[petsc-users] Question about a parallel implementation of PCFIELDSPLIT
Pantelis Moschopoulos pmoschopoulos at outlook.com
Fri Jan 19 02:19:48 CST 2024
Dear all,
When I am using PCFIELDSPLIT and pc type "schur" in serial mode everything works fine. When I turn now to parallel, I observe that the number of ranks that I can use must divide the number of N without any remainder, where N is the number of unknowns. Otherwise, an error of the following form emerges: "Local columns of A10 3473 do not equal local rows of A00 3471".
Can I do something to overcome this?
Pantelis
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240119/ffd7b0cf/attachment.html>
