[petsc-users] [EXTERNAL] Re: Running PETSc with a Kokkos backend on OLCF Frontier
Stefano Zampini stefano.zampini at gmail.com
Fri Jun 14 15:06:16 CDT 2024
These options are prefixed by the equation name, and it won't work. You
should add the option via the environment variable
 PETSC_OPTIONS="-log_view"
On Fri, Jun 14, 2024, 23:01 Barry Smith <bsmith at petsc.dev> wrote:
> Are you using https: //develop. openfoam. com/modules/external-solver If
> so you might be able to add it like petsc { options { log_view; ksp_type
> cg; pc_type bjacobi; sub_pc_type icc; } as discussed on the webpage for
> setting PETSc solver optionsOn
> ZjQcmQRYFpfptBannerStart
> This Message Is From an External Sender
> This message came from outside your organization.
> ZjQcmQRYFpfptBannerEnd
>   Are you using https://urldefense.us/v3/__https://develop.openfoam.com/modules/external-solver__;!!G_uCfscf7eWS!avqfqzhEZD_pucu7YsUcVV0ZJNb6Gaq5y7vItF1Yx2FXvC9s_R6nGKhtj1kvYWaVbBa2sHt5_Sm99fJknpUa2ErVWHwP6nE$
> <https://urldefense.us/v3/__https://develop.openfoam.com/modules/external-solver__;!!G_uCfscf7eWS!YgXDdUKnfJdPEbKAQzR8TYlQzciWTcMmU_6jrKexdBB6UajcOHUvJhfaBjBtMN2cX6EUFDrcF4LcFItaSLxbAb0$>
> If so you might be able to add it like
> petsc
>             options
>                 log_view;
>                 ksp_type    cg;
>                 pc_type     bjacobi;
>                 sub_pc_type icc;
> as discussed on the webpage for setting PETSc solver options
> On Jun 14, 2024, at 3:44 PM, Sircar, Arpan <sircara at ornl.gov> wrote:
> Hi Junchao and Barry,
> I tried adding -log_view to my OpenFOAM command since that is what I am
> running the entire package through. However, it does not recognize that as
> a valid option. I am not sure where to put that tag in this setup.
> I am however using a Kokkos profiling tool, the output of which (for the
> GPU run) is attached with this email. Do let me know if this is useful or
> if you have ideas of where to put the -log_view tag.
> Junchao - Great nice running into you here.
> Thanks,
> Arpan
> *From:* Junchao Zhang <junchao.zhang at gmail.com>
> *Sent:* Friday, June 14, 2024 3:16 PM
> *To:* Sircar, Arpan <sircara at ornl.gov>
> *Cc:* Barry Smith <bsmith at petsc.dev>; petsc-users at mcs.anl.gov <
> petsc-users at mcs.anl.gov>; Gottiparthi, Kalyan <gottiparthik at ornl.gov>
> *Subject:* Re: [petsc-users] [EXTERNAL] Re: Running PETSc with a Kokkos
> Arpan,
>    Did you add -log_view ?
> --Junchao Zhang
> On Fri, Jun 14, 2024 at 2:00 PM Sircar, Arpan via petsc-users <
> Hi Barry,
> Thanks for your prompt response. These are run with with the same PETSc
> solvers but the one on GPUs (log_pKok) uses mataijkokkos while the other
> one does not.
> Please let me know if you need any other information.
> Thanks,
> Arpan
> *From:* Barry Smith <bsmith at petsc.dev>
> *Sent:* Friday, June 14, 2024 1:47 PM
> *Cc:* petsc-users at mcs.anl.gov <petsc-users at mcs.anl.gov>; Gottiparthi,
> *Subject:* [EXTERNAL] Re: [petsc-users] Running PETSc with a Kokkos
>    Please run both the CPU solvers and GPU solvers cases with -log_view
> and send the two outputs.
>    Barry
> On Jun 14, 2024, at 1:35 PM, Sircar, Arpan via petsc-users <
> Hi,
> We have been working with OpenFOAM (an open-source CFD software) which can
> transfer its matrices to PETSc to use its linear solvers. This has been
> tested and is working well on OCLF's Frontier machine. Next we are trying
> to use the Kokkos backend to run it on Frontier GPUs. While the
> OpenFOAM+PETSc+Kokkos environment built correctly on Frontier using the
> modules sourced (attached file *bash_petsc4foam_gpu*) and configuring
> PETSc correctly (attached file *config_gpu*), the GPU solve seems to take
> more time than the CPU solve.
> The PETSc run-time options we are using are attached to this email (file
> *fvSolution_petsc_pKok_Uof*). Could you please take a look  and let us
> know if this combination of options is fine? In this approach we are trying
> to solve the pressure equation only on the GPUs.
> Thanks,
> Arpan
> *Arpan Sircar*
> R&D Associate Staff
> Thermal Hydraulics Group
> Nuclear Energy and Fuel Cycle Division
> *Oak Ridge National Laboratory*
> <fvSolution_petsc_pKok_Uof><bash_petsc4foam_gpu><config_gpu>
> <log.kok>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240614/4886b605/attachment-0001.html>
