[petsc-users] Swarm view HDF5
    Matthew Knepley
    knepley at gmail.com
    Thu Jan 18 14:08:16 CST 2024
On Thu, Jan 18, 2024 at 1:20 PM Mark Adams <mfadams at lbl.gov> wrote:
> I had this working at one point.
> Should I add PetscViewerHDF5PushTimestepping?
> I don't create a viewer now, but I could make one.
That will make it work. The real fix would be to check at swarm.c:45 to see
whether timestepping is set.
    Matt
> Thanks,
> Mark
> On Thu, Jan 18, 2024 at 11:26 AM Matthew Knepley <knepley at gmail.com>
> wrote:
>> On Thu, Jan 18, 2024 at 10:08 AM Mark Adams <mfadams at lbl.gov> wrote:
>>> I am trying to view a DMSwarm with: -weights_view hdf5:part.h5
>>>      Vec f;
>>>       PetscCall(DMSetOutputSequenceNumber(sw, 0, 0.0));
>>>       PetscCall(DMSwarmCreateGlobalVectorFromField(sw, "w_q", &f));
>>>       PetscCall(PetscObjectSetName((PetscObject)f, "particle weights"));
>>>       PetscCall(VecViewFromOptions(f, NULL, "-weights_view"));
>>>       PetscCall(DMSwarmDestroyGlobalVectorFromField(sw, "w_q", &f));
>>> And I get this error. I had this working once and did not set
>>> PetscViewerHDF5PushTimestepping, so I wanted to check.
>> We probably were not checking then. We might have to check there when we
>> set the timestep.
>>   Thanks,
>>     Matt
>>> Thanks,
>>> Mark
>>> [0]PETSC ERROR: Object is in wrong state
>>> [0]PETSC ERROR: Timestepping has not been pushed yet. Call
>>> PetscViewerHDF5PushTimestepping() first
>>> [0]PETSC ERROR: WARNING! There are unused option(s) set! Could be the
>>> program crashed before usage or a spelling mistake, etc!
>>> [0]PETSC ERROR:   Option left: name:-options_left (no value) source:
>>> command line
>>> [0]PETSC ERROR: See https://petsc.org/release/faq/ for trouble shooting.
>>> [0]PETSC ERROR: Petsc Development GIT revision: v3.20.3-461-g585a01bd688
>>>  GIT Date: 2024-01-16 23:32:45 +0000
>>> [0]PETSC ERROR: ./ex30k on a arch-macosx-gnu-O named MarksMac-302.local
>>> by markadams Thu Jan 18 10:05:53 2024
>>> [0]PETSC ERROR: Configure options CFLAGS="-g
>>> -Wno-deprecated-declarations " CXXFLAGS="-g -Wno-deprecated-declarations "
>>> COPTFLAGS=-O CXXOPTFLAGS=-O --with-cc=/usr/local/opt/llvm/bin/clang
>>> --with-cxx=/usr/local/opt/llvm/bin/clang++ --download-mpich
>>> --with-strict-petscerrorcode --download-triangle=1 --with-debugging=0
>>> --download-hdf5=1 PETSC_ARCH=arch-macosx-gnu-O
>>> [0]PETSC ERROR: #1 PetscViewerHDF5SetTimestep() at
>>> /Users/markadams/Codes/petsc/src/sys/classes/viewer/impls/hdf5/hdf5v.c:990
>>> [0]PETSC ERROR: #2 VecView_Swarm_HDF5_Internal() at
>>> /Users/markadams/Codes/petsc/src/dm/impls/swarm/swarm.c:45
>>> [0]PETSC ERROR: #3 VecView_Swarm() at
>>> /Users/markadams/Codes/petsc/src/dm/impls/swarm/swarm.c:86
>>> [0]PETSC ERROR: #4 VecView() at
>>> /Users/markadams/Codes/petsc/src/vec/vec/interface/vector.c:806
>>> [0]PETSC ERROR: #5 PetscObjectView() at
>>> /Users/markadams/Codes/petsc/src/sys/objects/destroy.c:76
>>> [0]PETSC ERROR: #6 PetscObjectViewFromOptions() at
>>> /Users/markadams/Codes/petsc/src/sys/objects/destroy.c:128
>>> [0]PETSC ERROR: #7 VecViewFromOptions() at
>>> /Users/markadams/Codes/petsc/src/vec/vec/interface/vector.c:691
>> experiments lead.
>> -- Norbert Wiener
>> https://www.cse.buffalo.edu/~knepley/
>> <http://www.cse.buffalo.edu/~knepley/>
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240118/e89eb9b9/attachment-0001.html>
