[petsc-users] [petsc-maint] Assistance Needed with PETSc KSPSolve Performance Issue
Wed Jun 12 17:46:14 CDT 2024
On Wed, Jun 12, 2024 at 6:36 PM Yongzhong Li <yongzhong.li at mail.utoronto.ca>
wrote:
> Dear PETSc’s developers, I hope this email finds you well. I am currently
> working on a project using PETSc and have encountered a performance issue
> with the KSPSolve function. Specifically, I have noticed that the time
> taken by KSPSolve is
> ZjQcmQRYFpfptBannerStart
> This Message Is From an External Sender
> This message came from outside your organization.
> ZjQcmQRYFpfptBannerEnd
> I am currently working on a project using PETSc and have encountered a
> performance issue with the KSPSolve function. Specifically, *I have
> noticed that the time taken by **KSPSolve** is **almost two times **greater
> than the CPU time for matrix-vector product multiplied by the number of
> iteration steps*. I use C++ chrono to record CPU time.
> For context, I am using a shell system matrix A. Despite my efforts to
> parallelize the matrix-vector product (Ax), the overall solve time
> remains higher than the matrix vector product per iteration indicates
> when multiple threads were used. Here are a few details of my setup:
>    - *Matrix Type*: Shell system matrix
>    - *Preconditioner*: Shell PC
>    - *Parallel Environment*: Using Intel MKL as PETSc’s BLAS/LAPACK
>    library, multithreading is enabled
> I have considered several potential reasons, such as preconditioner setup,
> additional solver operations, and the inherent overhead of using a shell
> system matrix. *However, since KSPSolve is a high-level API, I have been
> unable to pinpoint the exact cause of the increased solve time.*
> Have you observed the same issue? Could you please provide some experience
> on how to diagnose and address this performance discrepancy? Any insights
> or recommendations you could offer would be greatly appreciated.
For any performance question like this, we need to see the output of your
code run with
  -ksp_view -ksp_monitor_true_residual -ksp_converged_reason -log_view
     Matt
> Thank you for your time and assistance.
> Best regards,
> Yongzhong
> *Yongzhong Li*
> PhD student | Electromagnetics Group
> Department of Electrical & Computer Engineering
> University of Toronto
> https://urldefense.us/v3/__http://www.modelics.org__;!!G_uCfscf7eWS!eMuXWvayLIhrQweHZY95IfQMST6PiUiLEskCz9WUy0pb9bazMdyoLiAyZh_l80blSuxXwO5yN7vzdEzWkCL8$
> <https://urldefense.us/v3/__http://www.modelics.org__;!!G_uCfscf7eWS!cuLttMJEcegaqu461Bt4QLsO4fASfLM5vjRbtyNhWJQiInbjgNwkGNdkFE1ebSbFjOUatYB0-jd2yQWMWzqkDFFjwMvNl3ZKAr8$>
experiments lead.
-- Norbert Wiener
https://urldefense.us/v3/__https://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!eMuXWvayLIhrQweHZY95IfQMST6PiUiLEskCz9WUy0pb9bazMdyoLiAyZh_l80blSuxXwO5yN7vzdEsBefqt$  <https://urldefense.us/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!eMuXWvayLIhrQweHZY95IfQMST6PiUiLEskCz9WUy0pb9bazMdyoLiAyZh_l80blSuxXwO5yN7vzdFPL_avf$ >
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240612/480358ad/attachment-0001.html>
