[petsc-users] PETSC configuration on linux with intel MKL
Satish Balay
balay.anl at fastmail.org
Sun Dec 29 16:06:54 CST 2024
This syntax is useful for python - for ex.: config/examples*.py
Best to use shell friendly notation - when not using python scripts. i.e.:
--with-blaslapack-lib="/opt/intel/oneapi/mkl/2025.0/lib/intel64/libmkl_blas95_lp64.a /opt/intel/oneapi/mkl/2025.0/lib/intel64/libmkl_lapack95_lp64.a /opt/intel/oneapi/mkl/2025.0/lib/intel64/libmkl_gf_lp64.a /opt/intel/oneapi/mkl/2025.0/lib/intel64/libmkl_sequential.a /opt/intel/oneapi/mkl/2025.0/lib/intel64/libmkl_core.a"
or
--with-blaslapack-lib="-L/opt/intel/oneapi/mkl/2025.0/lib/intel64/ -lmkl_lapack95_lp64 -lmklblas95_lp64 -lmkl_gf_lp64 -lmkl_sequential -lmkl_lapack95_lp64"
Also "--with-blaslapack-dir=/opt/intel/oneapi/mkl/2025.0/lib/intel64" should automatically find and give something like:
BlasLapack:
Intel MKL Version: 20220000
Includes: -I/nfs/gce/software/custom/linux-ubuntu22.04-x86_64/spack/opt/spack/linux-ubuntu22.04-x86_64/gcc-11.2.0/intel-oneapi-mkl-2022.0.2-lzrncoj/mkl/2022.0.2/include
Libraries: -Wl,-rpath,/nfs/gce/software/custom/linux-ubuntu22.04-x86_64/spack/opt/spack/linux-ubuntu22.04-x86_64/gcc-11.2.0/intel-oneapi-mkl-2022.0.2-lzrncoj/mkl/2022.0.2/lib/intel64 -L/nfs/gce/software/custom/linux-ubuntu22.04-x86_64/spack/opt/spack/linux-ubuntu22.04-x86_64/gcc-11.2.0/intel-oneapi-mkl-2022.0.2-lzrncoj/mkl/2022.0.2/lib/intel64 -lmkl_intel_lp64 -lmkl_core -lmkl_intel_thread -liomp5 -ldl -lpthread
Satish
On Sun, 29 Dec 2024, Pierre Jolivet wrote:
> I just copied you configure line, you also have a whitespace in the [ ], best to remove that: libmkl_blas95_lp64.a", "/opt/intel/ -> libmkl_blas95_lp64.a,/opt/intel/ and so on.
> Thanks,
> Pierre
> > On 29 Dec 2024, at 9:09 PM, Bruno Ramon Batista Fernande <brbfernandes at utexas.edu> wrote:
> > Hi Pierre,
> > I tried it and got the same error message. Still, no configure.log was generated. It seems like it doesn't even start the configuration.
> > Best regards,
> > Bruno
> > On Sun, Dec 29, 2024 at 1:45 PM Pierre Jolivet <pierre at joliv.et <mailto:pierre at joliv.et>> wrote:
> >>> On 30 Dec 2024, at 2:24 AM, Bruno Ramon Batista Fernande <brbfernandes at utexas.edu <mailto:brbfernandes at utexas.edu>> wrote:
> >>> Hi Satish,
> >>> Thank you for your prompt response.
> >>> It seems like it doesn't reach the point of writing the configure.log for this issue.
> >>> The command used is below. I am using mpich and oneAPI both installed from apt from Ubuntu.
> >>> ./configure --with-cc=mpicc --with-cxx=mpicxx --with-fc=mpif90 --with-debugging=0 --download-hypre --with-blaslapack-libs=["/opt/intel/oneapi/mkl/2025.0/lib/intel64/libmkl_blas95_lp64.a", "/opt/intel/oneapi/mkl/2025.0/lib/intel64/libmkl_lapack95_lp64.a","/opt/intel/oneapi/mkl/2025.0/lib/intel64/libmkl_gf_lp64.a", "/opt/intel/oneapi/mkl/2025.0/lib/intel64/libmkl_sequential.a","/opt/intel/oneapi/mkl/2025.0/lib/intel64/libmkl_core.a"] --with-scalapack-libs=["/opt/intel/oneapi/mkl/2025.0/lib/intel64/libmkl_scalapack_lp64.a","/opt/intel/oneapi/mkl/2025.0/lib/intel64/libmkl_blacs_lp64.a"] --with-scalapack-include=/opt/intel/oneapi/mkl/2025.0/include
> >> It’s not -libs=, it’s -lib=, and there is no need for quotation marks.
> >> Try again, and if it still does not work, please send configure.log, there is no reason for it not being generated.
> >> Thanks,
> >> Pierre
> >>> Best regards,
> >>> Bruno
> >>> On Sun, Dec 29, 2024 at 8:15 AM Satish Balay <balay.anl at fastmail.org <mailto:balay.anl at fastmail.org>> wrote:
> >>>> Hm - what was the configure command [with options] used here? Can you send corresponding configure.log?
> >>>> Satish
> >>>> On Sat, 28 Dec 2024, Bruno Ramon Batista Fernande wrote:
> >>>> > Hi,
> >>>> > I am trying to use the oneAPI MKL 2025 into my PETSC configuration on
> >>>> > Linux. However, I get the following error as I enter the names of the mkl
> >>>> > libraries:
> >>>> > ERROR in COMMAND LINE ARGUMENT to ./configure
> >>>> > The option
> >>>> > /opt/intel/oneapi/mkl/2025.0/lib/intel64/libmkl_lapack95_lp64.a,/opt/intel/oneapi/mkl/2025.0/lib/intel64/libmkl_gf_lp64.a,
> >>>> > should probably be
> >>>> > /opt/intel/oneapi/mkl/2025.0/lib/intel64/libmkl-lapack95-lp64.a,/opt/intel/oneapi/mkl/2025.0/lib/intel64/libmkl-gf-lp64.a,
> >>>> > As you can see, the configure suggest to use libraries with hyphen in their
> >>>> > names but the original libraries have underscores in it. Any way to bypass
> >>>> > this issue without creating links or creating copies of files?
> >>>> > Best regards,
> >>>> > Bruno
