[petsc-users] question on matrix preallocation
Michael Povolotskyi mpovolot at gmail.com
Thu Jul 11 15:02:10 CDT 2024
Thank you,
let me clarify my question.
Imagine that I have a sparse matrix, and the number of non zero entries
that I specified is too small.
I know that I can insert values in it but it will be slow.
I remember there was a way to make PETSC to throw an error if a number
of non zero elements per row was bigger that was preallocated. Then I
could fix my algorithm. Is this functionality available with the current
version?
Michael.
On 7/11/2024 3:55 PM, Barry Smith wrote:
>   MatGetInfo() is the programmatic interface used to get this
> information.  You can also run a proggram with -info and grep for malloc.
>   Barry
>> On Jul 11, 2024, at 1:55 PM, Michael Povolotskyi <mpovolot at gmail.com>
>> wrote:
>> This Message Is From an External Sender
>> This message came from outside your organization.
>> Hello,
>> is there an option in PETSC that allows to check at run time if a sparse
>> matrix has been preallocated correctly? I remember there was something
>> like that is the older versions, but cannot find it now.
>> The goal is to get rid of any possible time overhead due to dynamic
>> preallocation.
>> Thank you,
>> Michael.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240711/3396e3bc/attachment-0001.html>
