[petsc-users] compilation error with latest petsc source
Vanella, Marcos (Fed)
marcos.vanella at nist.gov
Fri Jul 19 11:20:23 CDT 2024
Hi, I did an update and compiled PETSc in Frontier with gnu compilers. When compiling my code with PETSc I see this new error pop up:
Building mpich_gnu_frontier
ftn -c -m64 -O2 -g -std=f2018 -frecursive -ffpe-summary=none -fall-intrinsics -cpp -DGITHASH_PP=\"FDS-6.9.1-894-g0b77ae0-FireX\" -DGITDATE_PP=\""Thu Jul 11 16:05:44 2024 -0400\"" -DBUILDDATE_PP=\""Jul 19, 2024 12:13:39\"" -DWITH_PETSC -I"/autofs/nccs-svm1_home1/vanellam/Software/petsc/include/" -I"/autofs/nccs-svm1_home1/vanellam/Software/petsc/arch-linux-frontier-opt-gcc2/include" -fopenmp ../../Source/pres.f90
../../Source/pres.f90:2799:65:
2799 | CALL MATCREATESEQAIJ(PETSC_COMM_SELF,ZM%NUNKH,ZM%NUNKH,NNZ_7PT_H,PETSC_NULL_INTEGER,ZM%PETSC_MZ%A_H,PETSC_IERR)
| 1
Error: Rank mismatch in argument ‘e’ at (1) (rank-1 and scalar)
It seems the use of PETSC_NULL_INTEGER is causing an issue now. From the PETSc docs this entry is nnz which can be an array or NULL. Has there been any change on the API for this routine?
Marcos
PS: I see some other erros in calls to PETSc routines, same type.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240719/1b23f024/attachment.html>
