[petsc-users] Neumann Boundary Condition with DMDACreate3D
Gourav Kumbhojkar gourav.kumbhojkar at gmail.com
Sun Jan 14 23:50:31 CST 2024
The fix works well. Sorry for the delayed update.
Thanks again.
Gourav
From: Gourav Kumbhojkar <gourav.kumbhojkar at gmail.com>
Date: Tuesday, January 9, 2024 at 11:50 PM
To: Barry Smith <bsmith at petsc.dev>
Cc: petsc-users at mcs.anl.gov <petsc-users at mcs.anl.gov>
Subject: Re: [petsc-users] Neumann Boundary Condition with DMDACreate3D
Thank you very much for the fix. I’ll also update here as soon as I test it on my application code.
Many thanks.
Gourav
Date: Tuesday, January 9, 2024 at 8:59 PM
To: Gourav Kumbhojkar <gourav.kumbhojkar at gmail.com>
  Sorry for the delay. The fix is in the git branch barry/2024-01-09/fix-mirror-dmda-3d/release   see also https://gitlab.com/petsc/petsc/-/merge_requests/7175
  Barry
On Jan 8, 2024, at 3:44 PM, Gourav Kumbhojkar <gourav.kumbhojkar at gmail.com> wrote:
You are right. Attaching the code that I’m using to test this.
The output matrix is saved in separate ascii files.
You can use “make noflux” to compile the code.
Gourav
From: Barry Smith <bsmith at petsc.dev<mailto:bsmith at petsc.dev>>
Date: Saturday, January 6, 2024 at 7:08 PM
To: Gourav Kumbhojkar <gourav.kumbhojkar at gmail.com<mailto:gourav.kumbhojkar at gmail.com>>
Cc: petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov> <petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>>
  If the mirror code for star stencil is just wrong in 3d we should simply fix it. Not use some other approach. Can you attach code that tries to do what you need for both 2d (that results in a matrix you are happy with) and 3d (that results in a matrix that you are not happy with).
  Barry
On Jan 6, 2024, at 7:30 PM, Gourav Kumbhojkar <gourav.kumbhojkar at gmail.com<mailto:gourav.kumbhojkar at gmail.com>> wrote:
Thank you, Barry. Sorry for the late response.
Yes, I was referring to the same text. I am using a star stencil. However, I don’t think the mirror condition is implemented for star stencil either.
TLDR version of the whole message typed below –
I think DM_BOUNDARY_GHOSTED is not implemented correctly in 3D. It appears that ghost nodes are mirrored with boundary nodes themselves. They should mirror with the nodes next to boundary.
Long version -
Here’s what I’m trying to do –
Step 1 - Create a 3D DM
ierr = DMDACreate3d(PETSC_COMM_WORLD, DM_BOUNDARY_MIRROR, DM_BOUNDARY_MIRROR, DM_BOUNDARY_MIRROR, DMDA_STENCIL_STAR, num_pts, num_pts, num_pts, PETSC_DECIDE, PETSC_DECIDE, PETSC_DECIDE, 1, 1, NULL, NULL, NULL, &da); CHKERRQ(ierr);
Note - num_pts = 4 in my code.
 Step 2 – Create a Matrix from DM ( a FDM stiffness matrix)
DMCreateMatrix(da, &K);
globalKMat(K, info);
“globalKMat” is a user-defined function. Here’s a snippet from this function:
for (int i = info.xs; i < (info.xs + info.xm); i++){
    for(int j = info.ys; j < (info.ys + info.ym); j++){
      for (int k = info.zs; k < (info.zs + info.zm); k++){
        ncols = 0;
        row.i = i; row.j = j; row.k = k;
        col[0].i = i; col[0].j = j; col[0].k = k;
        vals[ncols++] = -6.; //ncols=1
        col[ncols].i = i-1; col[ncols].j = j; col[ncols].k = k;
        vals[ncols++] = 1.;//ncols=2
There are total 7 “ncols”. Other than the first one all ncols have value 1 (first one is set to -6). As you can see, this step is to only build the FDM stiffness matrix. I use “ADD_VALUES” at the end in the above function.
Step 3 – View the stiffness matrix to check the values. I use MatView for this.
Here are the results –
  1.  3D DM (showing first few rows of the stiffness matrix here, the original matrix is 64x64)-
Mat Object: 1 MPI processes
  type: seqaij
row 0: (0, -3.)  (1, 1.)  (4, 1.)  (16, 1.)
row 1: (0, 1.)  (1, -4.)  (2, 1.)  (5, 1.)  (17, 1.)
row 2: (1, 1.)  (2, -4.)  (3, 1.)  (6, 1.)  (18, 1.)
row 3: (2, 1.)  (3, -3.)  (7, 1.)  (19, 1.)
row 4: (0, 1.)  (4, -4.)  (5, 1.)  (8, 1.)  (20, 1.)
row 5: (1, 1.)  (4, 1.)  (5, -5.)  (6, 1.)  (9, 1.)  (21, 1.)
  1.  Repeat the same steps for a 2D DM to show the difference (the entire matrix is now 16x16)
  type: seqaij
row 0: (0, -4.)  (1, 2.)  (4, 2.)
row 1: (0, 1.)  (1, -4.)  (2, 1.)  (5, 2.)
row 2: (1, 1.)  (2, -4.)  (3, 1.)  (6, 2.)
row 3: (2, 2.)  (3, -4.)  (7, 2.)
row 4: (0, 1.)  (4, -4.)  (5, 2.)  (8, 1.)
row 5: (1, 1.)  (4, 1.)  (5, -4.)  (6, 1.)  (9, 1.)
I suspect that when using “DM_BOUNDARY_MIRROR” in 3D, the ghost node value is added to the boundary node itself, which would explain why row 0 of the stiffness matrix has -3 instead of -6. In principle the ghost node value should be mirrored with the node next to boundary.
Clearly, there’s no issue with the 2D implementation of the mirror boundary. The row 0 values are -4, 2, and 2 as expected.
Let me know if I should give any other information about this. I also thought about using DM_BOUNDARY_GHOSTED and implement the mirror boundary in 3D from scratch but I would really appreciate some resources on how to do that.
Thank you.
Gourav
Date: Thursday, January 4, 2024 at 12:24 PM
   Are you referring to the text?
. `DM_BOUNDARY_MIRROR` - the ghost value is the same as the value 1 grid point in; that is, the 0th grid point in the real mesh acts like a mirror to define
                         the ghost point value; not yet implemented for 3d
  Looking at the code for DMSetUp_DA_3D() I see
  PetscCheck(stencil_type != DMDA_STENCIL_BOX || (bx != DM_BOUNDARY_MIRROR && by != DM_BOUNDARY_MIRROR && bz != DM_BOUNDARY_MIRROR), PetscObjectComm((PetscObject)da), PETSC_ERR_SUP, "Mirror boundary and box stencil");
which seems (to me) to indicate the mirroring is not done for box stencils but should work for star stencils.
Are you using a star stencil or a box stencil?
I believe the code is not complete for box stencil because the code to determine the location of the "mirrored point" for extra "box points" is messy in 3d and no one wrote it. You can compare DMSetUp_DA_2D() and DMSetUp_DA_3D() to see what is missing and see if you can determine how to add it for 3d.
  Barry
On Jan 4, 2024, at 1:08 PM, Gourav Kumbhojkar <gourav.kumbhojkar at gmail.com<mailto:gourav.kumbhojkar at gmail.com>> wrote:
I am trying to implement a No-flux boundary condition for a 3D domain. I previously modeled a no flux boundary in 2D domain using DMDACreate2D and “PETSC_BOUNDARY_MIRROR” which worked well.
However, the manual pages say that the Mirror Boundary is not supported for 3D.
Could you please point me to the right resources to implement no flux boundary condition in 3D domains?
Gourav K.
<noflux_check.c><makefile>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240115/9561d243/attachment-0001.html>
