[petsc-users] Near nullspace lost in fieldsplit
Jeremy Theler (External) jeremy.theler-ext at ansys.com
Fri Feb 9 06:04:24 CST 2024
Hi all
Because of a combination of settings, our code passes through this line:
https://gitlab.com/petsc/petsc/-/blob/main/src/ksp/pc/impls/fieldsplit/fieldsplit.c?ref_type=heads#L692
i.e. the matrices associated with each of the sub-KSPs of a fieldsplit are destroyed and then re-created later.
The thing is that one of these destroyed matrices had a near nullspace attached, which is lost because the new matrix does not have it anymore.
Is this a bug or are we missing something?
I'll need some time to come up with a MWE showing how the near nullspace is lost, but if its needed I can take a stab at it.
jeremy
[https://gitlab.com/uploads/-/system/project/avatar/13882401/PETSc_RBG-logo.png]<https://gitlab.com/petsc/petsc/-/blob/main/src/ksp/pc/impls/fieldsplit/fieldsplit.c?ref_type=heads#L692>
src/ksp/pc/impls/fieldsplit/fieldsplit.c · main · PETSc / petsc · GitLab<https://gitlab.com/petsc/petsc/-/blob/main/src/ksp/pc/impls/fieldsplit/fieldsplit.c?ref_type=heads#L692>
PETSc, pronounced PET-see (the S is silent), is a suite of data structures and routines for the scalable (parallel) solution of scientific applications modeled by partial differential equations.
gitlab.com
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240209/fb0142b5/attachment.html>
