[petsc-users] matload and petsc4py
Stefano Zampini
stefano.zampini at gmail.com
Thu Jun 6 08:01:12 CDT 2024
On Thu, Jun 6, 2024, 14:53 Klaij, Christiaan <C.Klaij at marin.nl> wrote:
> I'm writing a matrix to file from my fortran code (that uses petsc-3. 19.
> 4) with -mat_view binary. Then, I'm trying to load this mat into python
> (that uses petsc-3. 21. 0). This works fine using single or multiple procs
> when the marix
> ZjQcmQRYFpfptBannerStart
> This Message Is From an External Sender
> This message came from outside your organization.
> ZjQcmQRYFpfptBannerEnd
> I'm writing a matrix to file from my fortran code (that uses petsc-3.19.4)
> with -mat_view binary. Then, I'm trying to load this mat into python (that
> uses petsc-3.21.0). This works fine using single or multiple procs when the
> marix was written using a single proc (attached file a_mat_np_1.dat).
> However, when the matrix was written using mulitple procs (attached file
> a_mat_n_2.dat) I get the error below. Is this supposed to work? If so, what
> I'm I doing wrong?
This should work. And your script seems ok too . How did you save the
matrix in parallel? I suspect that file is corrupt
> $ cat test_matrixImport_binary.py
> import sys
> import petsc4py
> from petsc4py import PETSc
> from mpi4py import MPI
> # mat files
> #filename = "./a_mat_np_1.dat" # Works
> filename = "./a_mat_np_2.dat" # Doesn't work
> # Initialize PETSc
> petsc4py.init(sys.argv)
> # Create a viewer for reading the binary file
> viewer = PETSc.Viewer().createBinary(filename, mode='r',
> comm=PETSc.COMM_WORLD)
> # Create a matrix and load data from the binary file
> A = PETSc.Mat().create(comm=PETSc.COMM_WORLD)
> A.load(viewer)
> $ python test_matrixImport_binary.py
> Traceback (most recent call last):
> File "/projects/P35662.700/test_cklaij/test_matrixImport_binary.py", line
> 18, in <module>
> A.load(viewer)
> File "petsc4py/PETSc/Mat.pyx", line 2025, in petsc4py.PETSc.Mat.load
> petsc4py.PETSc.Error: error code 79
> [0] MatLoad() at /home/cklaij/petsc-3.21.0/src/mat/interface/matrix.c:1344
> [0] MatLoad_SeqAIJ() at
> /home/cklaij/petsc-3.21.0/src/mat/impls/aij/seq/aij.c:5091
> [0] MatLoad_SeqAIJ_Binary() at
> /home/cklaij/petsc-3.21.0/src/mat/impls/aij/seq/aij.c:5142
> [0] Unexpected data in file
> [0] Inconsistent matrix data in file: nonzeros = 460, sum-row-lengths = 761
> $ mpirun -n 2 python test_matrixImport_binary.py
> 18, in <module>
> 18, in <module>
> A.load(viewer)
> A.load(viewer)
> [0] MatLoad_MPIAIJ() at
> /home/cklaij/petsc-3.21.0/src/mat/impls/aij/mpi/mpiaij.c:3035
> [0] MatLoad_MPIAIJ_Binary() at
> /home/cklaij/petsc-3.21.0/src/mat/impls/aij/mpi/mpiaij.c:3087
> [1] MatLoad() at /home/cklaij/petsc-3.21.0/src/mat/interface/matrix.c:1344
> [1] MatLoad_MPIAIJ() at
> [1] MatLoad_MPIAIJ_Binary() at
> [1] Unexpected data in file
> [1] Inconsistent matrix data in file: nonzeros = 460, sum-row-lengths = 761
> dr. ir. Christiaan Klaij
> | Senior Researcher | Research & Development
> T +31 317 49 33 44 <+31%20317%2049%2033%2044> | C.Klaij at marin.nl |
> https://urldefense.us/v3/__http://www.marin.nl__;!!G_uCfscf7eWS!bo30rJrAzGhdWcQwu5TbarbyiLMX1JhUlqvIeOd9MkvOG0knvEGaXfbc0_OWtTDnRlaJwql3m5vwIgprE0TsH2sIh1Prvdg$
> <https://urldefense.us/v3/__https://www.marin.nl/__;!!G_uCfscf7eWS!YrcVeQ6V8OD3jKxSzzxpyuTgFdncWh4YcL1SgDT8NHqystMpzO1pkd17oNGni-ll5I8qH9_ueOtj3WYWBYeP9zg$>
> [image: Facebook]
> <https://urldefense.us/v3/__https://www.facebook.com/marin.wageningen__;!!G_uCfscf7eWS!YrcVeQ6V8OD3jKxSzzxpyuTgFdncWh4YcL1SgDT8NHqystMpzO1pkd17oNGni-ll5I8qH9_ueOtj3WYWzqK6wKw$>
> [image: LinkedIn]
> <https://urldefense.us/v3/__https://www.linkedin.com/company/marin__;!!G_uCfscf7eWS!YrcVeQ6V8OD3jKxSzzxpyuTgFdncWh4YcL1SgDT8NHqystMpzO1pkd17oNGni-ll5I8qH9_ueOtj3WYWIUyfXbM$>
> [image: YouTube]
> <https://urldefense.us/v3/__https://www.youtube.com/marinmultimedia__;!!G_uCfscf7eWS!YrcVeQ6V8OD3jKxSzzxpyuTgFdncWh4YcL1SgDT8NHqystMpzO1pkd17oNGni-ll5I8qH9_ueOtj3WYWjtUkoeg$>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240606/10685a9b/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240606/10685a9b/attachment-0004.png>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240606/10685a9b/attachment-0005.png>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240606/10685a9b/attachment-0006.png>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240606/10685a9b/attachment-0007.png>
