[petsc-users] Using MatCreateComposite with petsc4py
Matthew Knepley
knepley at gmail.com
Mon Dec 2 16:32:36 CST 2024
On Mon, Dec 2, 2024 at 5:14 PM Eric Chamberland via petsc-users <
petsc-users at mcs.anl.gov> wrote:
> Hello,
> We were exploring the use of the MatCreateComposite function with petsc4py,
> but we noticed that it doesn't seem to be available in the Python interface
> (https://urldefense.us/v3/__https://petsc.org/release/petsc4py/reference/petsc4py.PETSc.Mat.html__;!!G_uCfscf7eWS!aHjys_axrlOjrR_fWK2NdV-rCkGLXuEuWPoyrHbLp_01Vvr48evkik5dT077BtK20PuTlFz8mMpKHhBMaM2o$
> <https://urldefense.us/v3/__https://petsc.org/release/petsc4py/reference/petsc4py.PETSc.Mat.html__;!!G_uCfscf7eWS!fphemsDPNmxHUr-ybYLt_xWUrP575eKuI4xixwypEzd2g7uc6qMilt8etg13o24gU0vloOVrsHDXwqlgoY1T7jrcQUiv83PrXvNSYlNU$>
> We were wondering if this is due to a technical limitation or if there is
> a better alternative to achieve the same result.
No, we just forgot to put in this interface. It should be done. It does not
look hard, cutting and pasting from other functions.
Matt
> Our goal is to create a matrix representing PTAP without explicitly
> computing the product.
> We also considered using MatShell, but it seems that this approach is not
> supported in petsc4py either.
> On the other hand, we noticed that MatCreateTranspose is implemented, and
> it aligns somewhat with the kind of operation we're aiming for.
> Any insights or advice you could provide would be greatly appreciated!
> Thank you,
> Eric
> Eric Chamberland, ing., M. Ing
> Professionnel de recherche
> GIREF/Université Laval
> (418) 656-2131 poste 41 22 42
experiments lead.
-- Norbert Wiener
https://urldefense.us/v3/__https://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!aHjys_axrlOjrR_fWK2NdV-rCkGLXuEuWPoyrHbLp_01Vvr48evkik5dT077BtK20PuTlFz8mMpKHripB8Lo$ <https://urldefense.us/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!aHjys_axrlOjrR_fWK2NdV-rCkGLXuEuWPoyrHbLp_01Vvr48evkik5dT077BtK20PuTlFz8mMpKHsRQGEhB$ >
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20241202/28eb8985/attachment.html>
