[petsc-users] Running PETSc with a Kokkos backend on OLCF Frontier
Sircar, Arpan
sircara at ornl.gov
Fri Jun 14 12:35:14 CDT 2024
We have been working with OpenFOAM (an open-source CFD software) which can transfer its matrices to PETSc to use its linear solvers. This has been tested and is working well on OCLF's Frontier machine. Next we are trying to use the Kokkos backend to run it on Frontier GPUs. While the OpenFOAM+PETSc+Kokkos environment built correctly on Frontier using the modules sourced (attached file bash_petsc4foam_gpu) and configuring PETSc correctly (attached file config_gpu), the GPU solve seems to take more time than the CPU solve.
The PETSc run-time options we are using are attached to this email (file fvSolution_petsc_pKok_Uof). Could you please take a look and let us know if this combination of options is fine? In this approach we are trying to solve the pressure equation only on the GPUs.
Arpan
Arpan Sircar
R&D Associate Staff
Thermal Hydraulics Group
Nuclear Energy and Fuel Cycle Division
Oak Ridge National Laboratory
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240614/29fada4d/attachment.html>
Desc: fvSolution_petsc_pKok_Uof
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240614/29fada4d/attachment.obj>
Desc: bash_petsc4foam_gpu
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240614/29fada4d/attachment-0001.obj>
Desc: config_gpu
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240614/29fada4d/attachment-0002.obj>
