[petsc-users] Unique number in each element of a DMPlex mesh
Berend van Wachem berend.vanwachem at ovgu.de
Tue Jan 23 06:14:44 CST 2024
Dear Matt,
Please find attached a test for writing a DMPlex with hanging nodes,
which is based on a refined DMForest. I've linked the code with the
current main git version of Petsc.
When the DMPlex gets written to disc, the code crashes with
[0]PETSC ERROR: Unknown discretization type for field 0
although I specifically set the discretization for the DMPlex.
The DMPlex based on a DMForest has "double" faces when there is a jump
in cell size: the larger cell has one large face towards the refined
cells, and the adjacent 4 smaller cells each have a face as well.
I have written a function to remove the large face in such instances,
rebuilding the DM, which seems to work. But I can only do this on 1
process and therefore lose the connectivity between the DM and the
locations of the data points of the vector.
I can open an issue on the Petsc git, if you prefer?
Thanks and best regards,
Berend.
On 1/22/24 20:30, Matthew Knepley wrote:
> On Mon, Jan 22, 2024 at 2:26 PM Berend van Wachem
> <berend.vanwachem at ovgu.de <mailto:berend.vanwachem at ovgu.de>> wrote:
>     Dear Matt,
>     The problem is that I haven't figured out how to write a polyhedral
>     DMplex in parallel. So, currently, I can write the Vec data
>     in parallel, but the cones for the cells/faces/edges/nodes for the
>     mesh from just one process to a file (after gathering the
>     DMplex to a single process).
> Ah shoot. Can you send me a polyhedral mesh (or code to generate one) so
> I can fix the parallel write problem? Or maybe it is already an issue
> and I forgot?
>       From the restart, I can then read the cone information from one
>     process from the file, recreate the DMPlex, and then
>     redistribute it. In this scenario, the Vec data I read in (in
>     parallel) will not match the correct cells of the DMplex. Hence, I
>     need to put it in the right place afterwards.
> Yes, then searching makes sense. You could call DMLocatePoints(), but
> maybe you are doing that.
>    Thanks,
>       Matt
>     Best, Berend.
>     On 1/22/24 20:03, Matthew Knepley wrote:
>      > On Mon, Jan 22, 2024 at 1:57 PM Berend van Wachem
>     <mailto:berend.vanwachem at ovgu.de <mailto:berend.vanwachem at ovgu.de>>>
>     wrote:
>      >     Dear Matt,
>      >     Thanks for your quick response.
>      >     I have a DMPlex with a polyhedral mesh, and have defined a
>     number of vectors with data at the cell center. I have generated
>      >     data
>      >     for a number of timesteps, and I write the data for each
>     point to a file together with the (x,y,z) co-ordinate of the cell
>      >     center.
>      >     When I want to do a restart from the DMPlex, I recreate the
>     DMplex with the polyhedral mesh, redistribute it, and for each cell
>      >     center find the corresponding (x,y,z) co-ordinate and insert
>     the data that corresponds to it. This is quite expensive, as it
>      >     means I need to compare doubles very often.
>      >     But reading your response, this may not be a bad way of doing it?
>      > It always seems to be a game of "what do you want to assume?". I
>     tend to assume that I wrote the DM and Vec in the same order,
>      > so when I load them they match. This is how Firedrake I/O works,
>     so that you can load up on a different number of processes
>      > (https://arxiv.org/abs/2401.05868
>     <https://arxiv.org/abs/2401.05868> <https://arxiv.org/abs/2401.05868
>     <https://arxiv.org/abs/2401.05868>>).
>      > So, are you writing a Vec, and then redistributing and writing
>     another Vec? In the scheme above, you would have to write both
>      > DMs. Are you trying to avoid this?
>      >    Thanks,
>      >       Matt
>      >     Thanks,
>      >     Berend.
>      >     On 1/22/24 18:58, Matthew Knepley wrote:
>      >      > On Mon, Jan 22, 2024 at 10:49 AM Berend van Wachem
>     <mailto:berend.vanwachem at ovgu.de> <mailto:berend.vanwachem at ovgu.de
>     <mailto:berend.vanwachem at ovgu.de>>>> wrote:
>      >      >     Dear Petsc-Team,
>      >      >     Is there a good way to define a unique integer number
>     in each element
>      >      >     (e.g. a cell) of a DMPlex mesh, which is in the same
>     location,
>      >      >     regardless of the number of processors or the
>     distribution of the mesh
>      >      >     over the processors?
>      >      >     So, for instance, if I have a DMPlex box mesh, the
>     top-right-front
>      >      >     corner element (e.g. cell) will always have the same
>     unique number,
>      >      >     regardless of the number of processors the mesh is
>     distributed over?
>      >      >     I want to be able to link the results I have achieved
>     with a mesh from
>      >      >     DMPlex on a certain number of cores to the same mesh
>     from a DMPlex on a
>      >      >     different number of cores.
>      >      >     Of course, I could make a tree based on the distance
>     of each element to
>      >      >     a certain point (based on the X,Y,Z co-ordinates of
>     the element), and go
>      >      >     through this tree in the same way and define an
>     integer based on this,
>      >      >     but that seems rather cumbersome.
>      >      > I think this is harder than it sounds. The distance will
>     not work because it can be very degenerate.
>      >      > You could lexicographically sort the coordinates, but this
>     is hard in parallel. It is fine if you are willing
>      >      > to gather everything on one process. You could put down a
>     p4est, use the Morton order to number them since this is stable
>      >     for a
>      >      > given refinement. And then within each box
>     lexicographically sort the centroids. This is definitely cumbersome,
>     but I cannot
>      >      > think of anything else. This also might have parallel
>     problems since you need to know how much overlap you need to fill
>      >     each box.
>      >      >    Thanks,
>      >      >        Matt
>      >      >     Thanks and best regards, Berend.
>      >      > What most experimenters take for granted before they begin
>     their experiments is infinitely more interesting than any
>      >     results to
>      >      > which their experiments lead.
>      >      > -- Norbert Wiener
>      >      > https://www.cse.buffalo.edu/~knepley/
>     <https://www.cse.buffalo.edu/~knepley/>
>     <https://www.cse.buffalo.edu/~knepley/>>
>     <http://www.cse.buffalo.edu/~knepley/
>     <http://www.cse.buffalo.edu/~knepley/>
>     <http://www.cse.buffalo.edu/~knepley/>>>
>      > What most experimenters take for granted before they begin their
>     experiments is infinitely more interesting than any results to
>      > -- Norbert Wiener
> experiments is infinitely more interesting than any results to which
> -- Norbert Wiener
> https://www.cse.buffalo.edu/~knepley/ <http://www.cse.buffalo.edu/~knepley/>
Type: text/x-csrc
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240123/8b5e9ac3/attachment.bin>
