[petsc-users] Trying to run https://petsc.org/release/src/ksp/ksp/tutorials/ex72.c.html
neil liu
liufield at gmail.com
Wed Jul 31 17:31:30 CDT 2024
Thanks a lot, Berry. It works now.
Very interesting. I will explore what MatSetBlockSize is doing.
Have a good night.
On Wed, Jul 31, 2024 at 6:21 PM Barry Smith <bsmith at petsc.dev> wrote:
> Take a look at src/ksp/ksp/tutorials/ex71.c
> To have your code below not crash at this point call
> MatSetBlockSize(A,2) before MatSetUp()
> On Jul 31, 2024, at 6:01 PM, neil liu <liufield at gmail.com> wrote:
> Hi, all,
> Following Stefano's advice, my code is reorganized as follows,
> *MatCreate(PETSC_COMM_WORLD, &A);*
> * MatSetType(A, MATIS); MatSetSizes(A, PETSC_DECIDE, PETSC_DECIDE,
> numberDof_global, numberDof_global); MatSetUp(A); ISLocalToGlobalMapping
> ltogm; DMGetLocalToGlobalMapping(dm, <ogm);
> MatSetLocalToGlobalMapping(A, ltogm, ltogm);*
> Then I just ran the above code snippet, which gave me some errors as
> following. (Local size 67 not compatible with block size 2).
> It doesn't seems it is actually calling my routine, but I could be wrong
> about this.
> Can anyone give me some ideas to debug this issue?
> I am just coding vector FEM, assigning 2 dofs each edge and 2 dofs each
> face.
> The ltogm seems normal.
> ISLocalToGlobalMapping Object: 2 MPI processes
> type not yet set
> [0] 0:2 0:2
> [0] 2:4 2:4
> [0] 4:6 54:56
> [0] 6:8 4:6
> [0] 8:10 6:8
> [0] 10:12 8:10
> [0] 12:14 10:12
> [0] 14:16 56:58
> [0] 16:18 12:14
> [0] 18:20 14:16
> [0] 20:22 16:18
> [0] 22:24 58:60
> [0] 24:26 18:20
> [0] 26:28 20:22
> [0] 28:30 22:24
> [0] 30:32 24:26
> [0] 32:34 60:62
> [0] 34:36 26:28
> [0] 36:38 28:30
> [0] 38:40 30:32
> [0] 40:42 32:34
> [0] 42:44 92:94
> [0] 44:46 94:96
> [0] 46:48 34:36
> [0] 48:50 96:98
> [0] 50:52 36:38
> [0] 52:54 98:100
> [0] 54:56 38:40
> [0] 56:58 40:42
> [0] 58:60 100:102
> [0] 60:62 42:44
> [0] 62:64 102:104
> [0] 64:66 44:46
> [0] 66:68 104:106
> [0] 68:70 46:48
> [0] 70:72 106:108
> [0] 72:74 48:50
> [0] 74:76 50:52
> [0] 76:78 108:110
> [0] 78:80 52:54
> [1] 0:2 54:56
> [1] 2:4 56:58
> [1] 4:6 58:60
> [1] 6:8 60:62
> [1] 8:10 62:64
> [1] 10:12 64:66
> [1] 12:14 66:68
> [1] 14:16 68:70
> [1] 16:18 70:72
> [1] 18:20 72:74
> [1] 20:22 74:76
> [1] 22:24 76:78
> [1] 24:26 78:80
> [1] 26:28 80:82
> [1] 28:30 82:84
> [1] 30:32 84:86
> [1] 32:34 86:88
> [1] 34:36 88:90
> [1] 36:38 90:92
> [1] 38:40 92:94
> [1] 40:42 94:96
> [1] 42:44 96:98
> [1] 44:46 98:100
> [1] 46:48 100:102
> [1] 48:50 102:104
> [1] 50:52 104:106
> [1] 52:54 106:108
> [1] 54:56 108:110
> [1] 56:58 110:112
> [1] 58:60 112:114
> [1] 60:62 114:116
> [1] 62:64 116:118
> [1] 64:66 118:120
> [1] 66:68 120:122
> [1] 68:70 122:124
> [1] 70:72 124:126
> [1] 72:74 126:128
> [1] 74:76 128:130
> [1] 76:78 130:132
> [1] 78:80 132:134
> [0]PETSC ERROR: --------------------- Error Message
> [0]PETSC ERROR: Arguments are incompatible
> [0]PETSC ERROR: [1]PETSC ERROR: --------------------- Error Message
> [0]PETSC ERROR: See https://urldefense.us/v3/__https://petsc.org/release/faq/__;!!G_uCfscf7eWS!ezBBwLu_ohCVxEbEjF9KAyHOajlCzLcFYsXr_HXTqn0SGLkTERqqi0jm5qKxXga1bLCySC2Jmm_e5lFYstYzVw$ for trouble shooting.
> [0]PETSC ERROR: Petsc Release Version 3.21.1, unknown
> [0]PETSC ERROR: [1]PETSC ERROR: Arguments are incompatible
> [1]PETSC ERROR: Local size 67 not compatible with block size 2
> [1]PETSC ERROR: ./app on a arch-linux-c-debug by xiaodong.liu Wed Jul 31
> 17:43:28 2024
> [0]PETSC ERROR: Configure options --with-cc=gcc --with-fc=gfortran
> --with-cxx=g++ --download-fblaslapack --download-mpich
> --with-scalar-type=complex --download-triangle
> [1]PETSC ERROR: Petsc Release Version 3.21.1, unknown
> 17:43:28 2024
> [1]PETSC ERROR: #1 PetscLayoutSetBlockSize() at
> /home/xiaodong.liu/Documents/petsc-3.21.1/petsc/src/vec/is/utils/pmap.c:473
> [0]PETSC ERROR: #2 MatSetLocalToGlobalMapping_IS() at
> /home/xiaodong.liu/Documents/petsc-3.21.1/petsc/src/mat/impls/is/matis.c:2831
> [0]PETSC ERROR: #3 MatSetLocalToGlobalMapping() at
> /home/xiaodong.liu/Documents/petsc-3.21.1/petsc/src/mat/interface/matrix.c:2252
> Configure options --with-cc=gcc --with-fc=gfortran --with-cxx=g++
> --download-fblaslapack --download-mpich --with-scalar-type=complex
> --download-triangle
> [1]PETSC ERROR: After Mat set local to global mapping!
> [1]PETSC ERROR: #3 MatSetLocalToGlobalMapping() at
> Thanks,
> On Tue, Jul 30, 2024 at 2:51 PM neil liu <liufield at gmail.com> wrote:
>> Hi, Stefano,
>> I am trying to understand the example there you mentioned. I have a
>> question,
>> the example always use DMDA there. Does BDDC also work for DMPLEX?
>> Thanks ,
>> On Tue, Jul 30, 2024 at 1:47 PM neil liu <liufield at gmail.com> wrote:
>>> Thanks, Stefano,
>>> I am trying to modify the code as follows,
>>> MatSetSizes(A, PETSC_DECIDE, PETSC_DECIDE, numberDof_global,
>>> numberDof_global);
>>> MatSetUp(A);
>>> MatZeroEntries(A);
>>> VecCreate(PETSC_COMM_WORLD, &b);
>>> VecSetSizes(b, PETSC_DECIDE, numberDof_global);
>>> VecSetUp(b);
>>> VecSet(b,0.0);
>>> VecDuplicate(b, &x);
>>> const PetscInt *g_idx;
>>> ISLocalToGlobalMapping ltogm;
>>> ISLocalToGlobalMappingGetIndices(ltogm, &g_idx);
>>> //Build idxm_global and Set LHS
>>> idxm_Global[ idxDofLocal ] = g_idx[ numdofPerFace*idxm[idxDofLocal]];
>>> MatSetValues(A, numberDof_local, idxm_Global.data(), numberDof_local,
>>> idxm_Global.data(), MatrixLocal.data(), ADD_VALUES);
>>> //Set RHS
>>> PetscScalar valueDiag = 1.0 ;
>>> MatZeroRows(A, objGeometryInfo.numberDof_Dirichlet, (objGeometryInfo.
>>> arrayDofSeqGlobal_Dirichlet).data(), valueDiag, 0, 0);
>>> VecSetValues(b, objGeometryInfo.numberDof_Dirichlet, (objGeometryInfo.
>>> arrayDofSeqGlobal_Dirichlet).data(), (objGeometryInfo.dof_Dirichlet).
>>> data(), INSERT_VALUES);
>>> VecSetValues(x, objGeometryInfo.numberDof_Dirichlet, (objGeometryInfo.
>>> ISLocalToGlobalMappingRestoreIndices(ltogm, &g_idx);
>>> VecAssemblyBegin(b);
>>> VecAssemblyEnd(b);
>>> VecAssemblyBegin(x);
>>> VecAssemblyEnd(x);
>>> It shows the attached error when I run the code. It seems something
>>> wrong is with setting RHS.
>>> Could you please help me double check my above code to setup the RHS?
>>> Thanks,
>>> On Tue, Jul 30, 2024 at 11:56 AM Stefano Zampini <
>>> stefano.zampini at gmail.com> wrote:
>>>> BDDC needs the matrix in MATIS format. Using MatConvert will give you
>>>> back the right format, but the subdomain matrices are wrong. You need to
>>>> assemble directly in MATIS format, something like
>>>> MatCreate(comm,&A)
>>>> MatSetType(A,MATIS)
>>>> MatSetLocalToGlobalMapping(A,l2gmap, l2gmap)
>>>> for e in local_elements:
>>>> E = compute_element_matrix(e)
>>>> MatSetValues(A,local_element_dofs,local_element_dofs,....)
>>>> l2gmap is an ISLocalToGlobalMapping that stores the global dof number
>>>> of the dofs that are local to the mesh
>>>> See e.g.
>>>> https://urldefense.us/v3/__https://gitlab.com/petsc/petsc/-/blob/main/src/ksp/ksp/tutorials/ex59.c?ref_type=heads__;!!G_uCfscf7eWS!ezBBwLu_ohCVxEbEjF9KAyHOajlCzLcFYsXr_HXTqn0SGLkTERqqi0jm5qKxXga1bLCySC2Jmm_e5lFLn1UiNw$
>>>> or
>>>> https://urldefense.us/v3/__https://gitlab.com/petsc/petsc/-/blob/main/src/ksp/ksp/tutorials/ex71.c?ref_type=heads__;!!G_uCfscf7eWS!ezBBwLu_ohCVxEbEjF9KAyHOajlCzLcFYsXr_HXTqn0SGLkTERqqi0jm5qKxXga1bLCySC2Jmm_e5lFhsK-8Zg$
>>>> Il giorno mar 30 lug 2024 alle ore 17:50 neil liu <liufield at gmail.com>
>>>> ha scritto:
>>>>> Hi,
>>>>> I am trying to use PCBDDC for the vector based FEM. (Complex system,
>>>>> double precision )
>>>>> My code can work well with *asm*,
>>>>> petsc-3.21.1/petsc/arch-linux-c-opt/bin/mpirun -n 8 ./app -pc_type asm
>>>>> -pc_asm_overlap 6 -ksp_converged_reason -ksp_view
>>>>> -ksp_gmres_modifiedgramschmidt -ksp_gmres_restart 1500 -ksp_rtol 1e-8
>>>>> -ksp_monitor -ksp_max_it 100000
>>>>> When I tried BDDC, it was stuck for solving the linear system (it can
>>>>> not print anything for ksp_monitor). I did the conversion for matrix,
>>>>> * Mat J;*
>>>>> * MatConvert(A, MATIS, MAT_INITIAL_MATRIX, &J);*
>>>>> * KSPSetOperators(ksp, A, J);*
>>>>> * MatDestroy(&J);*
>>>>> * KSPSetInitialGuessNonzero(ksp, PETSC_TRUE);*
>>>>> * KSPSetFromOptions(ksp);*
>>>>> petsc-3.21.1/petsc/arch-linux-c-debug/bin/mpirun -n 2 ./app -ksp_type
>>>>> cg -pc_type bddc -ksp_monitor -mat_type is
>>>>> Do you have any suggestions?
>>>>> Thanks ,
>>>>> Xiaodong
>>>>> On Mon, Jul 29, 2024 at 6:19 PM neil liu <liufield at gmail.com> wrote:
>>>>>> When I compile with real data,
>>>>>> it shows the attached error.
>>>>>> The data file is in binary format, right?
>>>>>> On Mon, Jul 29, 2024 at 5:36 PM Stefano Zampini <
>>>>>>> Your PETSc installation is for complex, data is for real
>>>>>>> On Mon, Jul 29, 2024, 23:14 neil liu <liufield at gmail.com> wrote:
>>>>>>>> I compiled Petsc with single precision. However, it is not
>>>>>>>> converged with the data. Please see the attached file. On Mon, Jul 29, 2024
>>>>>>>> at 4: 25 PM Barry Smith <bsmith@ petsc. dev> wrote: This can
>>>>>>>> happen if the data was stored in single precision
>>>>>>>> ZjQcmQRYFpfptBannerStart
>>>>>>>> This Message Is From an External Sender
>>>>>>>> This message came from outside your organization.
>>>>>>>> ZjQcmQRYFpfptBannerEnd
>>>>>>>> On Mon, Jul 29, 2024 at 4:25 PM Barry Smith <bsmith at petsc.dev>
>>>>>>>> wrote:
>>>>>>>>> This can happen if the data was stored in single precision and
>>>>>>>>> PETSc was built for double.
>>>>>>>>> On Jul 29, 2024, at 3:55 PM, neil liu <liufield at gmail.com> wrote:
>>>>>>>>> Dear Petsc developers,,
>>>>>>>>> I am trying to run
>>>>>>>>> https://urldefense.us/v3/__https://petsc.org/release/src/ksp/ksp/tutorials/ex72.c.html__;!!G_uCfscf7eWS!ezBBwLu_ohCVxEbEjF9KAyHOajlCzLcFYsXr_HXTqn0SGLkTERqqi0jm5qKxXga1bLCySC2Jmm_e5lHlwHtSAw$
>>>>>>>>> <https://urldefense.us/v3/__https://petsc.org/release/src/ksp/ksp/tutorials/ex72.c.html__;!!G_uCfscf7eWS!ZG4gvmS6hQD8ymbvCUDfAatzRUJHzmWO-hOgp9m0xXuAXgIB-fxe_xspYs3WEPi_Ed0UFLMHKanYuYWrTlQGrA$>
>>>>>>>>> with
>>>>>>>>> petsc-3.21.1/petsc/arch-linux-c-opt/bin/mpirun -n 2 ./ex72 -f
>>>>>>>>> /Documents/PetscData/poisson_DMPLEX_32x32_16.dat -pc_type bddc -ksp_type cg
>>>>>>>>> -ksp_norm_type natural -ksp_error_if_not_converged -mat_type is
>>>>>>>>> The file was downloaded and put in the directory PetscData.
>>>>>>>>> The error is shown as follows,
>>>>>>>>> [0]PETSC ERROR: Read from file failed
>>>>>>>>> [0]PETSC ERROR: Read past end of file
>>>>>>>>> [0]PETSC ERROR: WARNING! There are unused option(s) set! Could be
>>>>>>>>> the program crashed before usage or a spelling mistake, etc!
>>>>>>>>> [0]PETSC ERROR: Option left: name:-ksp_error_if_not_converged
>>>>>>>>> (no value) source: command line
>>>>>>>>> [0]PETSC ERROR: Option left: name:-ksp_norm_type value: natural
>>>>>>>>> [0]PETSC ERROR: Option left: name:-ksp_type value: cg source:
>>>>>>>>> command line
>>>>>>>>> [0]PETSC ERROR: Option left: name:-pc_type value: bddc source:
>>>>>>>>> command line
>>>>>>>>> <https://urldefense.us/v3/__https://petsc.org/release/faq/__;!!G_uCfscf7eWS!ZG4gvmS6hQD8ymbvCUDfAatzRUJHzmWO-hOgp9m0xXuAXgIB-fxe_xspYs3WEPi_Ed0UFLMHKanYuYVR0x14Xg$>
>>>>>>>>> [0]PETSC ERROR: ./ex72 on a arch-linux-c-opt named
>>>>>>>>> Mon Jul 29 15:50:04 2024
>>>>>>>>> --with-scalar-type=complex --download-triangle --with-debugging=no
>>>>>>>>> [0]PETSC ERROR: #1 PetscBinaryRead() at
>>>>>>>>> /home/xxxxxx/Documents/petsc-3.21.1/petsc/src/sys/fileio/sysio.c:327
>>>>>>>>> [0]PETSC ERROR: #2 PetscViewerBinaryWriteReadAll() at
>>>>>>>>> /home/xiaodong.liu/Documents/petsc-3.21.1/petsc/src/sys/classes/viewer/impls/binary/binv.c:1077
>>>>>>>>> [0]PETSC ERROR: #3 PetscViewerBinaryReadAll() at
>>>>>>>>> /home/xiaodong.liu/Documents/petsc-3.21.1/petsc/src/sys/classes/viewer/impls/binary/binv.c:1119
>>>>>>>>> [0]PETSC ERROR: #4 MatLoad_MPIAIJ_Binary() at
>>>>>>>>> Documents/petsc-3.21.1/petsc/src/mat/impls/aij/mpi/mpiaij.c:3093
>>>>>>>>> [0]PETSC ERROR: #5 MatLoad_MPIAIJ() at
>>>>>>>>> /Documents/petsc-3.21.1/petsc/src/mat/impls/aij/mpi/mpiaij.c:3035
>>>>>>>>> [0]PETSC ERROR: #6 MatLoad() at
>>>>>>>>> /Documents/petsc-3.21.1/petsc/src/mat/interface/matrix.c:1344
>>>>>>>>> [0]PETSC ERROR: #7 MatLoad_IS() at
>>>>>>>>> /Documents/petsc-3.21.1/petsc/src/mat/impls/is/matis.c:2575
>>>>>>>>> [0]PETSC ERROR: #8 MatLoad() at
>>>>>>>>> /home/Documents/petsc-3.21.1/petsc/src/mat/interface/matrix.c:1344
>>>>>>>>> [0]PETSC ERROR: #9 main() at ex72.c:105
>>>>>>>>> [0]PETSC ERROR: PETSc Option Table entries:
>>>>>>>>> [0]PETSC ERROR: -f
>>>>>>>>> /Documents/PetscData/poisson_DMPLEX_32x32_16.dat (source: command
>>>>>>>>> line)
>>>>>>>>> [0]PETSC ERROR: -ksp_error_if_not_converged (source: command line)
>>>>>>>>> [0]PETSC ERROR: -ksp_norm_type natural (source: command line)
>>>>>>>>> [0]PETSC ERROR: -ksp_type cg (source: command line)
>>>>>>>>> [0]PETSC ERROR: -mat_type is (source: command line)
>>>>>>>>> [0]PETSC ERROR: -pc_type bddc (source: command line)
>>>>>>>>> [0]PETSC ERROR: ----------------End of Error Message -------send
>>>>>>>>> entire error message to petsc-maint at mcs.anl.gov----------
>>>>>>>>> application called MPI_Abort(MPI_COMM_SELF, 66) - process 0
>>>> Stefano
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240731/ea80fa0a/attachment-0001.html>
