[petsc-users] Help with Integrating PETSc into Fortran Groundwater Flow Simulation Code
Mark Adams
mfadams at lbl.gov
Fri Jan 5 06:53:03 CST 2024
This is a segv. As Matt said, you need to use a debugger for this or add
print statements to narrow down the place where this happens.
You will need to learn how to use debuggers to do your project so you might
as well start now.
If you have a machine with a GUI debugger that is easier but command line
debuggers are good to learn anyway.
I tend to run debuggers directly (eg, lldb ./a.out -- program-args ...) and
use a GUI debugger (eg, Totalview or DDT) if available.
On Wed, Dec 20, 2023 at 10:02 PM Shatanawi, Sawsan Muhammad via petsc-users
<petsc-users at mcs.anl.gov> wrote:
> Hello Matthew,
> Thank you for your help. I am sorry that I keep coming back with my error
> messages, but I reached a point that I don't know how to fix them, and I
> don't understand them easily.
> The list of errors is getting shorter, now I am getting the attached error
> messages
> Thank you again,
> Sawsan
> *From:* Matthew Knepley <knepley at gmail.com>
> *Sent:* Wednesday, December 20, 2023 6:54 PM
> *To:* Shatanawi, Sawsan Muhammad <sawsan.shatanawi at wsu.edu>
> *Cc:* Barry Smith <bsmith at petsc.dev>; petsc-users at mcs.anl.gov <
> *Subject:* Re: [petsc-users] Help with Integrating PETSc into Fortran
> *[EXTERNAL EMAIL]*
> On Wed, Dec 20, 2023 at 9:49 PM Shatanawi, Sawsan Muhammad via petsc-users
> Hello Barry,
> Thank you a lot for your help, Now I am getting the attached error message.
> Do not destroy the PC from KSPGetPC()
> THanks,
> Matt
> Bests,
> Sawsan
> *From:* Barry Smith <bsmith at petsc.dev>
> *Sent:* Wednesday, December 20, 2023 6:32 PM
> *Cc:* Mark Adams <mfadams at lbl.gov>; petsc-users at mcs.anl.gov <
> *[EXTERNAL EMAIL]*
> Instead of
> call PCCreate(PETSC_COMM_WORLD, pc, ierr)
> call PCSetType(pc, PCILU,ierr) ! Choose a preconditioner type (ILU)
> call KSPSetPC(ksp, pc,ierr) ! Associate the preconditioner with the
> KSP solver
> do
> call KSPGetPC(ksp,pc,ierr)
> Do not call KSPSetUp(). It will be taken care of automatically during the
> solve
> On Dec 20, 2023, at 8:52 PM, Shatanawi, Sawsan Muhammad via petsc-users <
> Hello,
> I don't think that I set preallocation values when I created the matrix,
> would you please have look at my code. It is just the petsc related part
> from my code.
> I was able to fix some of the error messages. Now I have a new set of
> error messages related to the KSP solver (attached)
> I appreciate your help
> Sawsan
> *From:* Mark Adams <mfadams at lbl.gov>
> *Sent:* Wednesday, December 20, 2023 6:44 AM
> *Cc:* petsc-users at mcs.anl.gov <petsc-users at mcs.anl.gov>
> *[EXTERNAL EMAIL]*
> Did you set preallocation values when you created the matrix?
> Don't do that.
> On Wed, Dec 20, 2023 at 9:36 AM Shatanawi, Sawsan Muhammad <
> sawsan.shatanawi at wsu.edu> wrote:
> Hello,
> I am trying to create a sparse matrix( which is as I believe a zero
> matrix) then adding some nonzero elements to it over a loop, then
> assembling it
> Get Outlook for iOS
> <https://urldefense.com/v3/__https://aka.ms/o0ukef__;!!JmPEgBY0HMszNaDT!uUJ_jeYf45gcXDGR_PeMjhU7hbd_fKcXJPn0pM9eb-YQihKNYuXMYM9x-hglsbXsCFIwNBWgHXdetHODupsOloE$>
> *Sent:* Wednesday, December 20, 2023 2:48 AM
> *[EXTERNAL EMAIL]*
> I am guessing that you are creating a matrix, adding to it, finalizing it
> ("assembly"), and then adding to it again, which is fine, but you are
> adding new non-zeros to the sparsity pattern.
> If this is what you want then you can tell the matrix to let you do that.
> Otherwise you have a bug.
> Mark
> On Tue, Dec 19, 2023 at 9:50 PM Shatanawi, Sawsan Muhammad via petsc-users
> Hello everyone,
> I hope this email finds you well.
> My Name is Sawsan Shatanawi, and I am currently working on developing a
> Fortran code for simulating groundwater flow in a 3D system. The code
> involves solving a nonlinear system, and I have created the matrix to be
> solved using the PCG solver and Picard iteration. However, when I tried
> to assign it as a PETSc matrix I started getting a lot of error messages.
> I am kindly asking if someone can help me, I would be happy to share my
> code with him/her.
> Please find the attached file contains a list of errors I have gotten
> Thank you in advance for your time and assistance.
> Best regards,
> Sawsan
> <Matrix_RHS.F90><out.txt><solver.F90>
> experiments lead.
> -- Norbert Wiener
> <https://urldefense.com/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!JmPEgBY0HMszNaDT!uskvAyF0pMMWDbMIexr9g4qN46V7Rea17GQdNIVG2vH_HMaX7mXgie4ZYgusmPpss_DS7H1_8vn8arGQNSkC$>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240105/55abbadf/attachment-0001.html>
