[petsc-users] Doubt about TSMonitorSolutionVTK
Matthew Knepley
knepley at gmail.com
Tue Jul 2 14:57:11 CDT 2024
On Tue, Jul 2, 2024 at 3:50 PM MIGUEL MOLINOS PEREZ <mmolinos at us.es> wrote:
> Dear Matthew, thank you. That makes much more sense. Is the script you
> mention available for download?
$PETSC_DIR/lib/petsc/bin/petsc-_gen_xdmf.py
Matt
> Thanks,
> Miguel
> On Jul 1, 2024, at 5:09 AM, Matthew Knepley <knepley at gmail.com> wrote:
> On Mon, Jul 1, 2024 at 1:43 AM MIGUEL MOLINOS PEREZ <mmolinos at us.es>
> wrote:
>> Dear Matthey,
>> Sorry for the late response.
>> Yes, I get output when I run the example mentioned by Barry.
>> The output directory should not be an issue since with the exact same
>> configuration works for hdf5 but not for vtk/vts/vtu.
>> I’ve been doing some tests and now I think this issue might be related to
>> the fact that the output vector was generated using a SWARM discretization.
>> Is this possible?
> Yes, there is no VTK viewer for Swarm. We have been moving away from VTK
> format, which is bulky and not very expressive, into our own HDF5 and CGNS.
> When we use HDF5, we have a script to generate an XDMF file, telling
> Paraview how to view it. I agree that this is annoying. Currently, we are
> moving toward PyVista, which can read our HDF5 files directly (and also
> work directly with running PETSc), although this is not done yet.
> Thanks,
> Matt
>> Best,
>> Miguel
>> On Jun 27, 2024, at 4:59 AM, Matthew Knepley <knepley at gmail.com> wrote:
>> Do you get output when you run an example with that option? Is it
>> possible that your current working directory is not what you expect? Maybe
>> try putting in an absolute path.
>> Thanks,
>> Matt
>> On Wed, Jun 26, 2024 at 5:30 PM MIGUEL MOLINOS PEREZ <mmolinos at us.es>
>> wrote:
>>> This Message Is From an External Sender
>>> This message came from outside your organization.
>>> Sorry, I did not put in cc petsc-users at mcs.anl.gov my replay.
>>> Miguel
>>> On Jun 24, 2024, at 6:39 PM, MIGUEL MOLINOS PEREZ <mmolinos at us.es>
>>> wrote:
>>> Thank you Barry,
>>> This is exactly how I did it the first time.
>>> Miguel
>>> On Jun 24, 2024, at 6:37 PM, Barry Smith <bsmith at petsc.dev> wrote:
>>> See, for example, the bottom of src/ts/tutorials/ex26.c that uses
>>> -ts_monitor_*solution_vtk* 'foo-%03d.vts'
>>> On Jun 24, 2024, at 8:47 PM, MIGUEL MOLINOS PEREZ <mmolinos at us.es>
>>> Dear all,
>>> I want to monitor the results at each iteration of TS using vtk format.
>>> To do so, I add the following lines to my Monitor function:
>>> char vts_File_Name[MAXC];
>>> PetscCall(PetscSNPrintf(vts_File_Name, sizeof(vts_File_Name),
>>> "./xi-MgHx-hcp-cube-x5-x5-x5-TS-BE-%i.vtu", step));
>>> PetscCall(TSMonitorSolutionVTK(ts, step, time, X, (void*)vts_File_Name
>>> My script compiles and executes without any sort of warning/error
>>> messages. However, no output files are produced at the end of the
>>> simulation. I’ve also tried the option “-ts_monitor_solution_vtk
>>> <filename-%03D.vts>”, but I got no results as well.
>>> I can’t find any similar example on the petsc website and I don’t see
>>> what I am doing wrong. Could somebody point me to the right direction?
>>> Thanks,
>>> Miguel
>> experiments lead.
>> -- Norbert Wiener
>> https://urldefense.us/v3/__https://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!c6MlkyvZFc8zu-D_Chh2KKned2NifwM1VkXSb9uEq_whB9rDSDhCEZNpbHt3eGv_MQCI6aR4dEHgyZlOgYlv$
>> <https://urldefense.us/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!c6MlkyvZFc8zu-D_Chh2KKned2NifwM1VkXSb9uEq_whB9rDSDhCEZNpbHt3eGv_MQCI6aR4dEHgyS793ANl$ >
> experiments lead.
> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
https://urldefense.us/v3/__https://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!c6MlkyvZFc8zu-D_Chh2KKned2NifwM1VkXSb9uEq_whB9rDSDhCEZNpbHt3eGv_MQCI6aR4dEHgyZlOgYlv$ <https://urldefense.us/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!c6MlkyvZFc8zu-D_Chh2KKned2NifwM1VkXSb9uEq_whB9rDSDhCEZNpbHt3eGv_MQCI6aR4dEHgyS793ANl$ >
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240702/ab4113d4/attachment-0001.html>
