[petsc-users] [Gmsh] Access both default sets and region names
Matthew Knepley
knepley at gmail.com
Fri Jan 12 08:59:53 CST 2024
On Fri, Jan 12, 2024 at 5:26 AM Noam T. <dontbugthedevs at proton.me> wrote:
> Great.
> Thank you very much for the quick replies.
It has now merged to the main branch.
Matt
> Noam
> On Thursday, January 11th, 2024 at 9:34 PM, Matthew Knepley <
> knepley at gmail.com> wrote:
> On Thu, Jan 11, 2024 at 12:53 PM Noam T. <dontbugthedevs at proton.me> wrote:
>> There could be some overlapping/redundancy between the default and the
>> user-defined groups, so perhaps that was the intended behavior. Glad to
>> hear it's possible to have access to everything.
> Here is the MR: https://gitlab.com/petsc/petsc/-/merge_requests/7178
> If you build that branch, you can use -dm_plex_gmsh_use_generic to turn on
> those labels.
> Thanks,
> Matt
>> Thanks,
>> Noam
>> On Thursday, January 11th, 2024 at 6:31 PM, Matthew Knepley <
>> On Thu, Jan 11, 2024 at 11:59 AM Noam T. <dontbugthedevs at proton.me>
>> wrote:
>>> Without using the flag -dm_plex_gmsh_use_regions, the DMGetNumLabels
>>> says there are 5, named celltype, depth, cell/face/vertex sets.
>>> With the flag, the labels are celltype, depth, my_vol, my_surface (using
>>> the same example as before).
>>> Am I misusing the flag somehow, and I should be able to access those of
>>> cell/face/vertex as well?
>> Shoot, yes this changed after another request. Yes, we can put in a flag
>> for that. Should not take long.
>> Thanks,
>> Matt
>>> PS: Using PETSc 3.20.3
>>> Thanks,
>>> Noam
>>> On Thursday, January 11th, 2024 at 5:28 PM, Matthew Knepley <
>>> On Thu, Jan 11, 2024 at 11:18 AM Noam T. via petsc-users <
>>> petsc-users at mcs.anl.gov> wrote:
>>>> Would it be feasible to have an option (e.g. new flag along the lines
>>>> of -dm_plex_gmsh_...) that allows the user to access both the default sets
>>>> (Cell / Face / Vertex) together with user-defined gorups (those under
>>>> $PhysicalNames, available when using -dm_plex_gmsh_use_regions)?
>>> I am not sure I understand the question. When you turn on regions, it
>>> makes extra labels, but the generic labels still exist.
>>> Thanks,
>>> Matt
>>>> That is, with a *.msh file containing
>>>> $PhysicalNames
>>>> 2
>>>> 2 100 "my_surface"
>>>> 3 200 "my_vol"
>>>> the return of DMGetLabelName(dm, n, name) would be (order may differ)
>>>> n = 0, name = "celltype"
>>>> n = 1, name = "depth"
>>>> n = 2, name = "Cell Sets"
>>>> n = 3, name = "my_vol"
>>>> n = 4, name = "Face Sets"
>>>> n = 5, name = "my_surface"
>>>> I poked into src/dm/impls/plex/plexgmsh.c and have managed to print all
>>>> the labels after changing a couple of variable values, so perhaps it is
>>>> doable.
>>>> The changes made are not a solution, simply naively set some variables
>>>> to skip checking for the use_regions flag, so it understandably crashes
>>>> soon after.
>>>> Thanks, Noam
>>> What most experimenters take for granted before they begin their
>>> experiments is infinitely more interesting than any results to which their
>>> experiments lead.
>>> -- Norbert Wiener
>>> https://www.cse.buffalo.edu/~knepley/
>>> <http://www.cse.buffalo.edu/~knepley/>
>> experiments lead.
>> -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240112/aae8e97f/attachment.html>
