[petsc-users] Question regarding naming of fieldsplit splits
    Blauth, Sebastian
    sebastian.blauth at itwm.fraunhofer.de
    Tue Jul  2 04:46:37 CDT 2024
Hi Matt,
thanks fort he answer and clarification. Then I’ll work around this issue in python, where I set the options.
Best,
Sebastian
Dr. Sebastian Blauth
Fraunhofer-Institut für
Techno- und Wirtschaftsmathematik ITWM
Abteilung Transportvorgänge
Fraunhofer-Platz 1, 67663 Kaiserslautern
Telefon: +49 631 31600-4968
sebastian.blauth at itwm.fraunhofer.de <mailto:sebastian.blauth at itwm.fraunhofer.de>
https://www.itwm.fraunhofer.de
Sent: Monday, July 1, 2024 4:30 PM
To: Blauth, Sebastian <sebastian.blauth at itwm.fraunhofer.de>
Cc: petsc-users at mcs.anl.gov
Subject: Re: [petsc-users] Question regarding naming of fieldsplit splits
On Mon, Jul 1, 2024 at 9:48 AM Blauth, Sebastian <sebastian.blauth at itwm.fraunhofer.de <mailto:sebastian.blauth at itwm.fraunhofer.de> > wrote:
Dear Matt,
thanks a lot for your help. Unfortunately, for me these extra options do not have any effect, I still get the “u” and “p” fieldnames. Also, this would not help me to get rid of the “c” fieldname – on that level of the fieldsplit I am basically using your approach already, and still it does show up. The output of the -ksp_view is unchanged, so that I do not attach it here again. Maybe I misunderstood you?
Oh, we make an exception for single fields, since we think you would want to use the name. I have to make an extra option to shut off naming.
     Matt
Thanks for the help and best regards,
Sebastian
From: Matthew Knepley <knepley at gmail.com <mailto:knepley at gmail.com> >
Sent: Monday, July 1, 2024 2:27 PM
To: Blauth, Sebastian <sebastian.blauth at itwm.fraunhofer.de <mailto:sebastian.blauth at itwm.fraunhofer.de> >
Cc: petsc-users at mcs.anl.gov <mailto:petsc-users at mcs.anl.gov>
On Fri, Jun 28, 2024 at 4:05 AM Blauth, Sebastian <sebastian.blauth at itwm.fraunhofer.de <mailto:sebastian.blauth at itwm.fraunhofer.de> > wrote:
Hello everyone,
I have a question regarding the naming convention using PETSc’s PCFieldsplit. I have been following https://lists.mcs.anl.gov/pipermail/petsc-users/2019-January/037262.html to create a DMShell with FEniCS in order to customize PCFieldsplit for my application.
I am using the following options, which work nicely for me:
-ksp_type fgmres
-pc_type fieldsplit
-pc_fieldsplit_0_fields 0, 1
-pc_fieldsplit_1_fields 2
-pc_fieldsplit_type additive
-fieldsplit_0_ksp_type fgmres
-fieldsplit_0_pc_type fieldsplit
-fieldsplit_0_pc_fieldsplit_type schur
-fieldsplit_0_pc_fieldsplit_schur_fact_type full
-fieldsplit_0_pc_fieldsplit_schur_precondition selfp
-fieldsplit_0_fieldsplit_u_ksp_type preonly
-fieldsplit_0_fieldsplit_u_pc_type lu
-fieldsplit_0_fieldsplit_p_ksp_type cg
-fieldsplit_0_fieldsplit_p_ksp_rtol 1e-14
-fieldsplit_0_fieldsplit_p_ksp_atol 1e-30
-fieldsplit_0_fieldsplit_p_pc_type icc
-fieldsplit_0_ksp_rtol 1e-14
-fieldsplit_0_ksp_atol 1e-30
-fieldsplit_0_ksp_monitor_true_residual
-fieldsplit_c_ksp_type preonly
-fieldsplit_c_pc_type lu
-ksp_view
By default, we use the field names, but you can prevent this by specifying the fields by hand, so
-fieldsplit_0_pc_fieldsplit_0_fields 0
-fieldsplit_0_pc_fieldsplit_1_fields 1
should remove the 'u' and 'p' fieldnames. It is somewhat hacky, but I think easier to remember than
some extra option.
     Matt
Note that this is just an academic example (sorry for the low solver tolerances) to test the approach, consisting of a Stokes equation and some concentration equation (which is not even coupled to Stokes, just for testing).
Completely analogous to https://lists.mcs.anl.gov/pipermail/petsc-users/2019-January/037262.html, I translate my IS’s to a PETSc Section, which is then supplied to a DMShell and assigned to a KSP. I am not so familiar with the code or how / why this works, but it seems to do so perfectly. I name my sections with petsc4py using
section.setFieldName(0, "u")
section.setFieldName(1, "p")
section.setFieldName(2, "c")
However, this is also reflected in the way I can access the fieldsplit options from the command line. My question is: Is there any way of not using the FieldNames specified in python but use the index of the field as defined with “-pc_fieldsplit_0_fields 0, 1” and “-pc_fieldsplit_1_fields 2”, i.e., instead of the prefix “fieldsplit_0_fieldsplit_u” I want to write “fieldsplit_0_fieldsplit_0”, instead of “fieldsplit_0_fieldsplit_p” I want to use “fieldsplit_0_fieldsplit_1”, and instead of “fieldsplit_c” I want to use “fieldsplit_1”. Just changing the names of the fields to
section.setFieldName(0, "0")
section.setFieldName(1, "1")
section.setFieldName(2, "2")
does obviously not work as expected, as it works for velocity and pressure, but not for the concentration – the prefix there is then “fieldsplit_2” and not “fieldsplit_1”. In the docs, I have found https://petsc.org/main/manualpages/PC/PCFieldSplitSetFields/ which seems to suggest that the fieldname can potentially be supplied, but I don’t see how to do so from the command line. Also, for the sake of completeness, I attach the output of the solve with “-ksp_view” below.
Thanks a lot in advance and best regards,
Sebastian
The output of ksp_view is the following:
KSP Object: 1 MPI processes
  type: fgmres
    restart=30, using Classical (unmodified) Gram-Schmidt Orthogonalization with no iterative refinement
    happy breakdown tolerance 1e-30
  maximum iterations=10000, initial guess is zero
  tolerances:  relative=1e-05, absolute=1e-11, divergence=10000.
  right preconditioning
  using UNPRECONDITIONED norm type for convergence test
PC Object: 1 MPI processes
  type: fieldsplit
    FieldSplit with ADDITIVE composition: total splits = 2
    Solver info for each split is in the following KSP objects:
  Split number 0 Defined by IS
  KSP Object: (fieldsplit_0_) 1 MPI processes
    type: fgmres
    tolerances:  relative=1e-14, absolute=1e-30, divergence=10000.
  PC Object: (fieldsplit_0_) 1 MPI processes
    type: fieldsplit
      FieldSplit with Schur preconditioner, factorization FULL
      Preconditioner for the Schur complement formed from Sp, an assembled approximation to S, which uses A00's diagonal's inverse
      Split info:
      Split number 1 Defined by IS
      KSP solver for A00 block
        KSP Object: (fieldsplit_0_fieldsplit_u_) 1 MPI processes
          type: preonly
          tolerances:  relative=1e-05, absolute=1e-50, divergence=10000.
          left preconditioning
          using NONE norm type for convergence test
        PC Object: (fieldsplit_0_fieldsplit_u_) 1 MPI processes
          type: lu
            out-of-place factorization
            tolerance for zero pivot 2.22045e-14
            matrix ordering: nd
            factor fill ratio given 5., needed 3.92639
              Factored matrix follows:
                Mat Object: 1 MPI processes
                  type: seqaij
                  rows=4290, cols=4290
                  package used to perform factorization: petsc
                  total: nonzeros=375944, allocated nonzeros=375944
                    using I-node routines: found 2548 nodes, limit used is 5
          linear system matrix = precond matrix:
          Mat Object: (fieldsplit_0_fieldsplit_u_) 1 MPI processes
            type: seqaij
            total: nonzeros=95748, allocated nonzeros=95748
            total number of mallocs used during MatSetValues calls=0
              using I-node routines: found 3287 nodes, limit used is 5
      KSP solver for S = A11 - A10 inv(A00) A01
        KSP Object: (fieldsplit_0_fieldsplit_p_) 1 MPI processes
          type: cg
          using PRECONDITIONED norm type for convergence test
        PC Object: (fieldsplit_0_fieldsplit_p_) 1 MPI processes
          type: icc
            0 levels of fill
            using Manteuffel shift [POSITIVE_DEFINITE]
            matrix ordering: natural
            factor fill ratio given 1., needed 1.
                  type: seqsbaij
                  rows=561, cols=561
                  total: nonzeros=5120, allocated nonzeros=5120
                      block size is 1
          linear system matrix followed by preconditioner matrix:
          Mat Object: (fieldsplit_0_fieldsplit_p_) 1 MPI processes
            type: schurcomplement
            rows=561, cols=561
              Schur complement A11 - A10 inv(A00) A01
              A11
                  type: seqaij
                  rows=561, cols=561
                  total: nonzeros=3729, allocated nonzeros=3729
                    not using I-node routines
              A10
                  type: seqaij
                  rows=561, cols=4290
                  total: nonzeros=19938, allocated nonzeros=19938
              KSP of A00
                  type: preonly
                  type: lu
                    matrix ordering: nd
                          type: seqaij
                    type: seqaij
              A01
                  type: seqaij
                  rows=4290, cols=561
            type: seqaij
            rows=561, cols=561
            total: nonzeros=9679, allocated nonzeros=9679
    Mat Object: (fieldsplit_0_) 1 MPI processes
      type: seqaij
      rows=4851, cols=4851
      total: nonzeros=139353, allocated nonzeros=139353
        using I-node routines: found 3830 nodes, limit used is 5
  KSP Object: (fieldsplit_c_) 1 MPI processes
    type: preonly
  PC Object: (fieldsplit_c_) 1 MPI processes
    type: lu
      matrix ordering: nd
      factor fill ratio given 5., needed 4.24323
            type: seqaij
            rows=561, cols=561
            total: nonzeros=15823, allocated nonzeros=15823
    Mat Object: (fieldsplit_c_) 1 MPI processes
      type: seqaij
      rows=561, cols=561
    type: seqaij
    rows=5412, cols=5412
    total: nonzeros=190416, allocated nonzeros=190416
      using I-node routines: found 3833 nodes, limit used is 5
-- Norbert Wiener
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240702/75fb260e/attachment-0001.html>
Type: application/pkcs7-signature
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240702/75fb260e/attachment-0001.p7s>
