[petsc-users] question on matrix preallocation
Michael Povolotskyi
mpovolot at gmail.com
Thu Jul 11 15:51:58 CDT 2024
Thanks a lot.
Is this a new feature? It seems to me that 10 years ago the default
behavior was different.
Michael.
On 7/11/2024 4:04 PM, Barry Smith wrote:
> By default, if you preallocate but not enough, it will automatically
> error unless you call
> MatSetOption(mat,MAT_NEW_NONZERO_ALLOCATION_ERR,PETSC_FALSE);
>> On Jul 11, 2024, at 4:02 PM, Michael Povolotskyi <mpovolot at gmail.com>
>> wrote:
>> Thank you,
>> let me clarify my question.
>> Imagine that I have a sparse matrix, and the number of non zero
>> entries that I specified is too small.
>> I know that I can insert values in it but it will be slow.
>> I remember there was a way to make PETSC to throw an error if a
>> number of non zero elements per row was bigger that was preallocated.
>> Then I could fix my algorithm. Is this functionality available with
>> the current version?
>> Michael.
>> On 7/11/2024 3:55 PM, Barry Smith wrote:
>>> MatGetInfo() is the programmatic interface used to get this
>>> information. You can also run a proggram with -info and grep for
>>> malloc.
>>> Barry
>>>> On Jul 11, 2024, at 1:55 PM, Michael Povolotskyi
>>>> <mpovolot at gmail.com> wrote:
>>>> This Message Is From an External Sender
>>>> This message came from outside your organization.
>>>> Hello,
>>>> is there an option in PETSC that allows to check at run time if a sparse
>>>> matrix has been preallocated correctly? I remember there was something
>>>> like that is the older versions, but cannot find it now.
>>>> The goal is to get rid of any possible time overhead due to dynamic
>>>> preallocation.
>>>> Thank you,
>>>> Michael.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240711/9e6f7f6f/attachment-0001.html>
