[petsc-users] make check error using Intel MKL
dr hwang dr_hwang2022 at outlook.com
Fri Jul 5 01:10:02 CDT 2024
thanks for your answer, i am using gcc-9  in my ubuntu20.04,if gcc9 compatible  with intel parallel studio 2019?
获取Outlook for Android<https://urldefense.us/v3/__https://aka.ms/AAb9ysg__;!!G_uCfscf7eWS!YD3pSCtmel4vZOSRRp4xe90d2P67Alot3sDBXE54GF3Gaj55MxEmoJjwCHNWWlcyOwTlsK7kpRs_r3lsFjO3hfiZPHbd0g$ >
Sent: Friday, July 5, 2024 12:18:30 PM
To: dr hwang <dr_hwang2022 at outlook.com>
Cc: petsc-users at mcs.anl.gov <petsc-users at mcs.anl.gov>
Subject: Re: [petsc-users] make check error using Intel MKL
Intel compilers require a compatible gcc/g++ compiler.
gcc-11 on ubuntu20.04 might be too new for "Intel parallel studio 2019"
So you'll need an older gcc - perhaps gcc-7 or gcc-8 for this version of Intel compiler.
Alternative: if you do not need to use petsc from c++ - you can try the following and see if it works:
--with-cxx=0
Satish
On Fri, 5 Jul 2024, dr hwang wrote:
> Dear support team,
>        I want to install the petsc-3.18.5 in my ubuntu20.04 with compiler "Intel parallel studio 2019", but I met some error when I execute the "make check". Below is my steps and relevant errors.
>        Firstly, in my ~/.bashrc, I have exported the PETSC_DIR=/home/hwang/archive/petsc-3.18.5 PETSC_ARCH=linux-gnu-intel and make it source.
> (1)    tar zxvf petsc-3.18.5.tar.gz
> (2)     ./configure PETSC_ARCH=linux-gnu-intel --prefix=/home/hwang/software/petsc-3.18.5 \
> --with-cc=mpiicc --with-cxx=mpiicpc --with-fc=mpiifort --with-blaslapack-dir=${MKLROOT}/lib/intel64 --with-clean
> (3)    make PETSC_DIR=/home/hwang/archive/petsc-3.18.5  PETSC_ARCH=linux-gnu-intel all
> (4)    make PETSC_DIR=/home/hwang/archive/petsc-3.18.5  PETSC_ARCH=linux-gnu-intel install
> (5)    make PETSC_DIR=/home/hwang/software/petsc-3.18.5 PETSC_ARCH="" check
> the step (5) finally threw the error like below:
> "ld: /home/hwang/software/petsc-3.19.6/lib/libpetsc.so: undefined reference to `__builtin_is_constant_evaluated'
> make[4]: *** [/home/hwang/software/petsc-3.19.6/lib/petsc/conf/rules:216: ex5f] Error 1
> Possible error running Fortran example src/snes/tutorials/ex5f with 1 MPI process
> See https://urldefense.us/v3/__https://petsc.org/release/faq/__;!!G_uCfscf7eWS!eqXOT36R1yIYfqMp-oF8yWf52fuq7J3L7CbkswjYcLeO7fQEIVvCYwGmvixTX1I4JJlq_XDHZ46Smrc0UZff2-GXD8YTHw$
> [proxy:0:0 at DESKTOP-AM9CLNS] HYD_spawn (../../../../../src/pm/i_hydra/libhydra/spawn/intel/hydra_spawn.c:117): execvp error on file ./ex5f (No such file or directory)
> make[4]: *** [<builtin>: ex19] Error 1
> Possible error running C/C++ src/snes/tutorials/ex19 with 1 MPI process
> See https://urldefense.us/v3/__https://petsc.org/release/faq/__;!!G_uCfscf7eWS!eqXOT36R1yIYfqMp-oF8yWf52fuq7J3L7CbkswjYcLeO7fQEIVvCYwGmvixTX1I4JJlq_XDHZ46Smrc0UZff2-GXD8YTHw$ "
> How can I solved it? Could you please help me.
> Best regards,
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240705/863b16cf/attachment.html>
