[petsc-users] Error MPI_ABORT
Ivan Luthfi
ivanluthfi5 at gmail.com
Fri Jul 26 22:24:06 CDT 2024
Hi friend,
I am trying to try my second Petsc exercise in a lecture from Eijkhout.
I run it using command: mpiexec -n 2 ./vec_view in my Macbook with 2 cores.
but I got an error. Here is the error message:
[1]PETSC ERROR: --------------------- Error Message
[1]PETSC ERROR: Argument out of range
[1]PETSC ERROR: Out of range index value 200 maximum 200
[1]PETSC ERROR: WARNING! There are unused option(s) set! Could be the
program crashed before usage or a spelling mistake, etc!
[1]PETSC ERROR: Option left: name:-vec_view (no value) source: command
line
[1]PETSC ERROR: See https://urldefense.us/v3/__https://petsc.org/release/faq/__;!!G_uCfscf7eWS!c9Sc5i6Zy6_vzM9RLEJfU92oYcv7s-RDyELXxNOCh10iT66qkMKsVNOdNN5Mylbznn2ag7w1daVGSrqSnN7HmPLABA$ for trouble shooting.
[1]PETSC ERROR: Petsc Release Version 3.21.3, unknown
[1]PETSC ERROR: ./vec on a arch-darwin-c-debug named ivanpro.local by jkh
Sat Jul 27 11:21:26 2024
[1]PETSC ERROR: Configure options
--with-cc=/Users/jkh/projects/openmpi/opt-5.0.4/bin/mpicc
--with-cxx=/Users/jkh/projects/openmpi/opt-5.0.4/bin/mpicxx --with-fc=0
--download-make --download-cmake --download-bison --with-x=0
--download-f2cblaslapack --download-metis --download-parmetis
--download-ptscotch --download-superlu_dist
[1]PETSC ERROR: #1 VecSetValues_MPI() at
/Users/jkh/projects/petsc/src/vec/vec/impls/mpi/pdvec.c:859
[1]PETSC ERROR: #2 VecSetValues() at
/Users/jkh/projects/petsc/src/vec/vec/interface/rvector.c:917
[1]PETSC ERROR: #3 main() at vec.c:70
[1]PETSC ERROR: PETSc Option Table entries:
[1]PETSC ERROR: -vec_view (source: command line)
[1]PETSC ERROR: ----------------End of Error Message -------send entire
error message to petsc-maint at mcs.anl.gov----------
MPI_ABORT was invoked on rank 0 in communicator MPI_COMM_SELF
Proc: [[953,1],1]
Errorcode: 63
NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
You may or may not see output from other processes, depending on
exactly when Open MPI kills them.
prterun has exited due to process rank 1 with PID 0 on node ivanpro calling
"abort". This may have caused other processes in the application to be
terminated by signals sent by prterun (as reported here).
can you help me guys?
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240727/336e82fb/attachment.html>
