[petsc-users] MKL Pardiso returning NAN values
Chris Hewson chris at resfrac.com
Thu Jul 11 15:03:08 CDT 2024
So are you saying that MKL_Padiso is returning inf/nan in the solution but
a return code less than or equal to zero?
- that's correct
 Is this expected behavior of MKL Pardiso?
- from what I can see, that does appear to be the expected behavior of
Pardiso. I mean I guess it has solved the system correctly.
Thanks Mark for the suggestion, that seems like a reasonable solution.
Chris
On Thu, Jul 11, 2024, 13:53 Barry Smith <bsmith at petsc.dev> wrote:
>   We don't by default, for example, check the norm of the solution
> returned by an external direct solver due to the added expense.
>   We do check the error condition returned by MKL Pardiso with
>   PetscCheck(mat_mkl_pardiso->err >= 0, PETSC_COMM_SELF, PETSC_ERR_LIB,
> "Error reported by MKL PARDISO: err=%d. Please check manual",
> mat_mkl_pardiso->err);
>  except (I don't know why) in  MatDestroy_MKL_PARDISO()
> a return code less than or equal to zero?  Is this expected behavior of MKL
> Pardiso?
> On Jul 10, 2024, at 5:01 PM, Chris Hewson <chris at resfrac.com> wrote:
> This Message Is From an External Sender
> This message came from outside your organization.
> Hi There,
> We have a matrix that is singular and trying to solve it. We first use an
> iterative solve with KSPBCGS, the solution vector is nan values and the
> converged reason from PETSc of KSP_DIVERGED_NANORINF, that's great and what
> I would expect.
> Sometimes in our program we redo a failed solve using the MKL Pardiso
> solver, when the same matrix and vectors get put into that solver which is
> a KSPPREONLY, I get KSP_CONVERGED_ITS as a converged reason and solution
> vector with nan values in it.
> Stepping through the PETSc calls, I see that the external call to Pardiso
> doesn't return an error for this, so not really the fault of PETSc, but
> curious if y'all have seen this before or a solution/workaround to this?
> *Chris Hewson*
> Senior Reservoir Simulation Engineer
> ResFrac
> +1.587.575.9792
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240711/0234d013/attachment.html>
