[petsc-users] question on PCLSC with matrix blocks of type MATNEST
Zhang, Hong
hzhang at mcs.anl.gov
Thu Feb 8 10:37:38 CST 2024
Hana,
"product AB with A nest, B nest" is not supported by PETSc. I do not know why PETSc does not display such an error message. I'll check it.
Hong
From: petsc-users <petsc-users-bounces at mcs.anl.gov> on behalf of Hana Honnerová <hhornik at kma.zcu.cz>
Sent: Thursday, February 8, 2024 4:45 AM
To: petsc-users at mcs.anl.gov <petsc-users at mcs.anl.gov>
Subject: [petsc-users] question on PCLSC with matrix blocks of type MATNEST
Hi all,
I am trying to solve linear systems arising from isogeometric discretization (similar to FEM) of the Navier-Stokes equations in parallel using PETSc. The linear systems are of saddle-point type, so I would like to use the PCFIELDSPLIT preconditioner with the -pc_fieldsplit_detect_saddle_point option, Schur complement factorization and the LSC Schur complement preconditioner. I do not provide any user-defined operators for PCLSC in my codes (at least for now).
I store the matrix as a MATNEST consisting of 4 blocks (F for velocity-velocity part, Bt for velocity-pressure part, B for pressure-velocity part and NULL for pressure-pressure part). It is also convenient for me to store the blocks F, Bt and B as another MATNEST consisting of blocks corresponding to individual velocity components.
However, in this setting, I get the following error message:
[0]PETSC ERROR: Petsc has generated inconsistent data
[0]PETSC ERROR: Unspecified symbolic phase for product AB with A nest, B nest. Call MatProductSetFromOptions() first
[0]PETSC ERROR: See https://petsc.org/release/faq/ for trouble shooting.
[0]PETSC ERROR: Petsc Release Version 3.20.4, unknown
[0]PETSC ERROR: /home/hhornik/gismo/build-petsc-mpi/RelWithDebInfo/bin/gsINSSolverPETScTest on a arch-debug named ThinkPad-T14 by hhornik Thu Feb 8 11:04:17 2024
[0]PETSC ERROR: Configure options PETSC_ARCH=arch-debug --with-debugging=1 --download-mumps --download-scalapack
[0]PETSC ERROR: #1 MatProductSymbolic() at /home/hhornik/Software/PETSc/src/mat/interface/matproduct.c:807
[0]PETSC ERROR: #2 MatProduct_Private() at /home/hhornik/Software/PETSc/src/mat/interface/matrix.c:10027
[0]PETSC ERROR: #3 MatMatMult() at /home/hhornik/Software/PETSc/src/mat/interface/matrix.c:10103
[0]PETSC ERROR: #4 PCSetUp_LSC() at /home/hhornik/Software/PETSc/src/ksp/pc/impls/lsc/lsc.c:79
[0]PETSC ERROR: #5 PCSetUp() at /home/hhornik/Software/PETSc/src/ksp/pc/interface/precon.c:1080
[0]PETSC ERROR: #6 KSPSetUp() at /home/hhornik/Software/PETSc/src/ksp/ksp/interface/itfunc.c:415
[0]PETSC ERROR: #7 KSPSolve_Private() at /home/hhornik/Software/PETSc/src/ksp/ksp/interface/itfunc.c:832
[0]PETSC ERROR: #8 KSPSolve() at /home/hhornik/Software/PETSc/src/ksp/ksp/interface/itfunc.c:1079
[0]PETSC ERROR: #9 PCApply_FieldSplit_Schur() at /home/hhornik/Software/PETSc/src/ksp/pc/impls/fieldsplit/fieldsplit.c:1165
[0]PETSC ERROR: #10 PCApply() at /home/hhornik/Software/PETSc/src/ksp/pc/interface/precon.c:498
[0]PETSC ERROR: #11 KSP_PCApply() at /home/hhornik/Software/PETSc/include/petsc/private/kspimpl.h:383
[0]PETSC ERROR: #12 KSPFGMRESCycle() at /home/hhornik/Software/PETSc/src/ksp/ksp/impls/gmres/fgmres/fgmres.c:123
[0]PETSC ERROR: #13 KSPSolve_FGMRES() at /home/hhornik/Software/PETSc/src/ksp/ksp/impls/gmres/fgmres/fgmres.c:235
[0]PETSC ERROR: #14 KSPSolve_Private() at /home/hhornik/Software/PETSc/src/ksp/ksp/interface/itfunc.c:906
[0]PETSC ERROR: #15 KSPSolve() at /home/hhornik/Software/PETSc/src/ksp/ksp/interface/itfunc.c:1079
[0]PETSC ERROR: #16 applySolver() at /home/hhornik/gismo/optional/gsIncompressibleFlow/src/gsINSSolver.hpp:531
I could not find any solution for this so far. My question is: Is it possible to use the LSC preconditioner in such case, where the matrix blocks are of type MATNEST? And if so, how?
Thank you,
Hana Honnerova
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240208/606d89f2/attachment.html>
