[petsc-users] How to combine different element types into a single DMPlex?
Eric Chamberland Eric.Chamberland at giref.ulaval.ca
Wed Jul 31 15:16:47 CDT 2024
Hi Vaclav,
Okay, I am coming back with this question after some time... ;)
I am just wondering if it is now possible to call
DMPlexBuildFromCellListParallel or something else, to build a mesh that
combine different element types into a single DMPlex (in parallel of
course) ?
Eric
On 2021-09-23 11:30, Hapla Vaclav wrote:
> Note there will soon be a generalization of
> DMPlexBuildFromCellListParallel() around, as a side product of our
> current collaborative efforts with Firedrake guys. It will take a
> PetscSection instead of relying on the blocksize [which is indeed
> always constant for the given dataset]. Stay tuned.
> https://urldefense.us/v3/__https://gitlab.com/petsc/petsc/-/merge_requests/4350__;!!G_uCfscf7eWS!fgngRI84CI_6fHdWdRiVbv0bvraQkhXyV396Uo5y2mORbR4DjlMYrHTqX0p22Ysp8t9yJPhCL1E3fkbWxmIZpQp6dYhcdaKz9_yUIGas$
> Thanks,
> Vaclav
>> On 23 Sep 2021, at 16:53, Eric Chamberland
>> <Eric.Chamberland at giref.ulaval.ca> wrote:
>> Hi,
>> oh, that's a great news!
>> In our case we have our home-made file-format, invariant to the
>> number of processes (thanks to MPI_File_set_view), that uses
>> collective, asynchronous MPI I/O native calls for unstructured hybrid
>> meshes and fields .
>> So our needs are not for reading meshes but only to fill an hybrid
>> DMPlex with DMPlexBuildFromCellListParallel (or something else to
>> come?)... to exploit petsc partitioners and parallel overlap
>> computation...
>> Thanks for the follow-up! :)
>> Eric
>> On 2021-09-22 7:20 a.m., Matthew Knepley wrote:
>>> On Wed, Sep 22, 2021 at 3:04 AM Karin&NiKo <niko.karin at gmail.com> wrote:
>>>     Dear Matthew,
>>>     This is great news!
>>>     For my part, I would be mostly interested in the parallel input
>>>     interface. Sorry for that...
>>>     Indeed, in our application, we already have a parallel mesh data
>>>     structure that supports hybrid meshes with parallel I/O and
>>>     distribution (based on the MED format). We would like to use a
>>>     DMPlex to make parallel mesh adaptation.
>>>      As a matter of fact, all our meshes are in the MED format. We
>>>     could also contribute to extend the interface of DMPlex with MED
>>>     (if you consider it could be usefull).
>>> An MED interface does exist. I stopped using it for two reasons:
>>>   1) The code was not portable and the build was failing on
>>> different architectures. I had to manually fix it.
>>>   2) The boundary markers did not provide global information, so
>>> that parallel reading was much harder.
>>> Feel free to update my MED reader to a better design.
>>>   Thanks,
>>>      Matt
>>>     Best regards,
>>>     Nicolas
>>>     Le mar. 21 sept. 2021 à 21:56, Matthew Knepley
>>>     <knepley at gmail.com> a écrit :
>>>         On Tue, Sep 21, 2021 at 10:31 AM Karin&NiKo
>>>             Dear Eric, dear Matthew,
>>>             I share Eric's desire to be able to manipulate meshes
>>>             composed of different types of elements in a PETSc's
>>>             DMPlex.
>>>             Since this discussion, is there anything new on this
>>>             feature for the DMPlex object or am I missing something?
>>>         Thanks for finding this!
>>>         Okay, I did a rewrite of the Plex internals this summer. It
>>>         should now be possible to interpolate a mesh with any
>>>         number of cell types, partition it, redistribute it, and
>>>         many other manipulations.
>>>         You can read in some formats that support hybrid meshes. If
>>>         you let me know how you plan to read it in, we can make it work.
>>>         Right now, I don't want to make input interfaces that no one
>>>         will ever use. We have a project, joint with Firedrake, to
>>>         finalize
>>>         parallel I/O. This will make parallel reading and writing
>>>         for checkpointing possible, supporting topology, geometry,
>>>         fields and
>>>         layouts, for many meshes in one HDF5 file. I think we will
>>>         finish in November.
>>>           Thanks,
>>>              Matt
>>>             Thanks,
>>>             Nicolas
>>>             Le mer. 21 juil. 2021 à 04:25, Eric Chamberland
>>>             <Eric.Chamberland at giref.ulaval.ca> a écrit :
>>>                 Hi,
>>>                 On 2021-07-14 3:14 p.m., Matthew Knepley wrote:
>>>>                 On Wed, Jul 14, 2021 at 1:25 PM Eric Chamberland
>>>>                     Hi,
>>>>                     while playing with
>>>>                     DMPlexBuildFromCellListParallel, I noticed we
>>>>                     have to
>>>>                     specify "numCorners" which is a fixed value,
>>>>                     then gives a fixed number
>>>>                     of nodes for a series of elements.
>>>>                     How can I then add, for example, triangles and
>>>>                     quadrangles into a DMPlex?
>>>>                 You can't with that function. It would be much mich
>>>>                 more complicated if you could, and I am not sure
>>>>                 it is worth it for that function. The reason is
>>>>                 that you would need index information to
>>>>                 offset into the
>>>>                 connectivity list, and that would need to be
>>>>                 replicated to some extent so that all processes
>>>>                 know what
>>>>                 the others are doing. Possible, but complicated.
>>>>                 Maybe I can help suggest something for what you are
>>>>                 trying to do?
>>>                 Yes: we are trying to partition our parallel mesh
>>>                 with PETSc functions. The mesh has been read in
>>>                 parallel so each process owns a part of it, but we
>>>                 have to manage mixed elements types.
>>>                 When we directly use ParMETIS_V3_PartMeshKway, we
>>>                 give two arrays to describe the elements which
>>>                 allows mixed elements.
>>>                 So, how would I read my mixed mesh in parallel and
>>>                 give it to PETSc DMPlex so I can use a
>>>                 PetscPartitioner with DMPlexDistribute ?
>>>                 A second goal we have is to use PETSc to compute the
>>>                 overlap, which is something I can't find in PARMetis
>>>                 (and any other partitionning library?)
>>>                 Thanks,
>>>                 Eric
>>>>                   Thanks,
>>>>                       Matt
>>>>                     Thanks,
>>>>                     Eric
>>>>                     Eric Chamberland, ing., M. Ing
>>>>                     Professionnel de recherche
>>>>                     GIREF/Université Laval
>>>>                     (418) 656-2131 poste 41 22 42
>>>>                 What most experimenters take for granted before
>>>>                 they begin their experiments is infinitely more
>>>>                 interesting than any results to which their
>>>>                 experiments lead.
>>>>                 -- Norbert Wiener
>>>>                 https://urldefense.us/v3/__https://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!fgngRI84CI_6fHdWdRiVbv0bvraQkhXyV396Uo5y2mORbR4DjlMYrHTqX0p22Ysp8t9yJPhCL1E3fkbWxmIZpQp6dYhcdaKz9-bqwEGn$
>>>>                 <https://urldefense.us/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!fgngRI84CI_6fHdWdRiVbv0bvraQkhXyV396Uo5y2mORbR4DjlMYrHTqX0p22Ysp8t9yJPhCL1E3fkbWxmIZpQp6dYhcdaKz9w0270gm$ >
>>>         What most experimenters take for granted before they begin
>>>         their experiments is infinitely more interesting than any
>>>         results to which their experiments lead.
>>>         -- Norbert Wiener
>>> What most experimenters take for granted before they begin their
>>> experiments is infinitely more interesting than any results to which
>>> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240731/dea81bef/attachment-0001.html>
