[petsc-users] (no subject)
Dave May dave.mayhem23 at gmail.com
Thu Jul 25 09:59:15 CDT 2024
I think to achieve what you want you will need to use a KSP which supports
right preconditioning, that is they monitor || Ax-b || rather than ||
P^{-1} ( Ax - b ) ||, where P^{-1} is the application of the preconditioner.
Try running with -ksp_type fgmres or -ksp_type gcr. These Krylov methods
support right preconditioning by default.
Dave
On Mon 22. Jul 2024 at 04:37, Константин Мурусидзе <
konstantin.murusidze at math.msu.ru> wrote:
> Good afternoon. I am a student at the Faculty of Mathematics and for my
> course work I need to solve SLAE with a relative accuracy of 1e-8 or more.
> To do this, I created the function PetscCall(KSPSetTolerances(ksp, 1. e-8,
> PETSC_DEFAULT, PETSC_DEFAULT,
> ZjQcmQRYFpfptBannerStart
> This Message Is From an External Sender
> This message came from outside your organization.
> ZjQcmQRYFpfptBannerEnd
> To do this, I created the function PetscCall(KSPSetTolerances(ksp, 1.e-8,
> PETSC_DEFAULT, PETSC_DEFAULT, 100000));. But in the end, only 38 iterations
> were made and the relative norm ||Ax-b||/||b|| it turns out 4.54011. If you
> reply to my email, I can give you more information about the solver
> settings.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240725/a3bb561a/attachment.html>
