[petsc-users] petsc-users Digest, Vol 181, Issue 9
Khaled Nabil Shar Abdelaziz kabdelaz at purdue.edu
Sun Jan 7 16:06:15 CST 2024
Issue resolved, stopped using the vector in the struct and used the one in the arguments. Same issue was taking place in the Jacobian function which resulted in error (-8) SNES_DIVERGED_LOCAL_MIN. Adjusting the jacobian function resolved that issue as well.
-----Original Message-----
From: petsc-users <petsc-users-bounces at mcs.anl.gov> On Behalf Of petsc-users-request at mcs.anl.gov
Sent: Sunday, January 7, 2024 3:52 PM
To: petsc-users at mcs.anl.gov
Subject: petsc-users Digest, Vol 181, Issue 9
---- External Email: Use caution with attachments, links, or sharing data ----
Send petsc-users mailing list submissions to
To subscribe or unsubscribe via the World Wide Web, visit
        https://lists.mcs.anl.gov/mailman/listinfo/petsc-users
or, via email, send a message with subject or body 'help' to
You can reach the person managing the list at
        petsc-users-owner at mcs.anl.gov
When replying, please edit your Subject line so it is more specific than "Re: Contents of petsc-users digest..."
Today's Topics:
   1.  SNES solve residual vector - Fortran
      (Khaled Nabil Shar Abdelaziz)
Message: 1
Date: Sun, 7 Jan 2024 20:51:33 +0000
From: Khaled Nabil Shar Abdelaziz <kabdelaz at purdue.edu>
To: "petsc-users at mcs.anl.gov" <petsc-users at mcs.anl.gov>
Subject: [petsc-users] SNES solve residual vector - Fortran
Message-ID:
        <PH7PR22MB363758580C91A9958802A9C6BD642 at PH7PR22MB3637.namprd22.prod.outlook.com>
Content-Type: text/plain; charset="us-ascii"
Hello everyone,
I am running into an issue with SNES solver where the residual in the first iteration gets calculated fine, but on the 2nd iteration, even though it is getting calculated locally, it doesn't seem to be "assigned" to the residual vector correctly.
The residual vector here is referred to as petsc_PVector which is defined in a type (struct). It seems like the first iteration, it behaves as expected and that petsc_PVector gets updated, 2nd iteration however seems like there are 2 versions of it; one that is being passed into FormFunctionU, and another that exists in the type (struct). This result in the residual on the 2nd iteration to be exactly = 0 and convergence.
Any insights, suggestions, or experiences you can share regarding this issue would be immensely appreciated. I'm particularly interested in understanding why the residual vector behaves differently in the second iteration.
Best,
Khaled
The following is a snapshot of how I initialize and use SNES:
    subroutine set_function_jacobian_to_solver_u(nlU)
        type(variable_node_u),target,intent(inout)::nlU
        PetscErrorCode::ierr
        type(variable_node_part),pointer::var_nd_part
        integer::ipart
        ! external FormFunctionU,FormJacobianU
        do ipart=1,nlU%variable_node%npart
            var_nd_part=>nlU%variable_node%parts(ipart)
            PetscCallA(SNESSetFunction(var_nd_part%petsc_snes,var_nd_part%petsc_PVector,FormFunctionU,nlU,ierr))
            PetscCallA(SNESSetJacobian(var_nd_part%petsc_snes,var_nd_part%petsc_KMatrix,var_nd_part%petsc_KMatrix,FormJacobianU,nlU,ierr))
            PetscCallA(SNESSetFromOptions(var_nd_part%petsc_snes,ierr))
        end do
        var_nd_part=>null()
    end subroutine set_function_jacobian_to_solver_u
    subroutine FormFunctionU(petsc_snes,petsc_vector,petsc_PVector,nlU,ierr)
        type(tSNES)::petsc_snes
        type(tVec)::petsc_vector
        type(tVec)::petsc_PVector
        type(PetscScalar),pointer::vec_ptr_a(:),vec_ptr_b(:)
        type(variable_node_u),target::nlU
        type(PetscScalar),pointer::val_petsc_PVector(:)
        type(parameter),pointer::para_data
        type(mesh),pointer::mesh_data
        type(element),pointer::eles(:)
        integer::k,i,flag,pid
        PetscInt::its
        para_data=>nlU%para_data
        mesh_data=>nlU%mesh_data
        eles=>nlU%eles
        call MPI_Comm_rank(MPI_COMM_WORLD, pid, ierr)
        call update_data_by_petsc_vector(nlU%variable_node,petsc_vector)
        call set_petsc_PVector_to_zero(nlU%variable_node)
        call update_petsc_PVector(nlU%variable_node)
        flag = 0
        do k=1,mesh_data%nel
            call get_element_value(nlU%data_e, eles(k)%nnd_e, mesh_data%elements(:,k), nlU%nvar_total, nlU%data)
            call cal_element_ResidualU(nlU%PVector_e, eles(k), nlU%data_e, para_data)
            call set_petsc_PVector_values_by_element(nlU%variable_node, nlU%PVector_e, eles(k)%nnd_e, mesh_data%elements(:,k))
        end do
        para_data=>null()
        mesh_data=>null()
        eles=>null()
        return
    end subroutine FormFunctionU
                call SNESSolve(nlU%variable_node%petsc_snes,PETSC_NULL_VEC, nlU%variable_node%petsc_vector,error_petsc)
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240107/683fa2d8/attachment.html>
Subject: Digest Footer
End of petsc-users Digest, Vol 181, Issue 9
