[petsc-users] Strategies for coupled nonlinear problems
    Matthew Knepley
    knepley at gmail.com
    Mon Jul  8 06:42:56 CDT 2024
On Mon, Jul 8, 2024 at 6:14 AM Miguel Angel Salazar de Troya <
miguel.salazar at corintis.com> wrote:
> Thanks Adam and Matt,
> Matt, can I get away with just using PCFIELDSPLIT? Or do I need the
> SNESFIELDSPLIT? Though it looks like the block Gauss-Seidel is only
> implemented in serial (
> https://urldefense.us/v3/__https://petsc.org/main/manual/ksp/*block-jacobi-and-overlapping-additive-schwarz-preconditioners__;Iw!!G_uCfscf7eWS!eLmDWSrulgDcLMhEC5MITvrmcOrDVcAOy95wwGeNzgl7fvAnsX_ldsB3qVD5ArIV-jCyIHEPt3Po_GnSYekO$
You can do what you want for the linear problem, but that will probably not
help. The best thing I know of for this kind of nonlinear coupling is
now called primal-dual Newton, a name which I am not wild about. It is
discussed here (https://urldefense.us/v3/__https://core.ac.uk/download/pdf/211337815.pdf__;!!G_uCfscf7eWS!eLmDWSrulgDcLMhEC5MITvrmcOrDVcAOy95wwGeNzgl7fvAnsX_ldsB3qVD5ArIV-jCyIHEPt3Po_DT_42uJ$ ) and
originated in reference [33] from that thesis. My aim was to allow these
kinds of solvers with that branch.
> On a more theoretical note, I have the impression that the convergence
> failures of the Newton-Raphson method for this kind of problem is
> ultimately due to a lack of a diagonally dominant Jacobian. I have not
> found any reference so I might be wrong.
I would say that the dominant direction for momentum hides the direction
for improvement of the coefficient.
    Matt
> Best,
> Miguel
> On Sat, Jul 6, 2024 at 3:33 PM Matthew Knepley <knepley at gmail.com> wrote:
>> On Fri, Jul 5, 2024 at 3:29 AM Miguel Angel Salazar de Troya <
>>> Hello, I have the Navier-Stokes equation coupled with a
>>> convection-diffusion equation for the temperature. It is a two-way coupling
>>> because the viscosity depends on the temperature. One way to solve this is
>>> with some kind of fixed point iteration
>>> ZjQcmQRYFpfptBannerStart
>>> This Message Is From an External Sender
>>> This message came from outside your organization.
>>> ZjQcmQRYFpfptBannerEnd
>>> Hello,
>>> I have the Navier-Stokes equation coupled with a convection-diffusion
>>> equation for the temperature. It is a two-way coupling because the
>>> viscosity depends on the temperature. One way to solve this is with some
>>> kind of fixed point iteration scheme, where I solve each equation
>>> separately in a loop until I see convergence. I am aware this is not
>>> possible directly at the SNES level. Is there something that one can do
>>> using PCFIELDSPLIT? I would like to assemble my fully coupled system and
>>> play with the solver options to get some kind of fixed-point iteration
>>> scheme. I would like to avoid having to build two separate SNES solvers,
>>> one per equation. Any reference on techniques to solve this type of coupled
>>> system is welcome.
>> Hi Miguel,
>> I have a branch
>> https://urldefense.us/v3/__https://gitlab.com/petsc/petsc/-/tree/knepley/feature-snes-fieldsplit?ref_type=heads__;!!G_uCfscf7eWS!eLmDWSrulgDcLMhEC5MITvrmcOrDVcAOy95wwGeNzgl7fvAnsX_ldsB3qVD5ArIV-jCyIHEPt3Po_ESUOIOo$
>> that will allow you to do exactly what you want to do. However, there are
>> caveats. In order to have SNES do this, it needs a way to selectively
>> reassemble subproblems. I assume you are using Firedrake, so this will
>> not work. I would definitely be willing to work with those guys to get
>> this going, introducing callbacks, just as we did on the FieldSplit case.
>>   Thanks,
>>      Matt
>>> Best,
>>> Miguel
>> experiments lead.
>> -- Norbert Wiener
>> https://urldefense.us/v3/__https://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!eLmDWSrulgDcLMhEC5MITvrmcOrDVcAOy95wwGeNzgl7fvAnsX_ldsB3qVD5ArIV-jCyIHEPt3Po_DKriL_s$
>> <https://urldefense.us/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!eLmDWSrulgDcLMhEC5MITvrmcOrDVcAOy95wwGeNzgl7fvAnsX_ldsB3qVD5ArIV-jCyIHEPt3Po_Ne_UeR1$ >
experiments lead.
-- Norbert Wiener
https://urldefense.us/v3/__https://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!eLmDWSrulgDcLMhEC5MITvrmcOrDVcAOy95wwGeNzgl7fvAnsX_ldsB3qVD5ArIV-jCyIHEPt3Po_DKriL_s$  <https://urldefense.us/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!eLmDWSrulgDcLMhEC5MITvrmcOrDVcAOy95wwGeNzgl7fvAnsX_ldsB3qVD5ArIV-jCyIHEPt3Po_Ne_UeR1$ >
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240708/18d090cc/attachment-0001.html>
