[petsc-users] "-ts_exact_final_time matchstep" leads to DIVERGED_STEP_REJECTED
Blondel, Sophie
sblondel at utk.edu
Tue Dec 10 10:10:49 CST 2024
Now I see that the dt is set to 0 s in that case instead of 1.0e-12 s.
Sophie
Sent: Tuesday, December 10, 2024 11:08
To: Barry Smith <bsmith at petsc.dev>; Blondel, Sophie <sblondel at utk.edu>
Cc: petsc-users at mcs.anl.gov <petsc-users at mcs.anl.gov>; xolotl-psi-development at lists.sourceforge.net <xolotl-psi-development at lists.sourceforge.net>
Subject: Re: [petsc-users] "-ts_exact_final_time matchstep" leads to DIVERGED_STEP_REJECTED
Good morning Barry,
Attached are the updated files, there is more useful information in them.
Cheers,
Sophie
From: Blondel, Sophie via Xolotl-psi-development <xolotl-psi-development at lists.sourceforge.net>
Sent: Monday, December 9, 2024 17:29
Subject: Re: [Xolotl-psi-development] [petsc-users] "-ts_exact_final_time matchstep" leads to DIVERGED_STEP_REJECTED
Hi Barry,
I hope you are doing well.
Attached are the output. To give a little more context, this is a "new" way of running the code where multiple instances are created and communicate together every few time steps (like coupling the code with itself in memory). Here there are 3 instances that each have a separate TS object, plus one "main" instance that doesn't solve anything but compute rates to exchange between the other instances.
Cheers,
Sophie
Sent: Monday, December 9, 2024 15:12
To: Blondel, Sophie <sblondel at utk.edu>
On Dec 9, 2024, at 2:56 PM, Blondel, Sophie via petsc-users <petsc-users at mcs.anl.gov> wrote:
I am trying to understand a strange behavior I'm encountering: when running my application with "-ts_exact_final_time stepover" everything goes well, but when I switch to "matchstep" I get DIVERGED_STEP_REJECTED before the first time step is finished.
This is in the very first time-step in TSSolve?
Please run with -ts_monitor and send all the output (best for a short time interval and do it twice once with -ts_exact_final_time stepover and once with exact.
Barry
I tried increasing the maximum number of rejections and it just takes longer to diverge, and if I set the value to "unlimited" it is basically an infinite loop.
Is there a way to check why is the step rejected? Could the "matchstep" option change tolerances somewhere that would cause that behavior?
Let me know if I should provide more information.
Best,
Sophie Blondel
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20241210/9e1eae18/attachment.html>
