[petsc-users] Hypre freezing with Mat type mpiaij and Vec type mpi
Mark Adams
mfadams at lbl.gov
Fri Jan 5 06:46:47 CST 2024
On Fri, Jan 5, 2024 at 5:40 AM Edoardo Centofanti <
edoardo.centofanti01 at universitadipavia.it> wrote:
> Dear all,
> I have a code running both on GPU and CPU. This code has both cuda kernels
> and calls to PETSc KSP and related PC. In particular, I am trying to
> perform tests with Hypre BoomerAMG both on CPU and GPU. In order to do
> that, on CPU I am running the code with -mat_type mpiaij and -vec_type mpi,
> while on GPU I am using respectively aijcusparse and cuda.
> The configuration ran for PETSc (version is 3.20) is
> ./configure PETSC_ARCH=arch-linux-cuda --with-cuda --download-mumps
> --download-hypre --with-debugging=0 --download-scalapack
> --download-parmetis --download-metis --download-fblaslapack=1
> --download-mpich --download-make --download-cmake
> My problem is that when I try to run my code on GPU it works well, while
> on CPU with mat_type mpiaij and -vec_type mpi it works regularly until the
> call to Hypre, then freezes (I have to kill it myself), while with GAMG it
> works on CPU with the same configuration (and the same code, just PC is
> changed).
> On another machine running PETSc version 3.17 everything worked smoothly
> with the same code and the same configuration, also on Hypre.
Can you reproduce this error on this machine with 3.20?
If yes you do a git bisect to find the commit that causes this. That would
be a good start.
A stack trace would be helpful. You can run this in a debugger and see
where you are hung.
A GUI debugger is best for this (DDT or Totalview) but a command line
debugger is fine if you can do this in a serial run (Control-C will stop
the code and give you a prompt and you can then see the stack).
> Do you have any insights on what is happening?
> Best regards,
> Edoardo
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240105/15fed733/attachment-0001.html>
