[petsc-users] "-ts_exact_final_time matchstep" leads to DIVERGED_STEP_REJECTED
Blondel, Sophie
sblondel at utk.edu
Mon Dec 9 13:56:21 CST 2024
I am trying to understand a strange behavior I'm encountering: when running my application with "-ts_exact_final_time stepover" everything goes well, but when I switch to "matchstep" I get DIVERGED_STEP_REJECTED before the first time step is finished. I tried increasing the maximum number of rejections and it just takes longer to diverge, and if I set the value to "unlimited" it is basically an infinite loop.
Is there a way to check why is the step rejected? Could the "matchstep" option change tolerances somewhere that would cause that behavior?
Let me know if I should provide more information.
Best,
Sophie Blondel
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20241209/5f98c6e0/attachment.html>
