[petsc-users] Petsc Build error
Barry Smith
bsmith at petsc.dev
Thu Jun 13 17:47:13 CDT 2024
Please send configure.log and make.log to petsc-maint at mcs.anl.gov without the exact details we cannot determine what has gone wrong.
> On Jun 13, 2024, at 6:33 PM, s.pradeep kumar <spradeepmahadeek at gmail.com> wrote:
> This Message Is From an External Sender
> This message came from outside your organization.
> Dear Petsc Development Team,
> I am encountering an issue while trying to build Petsc library in our Cray Cluster. Despite loading appropriate gcc and cray-mpich modules and successfully configuring Petsc, I receive the following error (see A1). I have also attached petsc configure statement (see A2) and snippet of configure log (see A3).
> Could you please provide assistance in resolving this build issue? Any insights or additional steps I might take to diagnose and fix the problem would be greatly appreciated.
> Thank you for your support
> Regards,
> Pradeep
> A1.Error from make.log:
> /usr/bin/gmake --print-directory -f gmakefile -j88 -l272.0 --output-sync=recurse V= libs
> gmake[3]: *** No rule to make target '/$NETWORK$/users/$USERNAME$/NumLib/petsc-3.21.1/src/sys/f90-mod/petscsysmod.F90', needed by 'gnu-opt/obj/src/sys/f90-mod/petscsysmod.o'. Stop.
> gmake[2]: *** [/users/$USERNAME$/NumLib/petsc-3.21.1/lib/petsc/conf/rules_doc.mk:5 <https://urldefense.us/v3/__http://rules_doc.mk:5__;!!G_uCfscf7eWS!bzt6Ug_Q99IAVZ3YC6uReptvtUbsmvjz5BTANuRoXR9Ap8p-lmK9vgI05Bc1978HvYN2t63u7h4OQCvKWLfZ2bAtjgAjZzjQ$>: libs] Error 2
> **************************ERROR*************************************
> Error during compile, check gnu-opt/lib/petsc/conf/make.log
> Send it and gnu-opt/lib/petsc/conf/configure.log to petsc-maint at mcs.anl.gov <mailto:petsc-maint at mcs.anl.gov>
> Finishing make run at Thu, 13 Jun 2024 11:42:44 -0600
> A2.Configure Statement:
> ./configure --with-scalar-type=real --with-precision=double --download-metis=$metis_path --download-metis-use-doubleprecision=1 --download-parmetis=$parmetis_path --with-cmake=1 --with-mpi-dir=$MPI_DIR --download-fblaslapack=$fblaslapack_path --with-debugging=0 COPTFLAGS=-O2 FOPTFLAGS=-O2
> Where the paths are defined:
> fblaslapack_path="/users/$USERNAME$/NumLib/ExternalPackages/petsc-pkg-fblaslapack-e8a03f57d64c.tar.gz"
> metis_path="/users/$USERNAME$/NumLib/ExternalPackages/petsc-pkg-metis-69fb26dd0428.tar.gz"
> parmetis_path="/users/$USERNAME$/NumLib/ExternalPackages/petsc-pkg-parmetis-f5e3aab04fd5.tar.gz"
> MPI_DIR=${CRAY_MPICH_PREFIX}
> A3. Snippets From configure.log:
> PETSc:
> Build : Set default architecture to gnu-opt in lib/petsc/conf/petscvariables
> File creation : Created gnu-opt/lib/petsc/conf/reconfigure-gnu-opt.py for automatic reconfiguration
> Framework:
> RDict update : Substitutions were stored in RDict with parent None
> File creation : Created makefile configure header gnu-opt/lib/petsc/conf/petscvariables
> File creation : Created makefile configure header gnu-opt/lib/petsc/conf/petscrules
> File creation : Created configure header gnu-opt/include/petscconf.h
> File creation : Created C specific configure header gnu-opt/include/petscfix.h
> File creation : Created configure pkg header gnu-opt/include/petscpkg_version.h
> Compilers:
> C Compiler: /opt/cray/pe/mpich/8.1.28/ofi/gnu/12.3/bin/mpicc -fPIC -Wall -Wwrite-strings -Wno-unknown-pragmas -Wno-lto-type-mismatch -Wno-stringop-overflow -fstack-protector -fvisibility=hidden -O2
> Version: gcc (GCC) 12.2.0 20220819 (HPE)
> C++ Compiler: /opt/cray/pe/mpich/8.1.28/ofi/gnu/12.3/bin/mpicxx -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -Wno-lto-type-mismatch -Wno-psabi -fstack-protector -fvisibility=hidden -g -O -std=gnu++20 -fPIC
> Version: g++ (GCC) 12.2.0 20220819 (HPE)
> Fortran Compiler: /opt/cray/pe/mpich/8.1.28/ofi/gnu/12.3/bin/mpif90 -fPIC -Wall -ffree-line-length-none -ffree-line-length-0 -Wno-lto-type-mismatch -Wno-unused-dummy-argument -O2
> Version: GNU Fortran (GCC) 12.2.0 20220819 (HPE)
> Linkers:
> Shared linker: /opt/cray/pe/mpich/8.1.28/ofi/gnu/12.3/bin/mpicc -shared -fPIC -Wall -Wwrite-strings -Wno-unknown-pragmas -Wno-lto-type-mismatch -Wno-stringop-overflow -fstack-protector -fvisibility=hidden -O2
> Dynamic linker: /opt/cray/pe/mpich/8.1.28/ofi/gnu/12.3/bin/mpicc -shared -fPIC -Wall -Wwrite-strings -Wno-unknown-pragmas -Wno-lto-type-mismatch -Wno-stringop-overflow -fstack-protector -fvisibility=hidden -O2
> Libraries linked against: -lquadmath -ldl
> BlasLapack:
> Libraries: -Wl,-rpath,/users/$USERNAME$/NumLib/petsc-3.21.1/gnu-opt/lib -L/users/$USERNAME$ /NumLib/petsc-3.21.1/gnu-opt/lib -lflapack -lfblas
> uses 4 byte integers
> MPI:
> Version: 3
> Includes: -I/opt/cray/pe/mpich/8.1.28/ofi/gnu/12.3/include
> mpiexec: /bin/false
> Implementation: mpich3
> MPICH_NUMVERSION: 30400002
> X:
> Libraries: -lX11
> python:
> Executable: /usr/bin/python3
> pthread:
> Libraries: -lpthread
> cmake:
> Version: 3.23.1
> Executable: /usr/projects/hpcsoft/tce/23-03/cray-sles15-x86_64_v3-slingshot-none/packages/cmake/cmake-3.23.1/bin/cmake
> fblaslapack:
> metis:
> Version: 5.1.0
> Includes: -I/users/$USERNAME$/NumLib/petsc-3.21.1/gnu-opt/include
> Libraries: -Wl,-rpath,/users/$USERNAME$/NumLib/petsc-3.21.1/gnu-opt/lib -L/users/$USERNAME$/NumLib/petsc-3.21.1/gnu-opt/lib -lmetis
> parmetis:
> Version: 4.0.3
> Libraries: -Wl,-rpath,/users/$USERNAME$/NumLib/petsc-3.21.1/gnu-opt/lib -L/users/$USERNAME$/NumLib/petsc-3.21.1/gnu-opt/lib -lparmetis
> regex:
> bison:
> Version: 3.0
> Executable: /usr/bin/bison
> PETSc:
> Language used to compile PETSc: C
> PETSC_ARCH: gnu-opt
> PETSC_DIR: /users/$USERNAME$/NumLib/petsc-3.21.1
> Prefix: <inplace installation>
> Scalar type: real
> Precision: double
> Support for __float128
> Integer size: 4 bytes
> Single library: yes
> Shared libraries: yes
> Memory alignment from malloc(): 16 bytes
> Using GNU make: /usr/bin/gmake
> xxx=======================================================================================xxx
> Configure stage complete. Now build PETSc libraries with:
> make PETSC_DIR=/users/$USERNAME$/NumLib/petsc-3.21.1 PETSC_ARCH=gnu-opt all
> Finishing configure run at Thu, 13 Jun 2024 11:42:35 -0600
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240613/07ff15ce/attachment-0001.html>
