[petsc-users] PETSC configuration on linux with intel MKL
Bruno Ramon Batista Fernande brbfernandes at utexas.edu
Sat Dec 28 23:16:51 CST 2024
I am trying to use the oneAPI MKL 2025 into my PETSC configuration on
Linux. However, I get the following error as I enter the names of the mkl
libraries:
                        ERROR in COMMAND LINE ARGUMENT to ./configure
  The option
/opt/intel/oneapi/mkl/2025.0/lib/intel64/libmkl_lapack95_lp64.a,/opt/intel/oneapi/mkl/2025.0/lib/intel64/libmkl_gf_lp64.a,
  should probably be
/opt/intel/oneapi/mkl/2025.0/lib/intel64/libmkl-lapack95-lp64.a,/opt/intel/oneapi/mkl/2025.0/lib/intel64/libmkl-gf-lp64.a,
As you can see, the configure suggest to use libraries with hyphen in their
names but the original libraries have underscores in it. Any way to bypass
this issue without creating links or creating copies of files?
Best regards,
Bruno
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20241228/5813e1ce/attachment.html>
