[petsc-users] PCMG with shell restrictions
Matteo Semplice matteo.semplice at uninsubria.it
Tue Dec 10 06:02:35 CST 2024
Dear petsc-users,
     I am trying with a student to modify the MG example 65 to use
mat-shells instead of assembled matrices. Our use case is for a method
that will use custom shell operators and shell interpolation/restrictions.
To start we have modified ex65 and tried to replace the standard
restriction/interpolation with a shell matrix that performs the same
operations on the DMDA grids.
I attach our modifications to ex65.
The problem is that the code sometimes completes execution and sometimes
errors out like
$ ./ex65shell -ksp_monitor -pc_type mg -da_refine 2 -ksp_rtol 1e-1
 >> Created DMshell 0x55bbc83c91a0 (0x55bbc8390a80)
Calling KSPSolve from main
computeRHS on grid 513
computeMatrix on grid 513
Inside Coarsen
 >> Created DMshell 0x55bbc84c5270 (0x55bbc84b2ff0)
Inside Coarsen
 >> Created DMshell 0x55bbc84e0a30 (0x55bbc84bdb60)
 >> Create interpolation from 0x55bbc84c5270(0x55bbc84b2ff0) to
0x55bbc83c91a0(0x55bbc8390a80)
[0]PETSC ERROR: --------------------- Error Message
[0]PETSC ERROR: Invalid pointer
[0]PETSC ERROR: Invalid Pointer to PetscObject: Argument 'obj'
(parameter # 1)
[0]PETSC ERROR: See https://urldefense.us/v3/__https://petsc.org/release/faq/__;!!G_uCfscf7eWS!Y29qRoOD71oxcd-BQFTUohkIToMJNW3puZ3CerpZ6pBnecqhBQ8TBwhSnikLt4BYQTmsBgtKvoCFi-JuLXQAE_Oe_a_d2XOL8KvOmw$  for trouble shooting.
[0]PETSC ERROR: Petsc Release Version 3.22.0, unknown
[0]PETSC ERROR: ./ex65shell with 1 MPI process(es) and PETSC_ARCH  on
signalkuppe by matteo Tue Dec 10 12:55:12 2024
[0]PETSC ERROR: Configure options:
--prefix=/home/matteo/software/petscsaved/3.22-opt/
PETSC_DIR=/home/matteo/software/petsc --PETSC_ARCH=dbg
--with-debugging=1 --with-st
rict-petscerrorcode --download-hdf5 --download-ml --with-metis
--with-parmetis --with-gmsh --with-triangle --with-zlib
--with-p4est-dir=~/software/p4est/local/
[0]PETSC ERROR: #1 PetscObjectReference() at
/home/matteo/software/petsc/src/sys/objects/inherit.c:620
[0]PETSC ERROR: #2 PCMGSetRScale() at
/home/matteo/software/petsc/src/ksp/pc/impls/mg/mgfunc.c:394
[0]PETSC ERROR: #3 PCSetUp_MG() at
/home/matteo/software/petsc/src/ksp/pc/impls/mg/mg.c:998
[0]PETSC ERROR: #4 PCSetUp() at
/home/matteo/software/petsc/src/ksp/pc/interface/precon.c:1071
[0]PETSC ERROR: #5 KSPSetUp() at
/home/matteo/software/petsc/src/ksp/ksp/interface/itfunc.c:415
[0]PETSC ERROR: #6 KSPSolve_Private() at
/home/matteo/software/petsc/src/ksp/ksp/interface/itfunc.c:826
[0]PETSC ERROR: #7 KSPSolve() at
/home/matteo/software/petsc/src/ksp/ksp/interface/itfunc.c:1075
[0]PETSC ERROR: #8 main() at ../src/ex65shell.c:79
[0]PETSC ERROR: PETSc Option Table entries:
[0]PETSC ERROR: -da_refine 2 (source: command line)
[0]PETSC ERROR: -ksp_monitor (source: command line)
[0]PETSC ERROR: -ksp_rtol 1e-1 (source: command line)
[0]PETSC ERROR: -pc_type mg (source: command line)
[0]PETSC ERROR: ----------------End of Error Message -------send entire
error message to petsc-maint at mcs.anl.gov----------
In all cases valgrind complains like
$ valgrind ./ex65shell -ksp_monitor -pc_type mg -da_refine 2 -ksp_rtol
1e-1 -int_view ascii::ascii_info
==2130767== Memcheck, a memory error detector
==2130767== Copyright (C) 2002-2022, and GNU GPL'd, by Julian Seward et al.
==2130767== Using Valgrind-3.19.0 and LibVEX; rerun with -h for
copyright info
==2130767== Command: ./ex65shell -ksp_monitor -pc_type mg -da_refine 2
-ksp_rtol 1e-1 -int_view ascii::ascii_info
==2130767==
hwloc x86 backend cannot work under Valgrind, disabling.
May be reenabled by dumping CPUIDs with hwloc-gather-cpuid
and reloading them under Valgrind with HWLOC_CPUID_PATH.
 >> Created DMshell 0xfbf50f0 (0xfb49480)
Inside Coarsen
 >> Created DMshell 0xff404a0 (0xff062d0)
Inside Coarsen
 >> Created DMshell 0xff78ca0 (0xff4a530)
 >> Create interpolation from 0xff404a0(0xff062d0) to 0xfbf50f0(0xfb49480)
Mat Object: 1 MPI process
  type: shell
  rows=513, cols=257
==2130767== Conditional jump or move depends on uninitialised value(s)
==2130767==    at 0x83FDAAE: PCSetUp_MG (mg.c:998)
==2130767==    by 0x8620C04: PCSetUp (precon.c:1071)
==2130767==    by 0x7DA78D5: KSPSetUp (itfunc.c:415)
==2130767==    by 0x7DB2093: KSPSolve_Private (itfunc.c:826)
==2130767==    by 0x7DB7A53: KSPSolve (itfunc.c:1075)
==2130767==    by 0x10D2F7: main (ex65shell.c:79)
==2130767==
==2130767==    at 0x5794061: VecDestroy (vector.c:570)
==2130767==    by 0x83FDC36: PCSetUp_MG (mg.c:999)
==2130767==
We are clearly doing something wrong since PCSetUp_MG (mg.c:998) is an
area of code where I wouldn't expect we would enter.
Can you advise on the proper way to achieve our goal?
Best regards
     Matteo
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20241210/f3e1ef95/attachment.html>
Type: text/x-patch
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20241210/f3e1ef95/attachment.bin>
