[petsc-users] 2^32 integer problems
Matthew Knepley
knepley at gmail.com
Sun Jun 2 09:30:23 CDT 2024
On Sun, Jun 2, 2024 at 10:27 AM Matthew Knepley <knepley at gmail.com> wrote:
> On Sat, Jun 1, 2024 at 11:39 PM Carpenter, Mark H. (LARC-D302) via
> petsc-users <petsc-users at mcs.anl.gov> wrote:
>> Mark Carpenter, NASA Langley. I am a novice PETSC user of about 10 years.
>> I’ve build a DG-FEM code with petsc as one of the solver paths (I have my
>> own as well). Furthermore, I use petsc for MPI communication. I’m running
>> the DG-FEM
>> ZjQcmQRYFpfptBannerStart
>> This Message Is From an External Sender
>> This message came from outside your organization.
>> ZjQcmQRYFpfptBannerEnd
>> I am a novice PETSC user of about 10 years. I’ve build a DG-FEM code
>> with petsc as one of the solver paths (I have my own as well).
>> I’m running the DG-FEM code on our NAS supercomputer. Everything works
>> when my integer sizes are small. When I exceed the 2^32 limit of integer
>> arithmetic the code fails in very strange ways.
>> The users that originally set up the petsc infrastructure in the code are
>> no longer at NASA and I’m “dead in the water”.
One additional point. I have looked at the error message. When you make
PETSc calls, each call should be wrapped in PetscCall(). Here is a Fortran
example:
https://urldefense.us/v3/__https://gitlab.com/petsc/petsc/-/blob/main/src/ksp/ksp/tutorials/ex22f.F90?ref_type=heads__;!!G_uCfscf7eWS!eOkbaTOpui-YHhrX_HYLmYerXOaaGtlJn04-tdLvQzfRqa6gaCs2x-YtPn7xNTWzRRgD-wze7GkX5hkXqc8i$
This checks the return value after each call and ends early if there is an
error. It would make your
error output much more readable.
Matt
>> I think I’ve promoted all the integers that are problematic in my code
>> (F95). On PETSC side: I’ve tried
>> 1. Reinstall petsc with –with-64-bit-integers (no luck)
> That option does not exist, so this will not work.
>> 1.
>> 2. Reinstall petsc with –with-64-bit-integers and
>> –with-64-bit-indices (code will not compile with these options.
>> Additional variables on F90 side require promotion and then the errors
>> cascade through code when making PETSC calls.
> We should fix this. I feel confident we can get the code to compile.
>> 1.
>> 2. It’s possible that I’ve missed offending integers, but the petsc
>> error messages are so cryptic that I can’t even tell where it is failing.
>> Further complicating matters:
>> The problem by definition needs to be HUGE. Problem sizes requiring 1000
>> cores (10^6 elements at P5) are needed to experience the errors, which
>> involves waiting in queues for ½ day at least.
>> Attached are the
>> 1. Install script used to install PETSC on our machine
>> 2. The Makefile used on the fortran side
>> 3. A data dump from an offending simulation (which is huge and I
>> can’t see any useful information.)
>> How do I attack this problem.
>> (I’ve never gotten debugging working properly).
> Let's get the install for 64-bit indices to work. So we
> 1) Configure PETSc adding --with-64bit-indices to the configure line. Does
> this work? If not, send configure.log
> 2) Compile PETSc. Does this work? If not, send make.log
> 3) Compile your code. Does this work? If not, send all output.
> 4) Do one of the 1/2 day runs and let us know what happens. An alternative
> is to run a small number
> of processes on a large memory workstation. We do this to test at the
> lab.
> Thanks,
> Matt
>> Mark
> experiments lead.
> -- Norbert Wiener
> https://urldefense.us/v3/__https://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!eOkbaTOpui-YHhrX_HYLmYerXOaaGtlJn04-tdLvQzfRqa6gaCs2x-YtPn7xNTWzRRgD-wze7GkX5gB4gnrA$
> <https://urldefense.us/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!eOkbaTOpui-YHhrX_HYLmYerXOaaGtlJn04-tdLvQzfRqa6gaCs2x-YtPn7xNTWzRRgD-wze7GkX5r8KJKDw$ >
experiments lead.
-- Norbert Wiener
https://urldefense.us/v3/__https://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!eOkbaTOpui-YHhrX_HYLmYerXOaaGtlJn04-tdLvQzfRqa6gaCs2x-YtPn7xNTWzRRgD-wze7GkX5gB4gnrA$ <https://urldefense.us/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!eOkbaTOpui-YHhrX_HYLmYerXOaaGtlJn04-tdLvQzfRqa6gaCs2x-YtPn7xNTWzRRgD-wze7GkX5r8KJKDw$ >
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240602/6d4a6fea/attachment-0001.html>
