[petsc-users] "-ts_exact_final_time matchstep" leads to DIVERGED_STEP_REJECTED
Barry Smith
bsmith at petsc.dev
Mon Dec 9 19:04:00 CST 2024
Sorry, try both with -ts_adapt_monitor
> On Dec 9, 2024, at 5:29 PM, Blondel, Sophie <sblondel at utk.edu> wrote:
> Hi Barry,
> I hope you are doing well.
> Attached are the output. To give a little more context, this is a "new" way of running the code where multiple instances are created and communicate together every few time steps (like coupling the code with itself in memory). Here there are 3 instances that each have a separate TS object, plus one "main" instance that doesn't solve anything but compute rates to exchange between the other instances.
> Cheers,
> Sophie
> From: Barry Smith <bsmith at petsc.dev>
> Sent: Monday, December 9, 2024 15:12
> To: Blondel, Sophie <sblondel at utk.edu>
> Cc: petsc-users at mcs.anl.gov <petsc-users at mcs.anl.gov>; xolotl-psi-development at lists.sourceforge.net <xolotl-psi-development at lists.sourceforge.net>
> Subject: Re: [petsc-users] "-ts_exact_final_time matchstep" leads to DIVERGED_STEP_REJECTED
>> On Dec 9, 2024, at 2:56 PM, Blondel, Sophie via petsc-users <petsc-users at mcs.anl.gov> wrote:
>> Hi,
>> I am trying to understand a strange behavior I'm encountering: when running my application with "-ts_exact_final_time stepover" everything goes well, but when I switch to "matchstep" I get DIVERGED_STEP_REJECTED before the first time step is finished.
> This is in the very first time-step in TSSolve?
> Please run with -ts_monitor and send all the output (best for a short time interval and do it twice once with -ts_exact_final_time stepover and once with exact.
> Barry
>> I tried increasing the maximum number of rejections and it just takes longer to diverge, and if I set the value to "unlimited" it is basically an infinite loop.
>> Is there a way to check why is the step rejected? Could the "matchstep" option change tolerances somewhere that would cause that behavior?
>> Let me know if I should provide more information.
>> Best,
>> Sophie Blondel
> <stepover.txt><matchstep.txt>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20241209/5465215d/attachment.html>
