[petsc-users] [Gmsh] Access both default sets and region names
Matthew Knepley
knepley at gmail.com
Thu Jan 11 11:31:33 CST 2024
On Thu, Jan 11, 2024 at 11:59 AM Noam T. <dontbugthedevs at proton.me> wrote:
> Without using the flag -dm_plex_gmsh_use_regions, the DMGetNumLabels says
> there are 5, named celltype, depth, cell/face/vertex sets.
> With the flag, the labels are celltype, depth, my_vol, my_surface (using
> the same example as before).
> Am I misusing the flag somehow, and I should be able to access those of
> cell/face/vertex as well?
Shoot, yes this changed after another request. Yes, we can put in a flag
for that. Should not take long.
Matt
> PS: Using PETSc 3.20.3
> Thanks,
> Noam
> On Thursday, January 11th, 2024 at 5:28 PM, Matthew Knepley <
> knepley at gmail.com> wrote:
> On Thu, Jan 11, 2024 at 11:18 AM Noam T. via petsc-users <
> petsc-users at mcs.anl.gov> wrote:
>> Would it be feasible to have an option (e.g. new flag along the lines of
>> -dm_plex_gmsh_...) that allows the user to access both the default sets
>> (Cell / Face / Vertex) together with user-defined gorups (those under
>> $PhysicalNames, available when using -dm_plex_gmsh_use_regions)?
> I am not sure I understand the question. When you turn on regions, it
> makes extra labels, but the generic labels still exist.
> Thanks,
> Matt
>> That is, with a *.msh file containing
>> $PhysicalNames
>> 2
>> 2 100 "my_surface"
>> 3 200 "my_vol"
>> the return of DMGetLabelName(dm, n, name) would be (order may differ)
>> n = 0, name = "celltype"
>> n = 1, name = "depth"
>> n = 2, name = "Cell Sets"
>> n = 3, name = "my_vol"
>> n = 4, name = "Face Sets"
>> n = 5, name = "my_surface"
>> I poked into src/dm/impls/plex/plexgmsh.c and have managed to print all
>> the labels after changing a couple of variable values, so perhaps it is
>> doable.
>> The changes made are not a solution, simply naively set some variables to
>> skip checking for the use_regions flag, so it understandably crashes soon
>> after.
>> Thanks, Noam
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240111/0fdb4efc/attachment.html>
