[petsc-users] pc_redistribute issue
Barry Smith bsmith at petsc.dev
Mon Jan 29 11:55:09 CST 2024
Document the change in behavior for matrices with a block size greater than one
https://gitlab.com/petsc/petsc/-/merge_requests/7246
> On Jan 27, 2024, at 3:37 PM, Mark Adams <mfadams at lbl.gov> wrote:
> Note, pc_redistibute is a great idea but you lose the block size, which is obvious after you realize it, but is error prone.
> Maybe it would be better to throw an error if bs > 1 and add a -pc_redistribute_ignore_block_size or something for users that want to press on.
> Thanks,
> Mark
> On Sat, Jan 27, 2024 at 1:26 PM Mark Adams <mfadams at lbl.gov <mailto:mfadams at lbl.gov>> wrote:
>> Well, that puts the reason after the iterations, which is progress.
>> Oh, I see the preconditioned norm goes down a lot, but the reported residual that you would think is used for testing (see first post) does not go down 12 digits.
>> This matrix is very ill conditioned. LU just gets about 7 digits.
>> Thanks,
>> Mark
>> Residual norms for redistribute_ solve.
>>     0 KSP preconditioned resid norm 3.988887683909e+16 true resid norm 6.646245659859e+06 ||r(i)||/||b|| 1.000000000000e+00
>>     1 KSP preconditioned resid norm 3.257912040767e+02 true resid norm 1.741027565497e-04 ||r(i)||/||b|| 2.619565472898e-11
>>   Linear redistribute_ solve converged due to CONVERGED_RTOL iterations 1
>> KSP Object: (redistribute_) 1 MPI process
>>   type: gmres
>>     restart=30, using Classical (unmodified) Gram-Schmidt Orthogonalization with no iterative refinement
>>     happy breakdown tolerance 1e-30
>>   maximum iterations=10000, initial guess is zero
>>   tolerances:  relative=1e-12, absolute=1e-50, divergence=10000.
>>   left preconditioning
>>   using PRECONDITIONED norm type for convergence test
>> PC Object: (redistribute_) 1 MPI process
>>   type: bjacobi
>>     number of blocks = 1
>>     Local solver information for first block is in the following KSP and PC objects on rank 0:
>>     Use -redistribute_ksp_view ::ascii_info_detail to display information for all blocks
>>     KSP Object: (redistribute_sub_) 1 MPI process
>>       type: preonly
>>       tolerances:  relative=1e-05, absolute=1e-50, divergence=10000.
>>       using NONE norm type for convergence test
>>     PC Object: (redistribute_sub_) 1 MPI process
>>       type: lu
>>         out-of-place factorization
>>         tolerance for zero pivot 2.22045e-14
>>         matrix ordering: external
>>         factor fill ratio given 0., needed 0.
>>           Factored matrix follows:
>>             Mat Object: (redistribute_sub_) 1 MPI process
>>               type: mumps
>>               rows=44378, cols=44378
>>               package used to perform factorization: mumps
>>               total: nonzeros=50309372, allocated nonzeros=50309372
>>                 MUMPS run parameters:
>> On Sat, Jan 27, 2024 at 12:51 PM Matthew Knepley <knepley at gmail.com <mailto:knepley at gmail.com>> wrote:
>>> Okay, so the tolerance is right. It must be using ||b|| instead of ||r0||. Run with
>>>   -redistribute_ksp_monitor_true_residual
>>> You might have to force r0.
>>>   Thanks,
>>>      Matt
>>> On Sat, Jan 27, 2024 at 11:44 AM Mark Adams <mfadams at lbl.gov <mailto:mfadams at lbl.gov>> wrote:
>>>>   type: gmres
>>>>   type: bjacobi
>>>>       type: preonly
>>>>       type: lu
>>>> On Sat, Jan 27, 2024 at 10:24 AM Matthew Knepley <knepley at gmail.com <mailto:knepley at gmail.com>> wrote:
>>>>> View the solver.
>>>>>   Matt
>>>>> On Sat, Jan 27, 2024 at 9:43 AM Mark Adams <mfadams at lbl.gov <mailto:mfadams at lbl.gov>> wrote:
>>>>>> I am not getting ksp_rtol 1e-12 into pc_redistribute correctly?
>>>>>>   0 KSP Residual norm 2.182384017537e+02
>>>>>>   1 KSP Residual norm 1.889764161573e-04
>>>>>> Number of iterations =   1 N = 47628
>>>>>> Residual norm 8.65917e-07
>>>>>> #PETSc Option Table entries:
>>>>>> -f S.bin # (source: command line)
>>>>>> -ksp_monitor # (source: command line)
>>>>>> -ksp_type preonly # (source: command line)
>>>>>> -mat_block_size 36 # (source: command line)
>>>>>> -mat_view ascii::ascii_info # (source: command line)
>>>>>> -options_left # (source: command line)
>>>>>> -pc_type redistribute # (source: command line)
>>>>>> -redistribute_ksp_converged_reason # (source: command line)
>>>>>> -redistribute_ksp_rtol 1e-12 # (source: command line)
>>>>>> -redistribute_ksp_type gmres # (source: command line)
>>>>>> -redistribute_pc_type bjacobi # (source: command line)
>>>>>> -redistribute_sub_pc_factor_mat_solver_type mumps # (source: command line)
>>>>>> -redistribute_sub_pc_type lu # (source: command line)
>>>>>> #End of PETSc Option Table entries
>>>>>> There are no unused options.
>>>>> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
>>>>> -- Norbert Wiener
>>>>> https://www.cse.buffalo.edu/~knepley/ <http://www.cse.buffalo.edu/~knepley/>
>>> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240129/ab108c98/attachment.html>
