[petsc-users] About the complex version of gmres.
Barry Smith
bsmith at petsc.dev
Fri Jun 7 21:56:48 CDT 2024
I used src/ksp/ksp/tutorials/ex10.c and saved the A and b into a PETSc binary file from Matlab with PetscBinaryWrite() in PETSC_DIR/share/petsc/matlab
> On Jun 7, 2024, at 10:53 PM, neil liu <liufield at gmail.com> wrote:
> Thanks a lot for your explanation.
> Could you please share your petsc code to test this ?
> Thanks,
> Xiaodong
> On Fri, Jun 7, 2024 at 10:12 PM Barry Smith <bsmith at petsc.dev <mailto:bsmith at petsc.dev>> wrote:
>> If I run with -pc_type lu it solves the system
>> If I run with the default (ILU) -ksp_monitor_true_residual -ksp_converged_reason it does not converge. In fact, it makes no real progress to the solution.
>> It is always important to use KSPGetConvergedReason() or -ksp_converged_reason or -ksp_error_if_not_converged to check that the solver has actually converged.
>> If I run with -ksp_gmres_restart 100 it converges in 75 iterations.
>> Barry
>>> On Jun 7, 2024, at 8:03 PM, neil liu <liufield at gmail.com <mailto:liufield at gmail.com>> wrote:
>>> This Message Is From an External Sender
>>> This message came from outside your organization.
>>> Dear Petsc developers,
>>> I am using Petsc to solve a complex system ,AX=B.
>>> A is complex and B is real.
>>> And the petsc was configured with
>>> Configure options --download-mpich --download-fblaslapack=1 --with-cc=gcc --with-cxx=g++ --with-fc=gfortran --download-triangle --with-scalar-type=complex
>>> A and B were also imported to matlab and the same system was solved.
>>> The direct and iterative solver in matlab give the same result, which are quite different from the result from Petsc.
>>> A and B are attached. x from petsc is also attached. I am using only one processor.
>>> It is weird.
>>> Thanks a lot.
>>> Xiaodong
>>> <A.m><xPetsc.m><B.m>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240607/82b17513/attachment-0001.html>
