[petsc-users] [Gmsh] Access both default sets and region names
Thu Jan 11 14:34:36 CST 2024
On Thu, Jan 11, 2024 at 12:53 PM Noam T. <dontbugthedevs at proton.me> wrote:
> There could be some overlapping/redundancy between the default and the
> user-defined groups, so perhaps that was the intended behavior. Glad to
> hear it's possible to have access to everything.
Here is the MR: https://gitlab.com/petsc/petsc/-/merge_requests/7178
If you build that branch, you can use -dm_plex_gmsh_use_generic to turn on
those labels.
     Matt
> Thanks,
> Noam
> On Thursday, January 11th, 2024 at 6:31 PM, Matthew Knepley <
> knepley at gmail.com> wrote:
> On Thu, Jan 11, 2024 at 11:59 AM Noam T. <dontbugthedevs at proton.me> wrote:
>> Without using the flag -dm_plex_gmsh_use_regions, the DMGetNumLabels
>> says there are 5, named celltype, depth, cell/face/vertex sets.
>> With the flag, the labels are celltype, depth, my_vol, my_surface (using
>> the same example as before).
>> Am I misusing the flag somehow, and I should be able to access those of
>> cell/face/vertex as well?
> Shoot, yes this changed after another request. Yes, we can put in a flag
> for that. Should not take long.
> Thanks,
> Matt
>> PS: Using PETSc 3.20.3
>> Thanks,
>> Noam
>> On Thursday, January 11th, 2024 at 5:28 PM, Matthew Knepley <
>> On Thu, Jan 11, 2024 at 11:18 AM Noam T. via petsc-users <
>> petsc-users at mcs.anl.gov> wrote:
>>> Would it be feasible to have an option (e.g. new flag along the lines of
>>> -dm_plex_gmsh_...) that allows the user to access both the default sets
>>> (Cell / Face / Vertex) together with user-defined gorups (those under
>>> $PhysicalNames, available when using -dm_plex_gmsh_use_regions)?
>> I am not sure I understand the question. When you turn on regions, it
>> makes extra labels, but the generic labels still exist.
>> Thanks,
>> Matt
>>> That is, with a *.msh file containing
>>> $PhysicalNames
>>> 2
>>> 2 100 "my_surface"
>>> 3 200 "my_vol"
>>> the return of DMGetLabelName(dm, n, name) would be (order may differ)
>>> n = 0, name = "celltype"
>>> n = 1, name = "depth"
>>> n = 2, name = "Cell Sets"
>>> n = 3, name = "my_vol"
>>> n = 4, name = "Face Sets"
>>> n = 5, name = "my_surface"
>>> I poked into src/dm/impls/plex/plexgmsh.c and have managed to print all
>>> the labels after changing a couple of variable values, so perhaps it is
>>> doable.
>>> The changes made are not a solution, simply naively set some variables
>>> to skip checking for the use_regions flag, so it understandably crashes
>>> soon after.
>>> Thanks, Noam
>> experiments lead.
>> -- Norbert Wiener
>> https://www.cse.buffalo.edu/~knepley/
>> <http://www.cse.buffalo.edu/~knepley/>
> experiments lead.
> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240111/59f68aad/attachment.html>
