[petsc-users] Preliminaries to use gpu capabilities
Edoardo alinovi
edoardo.alinovi at gmail.com
Sun Aug 25 06:49:07 CDT 2024
Hello Petsc friends,
As many people is doing, I would like to explore a bit gpu capabilities
(cuda) in petsc.
Before attemping any coding effort I would like to hear from you if all of
this make sense:
- compile mpi with cuda support
- compile petsc with cuda support
- build matrix and vectors as MATAIJCUSPARSE and VECMPICUDA to tell petsc
using gpu.
That's really it or do I need to take care of something else?
I have seen that there is an amgXWrapper library aroud, but not sure if it
is still relevant now or not.
Thank you for the suggestions!
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240825/bbc0c404/attachment.html>
