[petsc-users] Parallel computing in SNES
David Jiawei LUO LIANG
12431140 at mail.sustech.edu.cn
Tue Dec 10 03:31:43 CST 2024
Hello PETSc,
I want to substitute the existing nonlinear solver codes with SNES.
The existing code is Parallel computing.
My FormFunction and FormJacobian is attached in file Res_Jac.cpp.
The global tangent matrix assembly and residual function assembly are both implemented by invoking user pointers.
The following is the message, we can find that SNES just iterate once.
I think the problem is input solution Vec y doesn't link to Residual Vec f, because my update is stored in the user variables.
If I use
const PetscScalar *yy;
VecGetArrayRead(y, &yy);
the value of yy is not identical to Vec y, because there are multi thread.
So, my problem is how to assembly residual and tangent in parallel environment?
南方科技大学/学生/研究生/2024
广东省深圳市南山区学苑大道1088号
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20241210/f193dbb9/attachment-0001.html>
Name: C30690D0 at 0F60110C.7F0A586700000000.jpg
Type: image/jpeg
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20241210/f193dbb9/attachment-0001.jpg>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20241210/f193dbb9/attachment-0001.obj>
