[petsc-users] Using MatCreateComposite with petsc4py
Eric Chamberland
Eric.Chamberland at giref.ulaval.ca
Tue Dec 3 15:33:17 CST 2024
great! Thank you all for this information! Indeed MATPYTHON cover our
needs!
Eric
On 2024-12-03 01:36, Stefano Zampini wrote:
> Eric
> the python equivalent of a MATSHELL is MATPYTHON, where you are in
> control of the implementation of the matrix vector product and other
> operations, see
> https://urldefense.us/v3/__https://petsc.org/release/petsc4py/petsc_python_types.html*petsc-python-matrix-type__;Iw!!G_uCfscf7eWS!ZD3aymPzmAu2afLqaAuAYv18OwPDU-6XWUzuj2lTZ7oyjCjYPx39HcSblHApdBD0BtxMNmBq8_BssfuDCbR1d2QRvp0ds5fft1-XkhiS$
> This should cover your needs, let me know if you need methods that are
> not wrapped
> Il giorno mar 3 dic 2024 alle ore 09:15 Pierre Jolivet
> <pierre at joliv.et> ha scritto:
>> On 2 Dec 2024, at 11:15 PM, Eric Chamberland via petsc-users
>> <petsc-users at mcs.anl.gov> wrote:
>> Hello,
>> We were exploring the use of the |MatCreateComposite| function
>> with |petsc4py|, but we noticed that it doesn't seem to be
>> available in the Python interface
>> (https://urldefense.us/v3/__https://petsc.org/release/petsc4py/reference/petsc4py.PETSc.Mat.html__;!!G_uCfscf7eWS!ZD3aymPzmAu2afLqaAuAYv18OwPDU-6XWUzuj2lTZ7oyjCjYPx39HcSblHApdBD0BtxMNmBq8_BssfuDCbR1d2QRvp0ds5fftzVa96TG$
>> <https://urldefense.us/v3/__https://petsc.org/release/petsc4py/reference/petsc4py.PETSc.Mat.html__;!!G_uCfscf7eWS!fphemsDPNmxHUr-ybYLt_xWUrP575eKuI4xixwypEzd2g7uc6qMilt8etg13o24gU0vloOVrsHDXwqlgoY1T7jrcQUiv83PrXvNSYlNU$>).
>> We were wondering if this is due to a technical limitation or if
>> there is a better alternative to achieve the same result.
>> Our goal is to create a matrix representing PTAP without
>> explicitly computing the product.
>> We also considered using |MatShell|, but it seems that this
>> approach is not supported in |petsc4py| either.
> What do you mean?
> You can use either a MatShell or a MatPython in petsc4py out of
> the box.
> Thanks,
> Pierre
>> On the other hand, we noticed that |MatCreateTranspose| is
>> implemented, and it aligns somewhat with the kind of operation
>> we're aiming for.
>> Any insights or advice you could provide would be greatly
>> appreciated!
>> Thank you,
>> Eric
>> Eric Chamberland, ing., M. Ing
>> Professionnel de recherche
>> GIREF/Université Laval
>> (418) 656-2131 poste 41 22 42
> Stefano
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20241203/00416f7e/attachment.html>
