PETSc and have encountered a performance issue
> with the KSPSolve function. Specifically, I have noticed that the time
> taken by KSPSolve is
> ZjQcmQRYFpfptBannerStart
> ZjQcmQRYFpfptBannerEnd
> I am currently working on a project using PETSc and have encountered a
> performance issue with the KSPSolve function. Specifically, *I have
> noticed that the time taken by **KSPSolve** is **almost two times **greater
> than the CPU time for matrix-vector product multiplied by the number of
> iteration steps*. I use C++ chrono to record CPU time.
> For context, I am using a shell system matrix A. Despite my efforts to
> parallelize the matrix-vector product (Ax), the overall solve time
> remains higher than the matrix vector product per iteration indicates
> when multiple threads were used. Here are a few details of my setup:
>    - *Matrix Type*: Shell system matrix
>    - *Preconditioner*: Shell PC
>    - *Parallel Environment*: Using Intel MKL as PETSc’s BLAS/LAPACK
>    library, multithreading is enabled
> I have considered several potential reasons, such as preconditioner setup,
> additional solver operations, and the inherent overhead of using a shell
> system matrix. *However, since KSPSolve is a high-level API, I have been
> unable to pinpoint the exact cause of the increased solve time.*
> Have you observed the same issue? Could you please provide some experience
>  on how to diagnose and address this performance discrepancy? Any
> insights or recommendations you could offer would be greatly appreciated.
> For any performance question like this, we need to see the output of your
> code run with
>   -ksp_view -ksp_monitor_true_residual -ksp_converged_reason -log_view
>   Thanks,
>      Matt
> Thank you for your time and assistance.
> Best regards,
> Yongzhong
> *Yongzhong Li*
> PhD student | Electromagnetics Group
> Department of Electrical & Computer Engineering
> University of Toronto
> https://urldefense.us/v3/__http://www.modelics.org__;!!G_uCfscf7eWS!YIK0ThSYBvsQIwQn1nK19oKLIjhdsMJjFBn4TKBPWX9MdHPawEkV_Ol4-JrQi4VGPFKXs18XY44nNUBQDDP5XLnDSypz$
> <https://urldefense.us/v3/__http://www.modelics.org__;!!G_uCfscf7eWS!cuLttMJEcegaqu461Bt4QLsO4fASfLM5vjRbtyNhWJQiInbjgNwkGNdkFE1ebSbFjOUatYB0-jd2yQWMWzqkDFFjwMvNl3ZKAr8$>
> experiments lead.
> -- Norbert Wiener
> https://urldefense.us/v3/__https://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!YIK0ThSYBvsQIwQn1nK19oKLIjhdsMJjFBn4TKBPWX9MdHPawEkV_Ol4-JrQi4VGPFKXs18XY44nNUBQDDP5XEgU8ZBa$
> <https://urldefense.us/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!djGfJnEhNJROfsMsBJy5u_KoRKbug55xZ64oHKUFnH2cWku_Th1hwt4TDdoMd8pWYVDzJeqJslMNZwpO3y0Et94d31qkNOuenGA$>
> <ksp_petsc_log.txt>
> <ksp_petsc_log.txt><ksp_petsc_log_noguess.txt>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240622/abbd5e46/attachment-0001.html>
