[petsc-users] Trying to run https://petsc.org/release/src/ksp/ksp/tutorials/ex72.c.html
    neil liu
    liufield at gmail.com
    Mon Jul 29 17:19:01 CDT 2024
When I compile with real data,
it shows the attached error.
The data file is in binary format, right?
On Mon, Jul 29, 2024 at 5:36 PM Stefano Zampini <stefano.zampini at gmail.com>
wrote:
> Your PETSc installation is for complex,  data is for real
> On Mon, Jul 29, 2024, 23:14 neil liu <liufield at gmail.com> wrote:
>> I compiled Petsc with single precision. However, it is not converged with
>> the data. Please see the attached file. On Mon, Jul 29, 2024 at 4: 25 PM
>> Barry Smith <bsmith@ petsc. dev> wrote: This can happen if the data was
>> stored in single precision
>> ZjQcmQRYFpfptBannerStart
>> This Message Is From an External Sender
>> This message came from outside your organization.
>> ZjQcmQRYFpfptBannerEnd
>> the data.
>> On Mon, Jul 29, 2024 at 4:25 PM Barry Smith <bsmith at petsc.dev> wrote:
>>>    This can happen if the data was stored in single precision and PETSc
>>> was built for double.
>>> Dear Petsc developers,,
>>> I am trying to run
>>> https://urldefense.us/v3/__https://petsc.org/release/src/ksp/ksp/tutorials/ex72.c.html__;!!G_uCfscf7eWS!bQ7LQoKmWInxGh234P3yc1H6VB9xutX12MkG2-7ZV5GSAmVt70Z2vX6aPGzGCL4t9ypRczUxcH684DnT-BO0kA$
>>> <https://urldefense.us/v3/__https://petsc.org/release/src/ksp/ksp/tutorials/ex72.c.html__;!!G_uCfscf7eWS!ZG4gvmS6hQD8ymbvCUDfAatzRUJHzmWO-hOgp9m0xXuAXgIB-fxe_xspYs3WEPi_Ed0UFLMHKanYuYWrTlQGrA$>
>>> with
>>> petsc-3.21.1/petsc/arch-linux-c-opt/bin/mpirun -n 2 ./ex72  -f
>>> /Documents/PetscData/poisson_DMPLEX_32x32_16.dat -pc_type bddc -ksp_type cg
>>> -ksp_norm_type natural -ksp_error_if_not_converged -mat_type is
>>> The file was downloaded and put in the directory PetscData.
>>> The error is shown as follows,
>>> 0]PETSC ERROR: --------------------- Error Message
>>> [0]PETSC ERROR: Read from file failed
>>> [0]PETSC ERROR: Read past end of file
>>> [0]PETSC ERROR: WARNING! There are unused option(s) set! Could be the
>>> program crashed before usage or a spelling mistake, etc!
>>> [0]PETSC ERROR:   Option left: name:-ksp_error_if_not_converged (no
>>> value) source: command line
>>> [0]PETSC ERROR:   Option left: name:-ksp_norm_type value: natural
>>> [0]PETSC ERROR:   Option left: name:-ksp_type value: cg source: command
>>> line
>>> [0]PETSC ERROR:   Option left: name:-pc_type value: bddc source: command
>>> line
>>> [0]PETSC ERROR: See https://urldefense.us/v3/__https://petsc.org/release/faq/__;!!G_uCfscf7eWS!bQ7LQoKmWInxGh234P3yc1H6VB9xutX12MkG2-7ZV5GSAmVt70Z2vX6aPGzGCL4t9ypRczUxcH684DmesNpXFA$
>>> <https://urldefense.us/v3/__https://petsc.org/release/faq/__;!!G_uCfscf7eWS!ZG4gvmS6hQD8ymbvCUDfAatzRUJHzmWO-hOgp9m0xXuAXgIB-fxe_xspYs3WEPi_Ed0UFLMHKanYuYVR0x14Xg$>
>>>  for trouble shooting.
>>> [0]PETSC ERROR: Petsc Release Version 3.21.1, unknown
>>> [0]PETSC ERROR: ./ex72 on a arch-linux-c-opt named
>>>  Mon Jul 29 15:50:04 2024
>>> [0]PETSC ERROR: Configure options --with-cc=gcc --with-fc=gfortran
>>> --with-cxx=g++ --download-fblaslapack --download-mpich
>>> --with-scalar-type=complex --download-triangle --with-debugging=no
>>> [0]PETSC ERROR: #1 PetscBinaryRead() at
>>> /home/xxxxxx/Documents/petsc-3.21.1/petsc/src/sys/fileio/sysio.c:327
>>> [0]PETSC ERROR: #2 PetscViewerBinaryWriteReadAll() at
>>> /home/xiaodong.liu/Documents/petsc-3.21.1/petsc/src/sys/classes/viewer/impls/binary/binv.c:1077
>>> [0]PETSC ERROR: #3 PetscViewerBinaryReadAll() at
>>> /home/xiaodong.liu/Documents/petsc-3.21.1/petsc/src/sys/classes/viewer/impls/binary/binv.c:1119
>>> [0]PETSC ERROR: #4 MatLoad_MPIAIJ_Binary() at
>>> Documents/petsc-3.21.1/petsc/src/mat/impls/aij/mpi/mpiaij.c:3093
>>> [0]PETSC ERROR: #5 MatLoad_MPIAIJ() at
>>> /Documents/petsc-3.21.1/petsc/src/mat/impls/aij/mpi/mpiaij.c:3035
>>> [0]PETSC ERROR: #6 MatLoad() at
>>> /Documents/petsc-3.21.1/petsc/src/mat/interface/matrix.c:1344
>>> [0]PETSC ERROR: #7 MatLoad_IS() at
>>> /Documents/petsc-3.21.1/petsc/src/mat/impls/is/matis.c:2575
>>> [0]PETSC ERROR: #8 MatLoad() at
>>> /home/Documents/petsc-3.21.1/petsc/src/mat/interface/matrix.c:1344
>>> [0]PETSC ERROR: #9 main() at ex72.c:105
>>> [0]PETSC ERROR: PETSc Option Table entries:
>>> [0]PETSC ERROR: -f
>>> /Documents/PetscData/poisson_DMPLEX_32x32_16.dat (source: command line)
>>> [0]PETSC ERROR: -ksp_error_if_not_converged (source: command line)
>>> [0]PETSC ERROR: -ksp_norm_type natural (source: command line)
>>> [0]PETSC ERROR: -ksp_type cg (source: command line)
>>> [0]PETSC ERROR: -mat_type is (source: command line)
>>> [0]PETSC ERROR: -pc_type bddc (source: command line)
>>> [0]PETSC ERROR: ----------------End of Error Message -------send entire
>>> error message to petsc-maint at mcs.anl.gov----------
>>> application called MPI_Abort(MPI_COMM_SELF, 66) - process 0
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240729/e4148813/attachment-0001.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240729/e4148813/attachment-0001.obj>
