[petsc-users] Question on using petsc matrix with hip
Junchao Zhang
junchao.zhang at gmail.com
Sun Feb 4 22:30:25 CST 2024
On Sun, Feb 4, 2024 at 9:57 PM Runfeng Jin <jsfaraway at gmail.com> wrote:
> Hi,
> I see in document the mat status in hip is still in development, but I
> see some hip interface in MAT. I want to use petsc with primme(eigenvalue
> solver) to diagonalize the matrix in AMD GPU. The primme need user to
> provide MV (matrix-vector operation in y=AX) in GPU, and I want to use
> PETSc to realize it. Can PETSc support this in hip? thank you!
petsc/hip backend supports sparse matrix vector multiplication (via AMD
hipsparce). The matrix has to be in the CSR format (i.e., MATAIJ in
petsc).
> Runfeng Jin
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240204/addad9b8/attachment.html>
