[petsc-users] KSP has an extra iteration when use shell matrix
Yi Hu
y.hu at mpie.de
Tue Feb 6 14:49:43 CST 2024
Dear Barry,
Thanks for your help. You suggestion works.
I found out another approach. I can still use Vec as ctx of my MatShell,
then I just need to initialize my MatShell with my solver Vec x. Then I
can use an empty FormJacobShell(), coz my MatShell ctx is automatically
updated with my solver vec (as I initialized with it). In MyMult the ctx
of MatShell is the current solve vec.
Best regards,
Yi
On 2/6/24 01:39, Barry Smith wrote:
> You cannot do call MatShellSetContext(jac,X,ierr) in subroutine
> FormJacobianShell(snes,X,jac,B,dummy,ierr) because Fortran arguments
> are always pass by address and the address of the X being passed in
> may not be valid after the routine that called FormJacobianShell() has
> returned. This is why the GetContext works inside this function but
> not later in MyMult.
> Instead add a Vec Xbase member to the MatCtx type and update that
> inside FormJacobShell(). Like
> TYPE(MatCtx),POINTER :: ctxF_pt
> MatShellGetContext(jac,ctxF_ptr,ierr)
> ctxF_pt%Xbase = X
> The reason this works is because ctxF_pt%Xbase = X copies the value of
> X (the PETSc vector) to Xbase, not the address of X.
> Barry
>> On Feb 5, 2024, at 4:18 PM, Yi Hu <y.hu at mpie.de> wrote:
>> Dear Barry,
>> the code is attached.
>> Just to let you know. When I commented out MatShellSetContext() in
>> FormJacobianShell(), then the code seems to work, meaning that the
>> base vector is passed to shell matrix context behind the scene.
>> Best regards,
>> Yi
>> On 2/5/24 19:09, Barry Smith wrote:
>>> Send the entire code.
>>>> On Feb 4, 2024, at 4:43 PM, Yi Hu <y.hu at mpie.de> wrote:
>>>> Thanks for your response. You are correct. I overlooked this step.
>>>> Now I am trying to correct my "shell matrix approach" for ex1f.F90
>>>> of snes solver
>>>> (https://github.com/hyharry/small_petsc_test/blob/master/test_shell_jac/ex1f.F90).
>>>> I realized that I need to record the base vector X in the context
>>>> of shell matrix and then use this info to carry MyMult. However,
>>>> the context cannot be obtained through MatShellGetContext(). Here
>>>> are the critical parts of my code.
>>>> INTERFACE MatCreateShell
>>>> SUBROUTINE MatCreateShell(comm,mloc,nloc,m,n,ctx,mat,ierr)
>>>> USE solver_context
>>>> MPI_Comm :: comm
>>>> PetscInt :: mloc,nloc,m,n
>>>> Vec :: ctx
>>>> Mat :: mat
>>>> PetscErrorCode :: ierr
>>>> END SUBROUTINE MatCreateShell
>>>> END INTERFACE MatCreateShell
>>>> INTERFACE MatShellSetContext
>>>> SUBROUTINE MatShellSetContext(mat,ctx,ierr)
>>>> USE solver_context
>>>> Mat :: mat
>>>> !TYPE(MatCtx) :: ctx
>>>> Vec :: ctx
>>>> END SUBROUTINE MatShellSetContext
>>>> END INTERFACE MatShellSetContext
>>>> INTERFACE MatShellGetContext
>>>> SUBROUTINE MatShellGetContext(mat,ctx,ierr)
>>>> USE solver_context
>>>> Mat :: mat
>>>> Vec, Pointer :: ctx
>>>> END SUBROUTINE MatShellGetContext
>>>> END INTERFACE MatShellGetContext
>>>> in my FormShellJacobian() I did
>>>> subroutine FormJacobianShell(snes,X,jac,B,dummy,ierr)
>>>> Then in MyMult() I tried to recover this context by
>>>> call MatShellGetContext(J,x,ierr)
>>>> call VecView(x,PETSC_VIEWER_STDOUT_WORLD,ierr)
>>>> Then the program failed with
>>>> [0]PETSC ERROR: --------------------- Error Message
>>>> [0]PETSC ERROR: Null argument, when expecting valid pointer
>>>> [0]PETSC ERROR: Null Pointer: Parameter # 1
>>>> In MyMult, I actually defined x to be a pointer. So I am confused
>>>> here.
>>>> Best regards,
>>>> Yi
>>>> On 1/31/24 03:18, Barry Smith wrote:
>>>>> It is not running an extra KSP iteration. This "extra" matmult
>>>>> is normal and occurs in many of the SNESLineSearchApply_*
>>>>> functions, for example,
>>>>> https://petsc.org/release/src/snes/linesearch/impls/bt/linesearchbt.c.html#SNESLineSearchApply_BT It
>>>>> is used to decide if the Newton step results in sufficient
>>>>> decrease of the function value.
>>>>> Barry
>>>>>> On Jan 30, 2024, at 3:19 PM, Yi Hu <y.hu at mpie.de> wrote:
>>>>>> Hello Barry,
>>>>>> Thanks for your reply. The monitor options are fine. I actually
>>>>>> meant my modification of snes tutorial ex1f.F90 does not work and
>>>>>> has some unexpected behavior. I basically wanted to test if I can
>>>>>> use a shell matrix as my jacobian (code is here
>>>>>> After compile my modified version and run with these monitor
>>>>>> options, it gives me the following,
>>>>>> ( in rhs )
>>>>>> ( leave rhs )
>>>>>> 0 SNES Function norm 6.041522986797e+00
>>>>>> ++++++++++++ in jac shell +++++++++++
>>>>>> 0 KSP Residual norm 6.041522986797e+00
>>>>>> === start mymult ===
>>>>>> === done mymult ===
>>>>>> 1 KSP Residual norm 5.065392549852e-16
>>>>>> Linear solve converged due to CONVERGED_RTOL iterations 1
>>>>>> === done mymult ===
>>>>>> ( in rhs )
>>>>>> ( leave rhs )
>>>>>> 1 SNES Function norm 3.512662245652e+00
>>>>>> 0 KSP Residual norm 3.512662245652e+00
>>>>>> === done mymult ===
>>>>>> 1 KSP Residual norm 6.230314124713e-16
>>>>>> === done mymult ===
>>>>>> ( in rhs )
>>>>>> ( leave rhs )
>>>>>> ( in rhs )
>>>>>> ( leave rhs )
>>>>>> 2 SNES Function norm 8.969285922373e-01
>>>>>> 0 KSP Residual norm 8.969285922373e-01
>>>>>> === done mymult ===
>>>>>> 1 KSP Residual norm 0.000000000000e+00
>>>>>> Linear solve converged due to CONVERGED_ATOL iterations 1
>>>>>> === done mymult ===
>>>>>> ( in rhs )
>>>>>> ( leave rhs )
>>>>>> ( in rhs )
>>>>>> ( leave rhs )
>>>>>> 3 SNES Function norm 4.863816734540e-01
>>>>>> 0 KSP Residual norm 4.863816734540e-01
>>>>>> === done mymult ===
>>>>>> === done mymult ===
>>>>>> ( in rhs )
>>>>>> ( leave rhs )
>>>>>> ( in rhs )
>>>>>> ( leave rhs )
>>>>>> 4 SNES Function norm 3.512070785520e-01
>>>>>> 0 KSP Residual norm 3.512070785520e-01
>>>>>> === done mymult ===
>>>>>> === done mymult ===
>>>>>> ( in rhs )
>>>>>> ( leave rhs )
>>>>>> ( in rhs )
>>>>>> ( leave rhs )
>>>>>> 5 SNES Function norm 2.769700293115e-01
>>>>>> 0 KSP Residual norm 2.769700293115e-01
>>>>>> === done mymult ===
>>>>>> 1 KSP Residual norm 1.104778916974e-16
>>>>>> === done mymult ===
>>>>>> ( in rhs )
>>>>>> ( leave rhs )
>>>>>> ( in rhs )
>>>>>> ( leave rhs )
>>>>>> 6 SNES Function norm 2.055345318150e-01
>>>>>> 0 KSP Residual norm 2.055345318150e-01
>>>>>> === done mymult ===
>>>>>> === done mymult ===
>>>>>> ( in rhs )
>>>>>> ( leave rhs )
>>>>>> ( in rhs )
>>>>>> ( leave rhs )
>>>>>> 7 SNES Function norm 1.267482220786e-01
>>>>>> 0 KSP Residual norm 1.267482220786e-01
>>>>>> === done mymult ===
>>>>>> 1 KSP Residual norm 1.498679601680e-17
>>>>>> === done mymult ===
>>>>>> ( in rhs )
>>>>>> ( leave rhs )
>>>>>> ( in rhs )
>>>>>> ( leave rhs )
>>>>>> 8 SNES Function norm 3.468150619264e-02
>>>>>> 0 KSP Residual norm 3.468150619264e-02
>>>>>> === done mymult ===
>>>>>> 1 KSP Residual norm 5.944160522951e-18
>>>>>> === done mymult ===
>>>>>> ( in rhs )
>>>>>> ( leave rhs )
>>>>>> ( in rhs )
>>>>>> ( leave rhs )
>>>>>> ( in rhs )
>>>>>> ( leave rhs )
>>>>>> ( in rhs )
>>>>>> ( leave rhs )
>>>>>> ( in rhs )
>>>>>> ( leave rhs )
>>>>>> ( in rhs )
>>>>>> ( leave rhs )
>>>>>> ( in rhs )
>>>>>> ( leave rhs )
>>>>>> ( in rhs )
>>>>>> ( leave rhs )
>>>>>> ( in rhs )
>>>>>> ( leave rhs )
>>>>>> ( in rhs )
>>>>>> ( leave rhs )
>>>>>> ( in rhs )
>>>>>> ( leave rhs )
>>>>>> ( in rhs )
>>>>>> ( leave rhs )
>>>>>> ( in rhs )
>>>>>> ( leave rhs )
>>>>>> ( in rhs )
>>>>>> ( leave rhs )
>>>>>> === done mymult ===
>>>>>> Nonlinear solve did not converge due to DIVERGED_LINE_SEARCH
>>>>>> iterations 8
>>>>>> Number of SNES iterations = 8
>>>>>> After each "Linear solve converged due to CONVERGED_ATOL
>>>>>> iterations", the code starts to do mymult again. So I thought it
>>>>>> did an extra (unwanted) KSP iteration. I would like to ask if
>>>>>> this extra iteration could be disabled, or maybe I am wrong about it.
>>>>>> Best regards,
>>>>>> Yi
>>>>>> On 1/30/24 18:35, Barry Smith wrote:
>>>>>>> How do I see a difference? What does "hence ruin my previous
>>>>>>> converged KSP result" mean? A different answer at the end of the
>>>>>>> KSP solve?
>>>>>>> $ ./joe > joe.basic
>>>>>>> ~/Src/petsc/src/ksp/ksp/tutorials*(barry/2023-09-15/fix-log-pcmpi=)*arch-fix-log-pcmpi
>>>>>>> $ ./joe -ksp_monitor -ksp_converged_reason -snes_monitor >
>>>>>>> joe.monitor
>>>>>>> $ diff joe.basic joe.monitor
>>>>>>> 0a1,36
>>>>>>> > Linear solve converged due to CONVERGED_RTOL_NORMAL iterations 1
>>>>>>> > 1 KSP Residual norm 1.535110861002e-17
>>>>>>>> On Jan 30, 2024, at 11:19 AM, Yi Hu <y.hu at mpie.de> wrote:
>>>>>>>> Dear PETSc team,
>>>>>>>> I am still trying to sort out my previous
>>>>>>>> threadhttps://lists.mcs.anl.gov/pipermail/petsc-users/2024-January/050079.htmlusing
>>>>>>>> a minimal working example. However, I encountered another
>>>>>>>> problem. Basically I combined the basic usage of SNES solver
>>>>>>>> and shell matrix and tried to make it work. The jacobian of my
>>>>>>>> snes is replaced by a customized MATOP_MULT. The minimal
>>>>>>>> example code can be viewed
>>>>>>>> herehttps://github.com/hyharry/small_petsc_test/blob/master/test_shell_jac/ex1f.F90
>>>>>>>> When running with -ksp_monitor -ksp_converged_reason, it shows
>>>>>>>> an extra mymult step, and hence ruin my previous converged KSP
>>>>>>>> result. Implement a customized converged call-back also does
>>>>>>>> not help. I am wondering how to skip this extra ksp iteration.
>>>>>>>> Could anyone help me on this?
>>>>>>>> Best wishes,
>>>>>>>> Yi
>>>>>>>> Stay up to date and follow us on LinkedIn, Twitter and YouTube.
>>>>>>>> Max-Planck-Institut für Eisenforschung GmbH
>>>>>>>> Max-Planck-Straße 1
>>>>>>>> D-40237 Düsseldorf
>>>>>>>> Handelsregister B 2533
>>>>>>>> Amtsgericht Düsseldorf
>>>>>>>> Geschäftsführung
>>>>>>>> Prof. Dr. Gerhard Dehm
>>>>>>>> Prof. Dr. Jörg Neugebauer
>>>>>>>> Prof. Dr. Dierk Raabe
>>>>>>>> Dr. Kai de Weldige
>>>>>>>> Ust.-Id.-Nr.: DE 11 93 58 514
>>>>>>>> Steuernummer: 105 5891 1000
>>>>>>>> Please consider that invitations and e-mails of our institute are
>>>>>>>> only valid if they end with …@mpie.de.
>>>>>>>> If you are not sure of the validity please contact rco at mpie.de
>>>>>>>> Bitte beachten Sie, dass Einladungen zu Veranstaltungen und E-Mails
>>>>>>>> aus unserem Haus nur mit der Endung …@mpie.de gültig sind.
>>>>>>>> In Zweifelsfällen wenden Sie sich bitte an rco at mpie.de
>>>>>> Max-Planck-Straße 1
>>>>>> D-40237 Düsseldorf
>>>>>> Geschäftsführung
>>>>>> Dr. Kai de Weldige
>>>> Max-Planck-Straße 1
>>>> D-40237 Düsseldorf
>>>> Geschäftsführung
>>>> Dr. Kai de Weldige
>> Max-Planck-Straße 1
>> D-40237 Düsseldorf
>> Geschäftsführung
>> Dr. Kai de Weldige
>> <ex1f.F90>
Max-Planck-Straße 1
D-40237 Düsseldorf
Geschäftsführung
Dr. Kai de Weldige
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240206/559ddb82/attachment-0001.html>
Type: text/x-fortran
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240206/559ddb82/attachment-0001.bin>
